Topic: Opus inside OggPages (Read 19312 times) previous topic - next topic
I'm currently working on a Winamp input plugin to provide better native support for the Opus codec than the one that dshow could provide linking in the k-lite codec pack.  Metadata and whatnot.
Anyways, I'm dynamically linking in the official opusfile-0.1-win32 libraries from the opus-codec site and I have been able to succesfully decode and get Winamp to play a local .opus file.  However, I've not been so fortunate with online streams.
I am not familiar at all with any of the internals/packets/pages/whatevers of live streams.  I can get my plugin to connect to a server, get the data it's outchucking, parse out the HTTP header, parse the seperate Ogg Pages, get the OpusHead, and get the OpusTags, but that's it.  I tried sending, just the Ogg pages, a chain of Ogg pages, individual segments in the pages, to all of the in-memory functions of the libraries but they all either return error code -133 (OP_EBADHEADER), -137 (OP_EBADLINK), or -139 (OP_EBADTIMESTAMP).
I know nothing of "granules", whatever that means.
Can somebody tell me how to decode an Ogg Opus stream with those libraries or if it's not possible to?
C++
tia
Live streams are exactly like files. You shouldn't need to do any parsing, you should be able to pass the data to opusfile using the callback apis.
Opusfile has good http support internally, but unfortunately its POSIX-api only at this point so it doesn't include that functionality on Windows. I think it would be great if someone wanted to work on that.
Can you post your code?  It's easier to point out problems in existing code then to walk over the whole process and hopefully clarify something for you by accident.
#include "pshpack1.h"
struct OggHead
        char MagicNumber[4];
        BYTE Version;
        BYTE HeaderType;//bit 0=Segment Cont from prev page; bit 1=Beginning of stream; bit 2=End of stream
        unsigned __int64 GranulePosition;
        DWORD BitStreamSerialNumber;
        DWORD PageSequenceNumber;
        DWORD CheckSum;
        BYTE PageSegments;
struct SuperOggHead
        OggHead oh;
        BYTE SegmentTable[255];
#include "poppack.h"
void __fastcall TPlaybackThread::ProcPlayURL(Messages::TMessage & Msg)
// Plugin specific code snipped...
AnsiString Get="GET /"+URL+" HTTP/1.0\r\n";
Get+="Host: "+Host+":"+Port+"\r\n";
Get+="Server: "+Host+":"+Port+"\r\n";
Get+="User-Agent: Winamp (Experimental BogProg Opus Support)\r\n";
Get+="\r\n";
ProcessMessages();
AnsiString Res;
TWinSocketStream *pStream=NULL;
char *buff=NULL;
try
        cs->Open();
        if(cs->Active)
                buff=new char[65535];
                int sr;
                pStream = new TWinSocketStream(cs->Socket,Timeout);
                pStream->WaitForData(0);
                pStream->TimeOut=Timeout;
                pStream->Write(Get.c_str(),Get.Length());
                int tto=0;
                bool ready=false;
                while(tto<Timeout && !ready && !WantStop)
                        if(!pStream->WaitForData(100))
                                tto+=100;
                        else{ready=true;break;}
                while(ready && !WantStop)
                        sr=pStream->Read(buff,65535);
                        if(sr<=0)break;
                        if(!URLData(buff,sr)){break;}
                        if(sr<0)break;
                        ready=false;tto=0;
tto+=100;
                if(!ready)ErrorStop();
                delete pStream;
                cs->Close();
                delete [] buff;
}catch(...)
        try{if(pStream)delete pStream;}catch(...){}
        try{cs->Close();}catch(...){}
        try{if(buff)delete [] buff;}catch(...){}
        //try{}catch(...){}
        //try{}catch(...){}
        ErrorStop();
delete cs;
URLDataStage=0;
bool __fastcall TPlaybackThread::URLData(char * buff, int len)
switch(URLDataStage)
        case 0://Get the stream type, info and data start
        URLDataStreamHead(buff,len);
        break;
        case 1:
        URLDataStreamData(buff,len);
        break;
return !WantStop;
void __fastcall TPlaybackThread::URLDataStreamHead(char * buff, int len)
char *la=buff;
int lal=len;
if(URLPrev)
        char *ack=new char[URLPrevLen+len];
        memcpy(ack,URLPrev,URLPrevLen);
        delete [] URLPrev;
        URLPrev=ack;
        ack=URLPrev+URLPrevLen;
        URLPrevLen=URLPrevLen+len;
        memcpy(ack,buff,len);
        la=URLPrev;
        lal=URLPrevLen;
int ds=-1;
for(int i=0;i<lal-3;i++)
        if(la[i]=='\r')
                if(la[i+1]=='\n')
                        if(la[i+2]=='\r')
                                if(la[i+3]=='\n')
                                        //Found the http head end
                                        ds=i+4;
                                        URLHead.SetLength(ds);
                                        memcpy(URLHead.c_str(),la,ds);
                                        URLDataStage=1;
                                        if(la==URLPrev)
                                                int nl=URLPrevLen-ds;
                                                if(nl>0)
                                                        char *ack=new char[nl];
                                                        memcpy(ack,URLPrev+ds,nl);
                                                        delete [] URLPrev;
                                                        URLPrev=ack;
                                                        URLPrevLen=nl;
                                                else
                                                        delete [] URLPrev;URLPrev=0;
                                                        URLPrevLen=0;
                                        else
                                                int nl=lal-ds;
                                                if(nl>0)
                                                        memcpy(ack,la+ds,nl);
                                                        delete [] URLPrev;
                                                        URLPrev=ack;
                                                        URLPrevLen=nl;
                                                else
                                                        if(URLPrev)delete [] URLPrev;
                                                        URLPrev=NULL;
                                                        URLPrevLen=0;
                                        return;
if(URLPrev==NULL)
        URLPrev=new char[lal];
        URLPrevLen=lal;
        memcpy(URLPrev,buff,lal);
void __fastcall TPlaybackThread::URLDataStreamData(char * buff, int len)
char *la=buff;
int lal=len;
if(URLPrev)
        delete [] URLPrev;
        URLPrev=ack;
        la=URLPrev;
        lal=URLPrevLen;
        OggHead *oh=(OggHead *)la;
        if(lal>=sizeof(OggHead))
                if(
                        oh->MagicNumber[0]!='O' ||
                        oh->MagicNumber[1]!='g' ||
                        oh->MagicNumber[2]!='g' ||
                        oh->MagicNumber[3]!='S' ||
                        oh->Version!=0
                        ErrorStop();
                        return;
                if(lal>sizeof(OggHead))
                        if(URLPrev==NULL)
                                AddURLPrevBytes(la,lal);
                                la=URLPrev;
                        SuperOggHead *soh=(SuperOggHead *)la;
                        int nps=soh->oh.PageSegments;
                        int pl=sizeof(OggHead)+nps;
                        if(lal<=pl)
                                return;
                        for(int i=0;i<nps;i++)
                                pl+=soh->SegmentTable[i];
                        if(lal<=pl)
                                return;
                        DecodeOggPage(la,pl);
                        DelURLPrevBytes(pl);
                        la=URLPrev;
                        lal=URLPrevLen;
if(URLPrev==NULL)
        URLPrevLen=lal;
void __fastcall TPlaybackThread::DecodeOggPage(char * buff, int len)
struct SomethingToDoWithOpus
        char h[8];
OpusHead oh;memset(&oh,0,sizeof(oh));
SuperOggHead *soh=(SuperOggHead *)buff;
int ss=sizeof(OggHead)+nps;
for(int i=0;((i<nps) && (!WantStop));i++)
        char *seg=buff+ss;
unsigned char toc[255];memset(toc,0,255);
const unsigned char frames[48]={0};memset((void *)&frames,0,48);
short size[48];memset(size,0,48*sizeof(short));
int payloadoffset=0;
//The object OpusLib is dynamically loaded with the functions exported from libopus*.dll
int nof=OpusLib.opus_packet_parse(seg,soh->SegmentTable[i],toc,(const unsigned char * *)&frames,size,&payloadoffset);
DecodeOggSegment(seg,soh->SegmentTable[i]);
        int res;
        if(soh->SegmentTable[i]>8)
                SomethingToDoWithOpus *stdwo=(SomethingToDoWithOpus *)seg;
                if(
                        stdwo->h[0]=='O' &&
                        stdwo->h[1]=='p' &&
                        stdwo->h[2]=='u' &&
                        stdwo->h[3]=='s'
                        if(
                                stdwo->h[4]=='H' &&
                                stdwo->h[5]=='e' &&
                                stdwo->h[6]=='a' &&
                                stdwo->h[7]=='d'
                                if(URLOpusTags)
                                        //The object Opus is a struct that is dynamically loaded with the functions exported by libopusfile*.dll
Opus.opus_tags_clear(URLOpusTags);
                                        delete URLOpusTags;URLOpusTags=NULL;
                                if(URLOpusHead)
                                        delete URLOpusHead;URLOpusHead=NULL;
                                res=Opus.opus_head_parse(&oh,seg,soh->SegmentTable[i]);
                                if(res==0)
                                        URLOpusHead=new OpusHead;
                                        memcpy(URLOpusHead,&oh,sizeof(oh));
                                        if(CurPPL)
                                                CurPPL->Out->Close();
                                                CurPPL->Out->Open(48000,URLOpusHead->channel_count,16,0,0);
                                        int error=0;
                                        URLOpusDecoder=OpusLib.opus_decoder_create(48000,URLOpusHead->channel_count,&error);
                                        if(error)
                                                ErrorStop();
                                                return;
                        else
                        if(
                                stdwo->h[4]=='T' &&
                                stdwo->h[5]=='a' &&
                                stdwo->h[6]=='g' &&
                                stdwo->h[7]=='s'
                                if(URLOpusTags)
                                URLOpusTags=new OpusTags;memset(URLOpusTags,0,sizeof(OpusTags));
                                Opus.opus_tags_init(URLOpusTags);
                                res=Opus.opus_tags_parse(URLOpusTags,seg,soh->SegmentTable[i]);
                                if(res)
        ss+=soh->SegmentTable[i];
void __fastcall TPlaybackThread::DecodeOggSegment(char * buff, int len)
if(URLOpusDecoder)
//need 240ms worth of samples at 48khz per channel (x2 for DSPs)
int numofframes=11520;//48000 * 240/1000
int numofsamples=numofframes*URLOpusHead->channel_count;
int len=numofsamples*sizeof(opus_int16);
len*=2;//Extra padding for DSPs
short *nbuffers=(short *)new unsigned char[len];
len/=2;
int sr=OpusLib.opus_decode(URLOpusDecoder,buff,len,nbuffers,numofframes,0);
//At this point, opus_decode is only returning -4 for everything.
if(sr>0)
if(CurPPL)
CurPPL->Out->Write((char *)nbuffers,sr*sizeof(opus_int16));
        else if(sr==0)
                //Do nothing
else
ErrorStop();
delete [] nbuffers;
Hangon, I found a major issue in my code.  Must be a blonde moment.  I created a variable with the same name as the incoming function parameter name, "len" and passing it instead of the actual size of the segment into the decode function.  I changed it to "outlen" and now it's giving me samples, but not all the time.  It sounds sped up sometimes with different servers and it constantly cuts out after the initial incoming packet frame burst from the server.
I've made significant progress but I'm still having problems.  I'm parsing the OggS pages myself to retrieve the stream header and metadata and am sending all of the OggS segments (except the ones containing OpusHead and OpusTags) from those pages directly to the "opus_decode" function which sometimes returns the number of samples and sometimes returns -4 (OPUS_INVALID_PACKET).  And when the function does return with a sample count some of the audio sounds distorted or it introduces junk audio data.
I'm testing it with actual radio station servers (which aren't anywhere near as bad sounding but still introduces bad audio data here-and-there) and a file from a local webserver (that sounds absolutely fine when played back locally with the opuslibfile*.dll functions.
What am I doing wrong?  Am I supposed to treat the segments differently in certain situations?  Do I need to combine some?  If I do, how do I figure out when and how?
tia
Made a (quick & dirty) patch for opusfile, which opens http support on win32:
[attachment=7187:winsock.patch.gz]
This patch is built against the latest commit of the official git repository:
commit f2e27e4d1aa6e1b12b1af5bce166d1c3b10473dd
Author: Ralph Giles <giles@mozilla.com>
Date:   Wed Nov 14 11:05:32 2012 -0800
I used mingw-w64 toolchain on Linux.
Some tweak might be still needed to take care of OPENSSL_AppLink to get https support working.
In win32, user application of openssl is required to do
#include <openssl/applink.c>
or something, when openssl is compiled with OPENSSL_USE_APPLINK.
I don't know how it should be taken care of, from the library point of view (it must be done by user of libopusfile, since openssl always searches that function in executable module).
Well rats, that didn't work.
C:\Program Files\GnuWin32\bin>patch < winsock.patch
can't find file to patch at input line 5
Perhaps you should have used the -p or --strip option?
The text leading up to this was:
|diff --git a/Makefile.am b/Makefile.am
|index e572ed8..371d61e 100644
|--- a/Makefile.am
|+++ b/Makefile.am
File to patch: libopusfile-0.dll
patching file libopusfile-0.dll
Hunk #1 FAILED at 12.
1 out of 1 hunk FAILED -- saving rejects to file libopusfile-0.dll.rej
can't find file to patch at input line 23
|gure.ac b/configure.ac
|index 3133b7f..fe74c3c 100644
|--- a/configure.ac
|+++ b/configure.ac
File to patch:
Just as a side note, I tried using the libogg functions to parse the packets out of the stream instead of finding and parsing them myself.  It made it worse!  lol  When I sent the packets to the decode function sometimes the decode function would throw floating point errors and all the audio data it did return (when it didn't throw exceptions) sounded like uninitialized memory.
This patch is to be applied to the source code, not to the libopusfile binary.
Just so you understand, a patch is a text file containing source code that you can combine with other source code and then compile into a binary.  Thats why nu774 suggested using the minigw c compiler.
I didn't compile the libraries, I just extracted the DLLs from the archive.
The codec library archive I downloaded didn't come with the source code.  Where can get the appropriate source to download and will the patch for the source work on a 32bit compile?
Then you're using them wrong— but I can't tell how because you haven't described what you're doing.  This has worked for many other people without issue for Opus and for tens of thousands of developers for other codecs.
You really need to stop trying to parse ogg yourself unless you're willing to sit down, read the docs, read the Ogg RFC, etc.  It isn't complicated, but your guesses are guiding you incorrectly: Segments are not packets.  You need to pass full packets to libopus, which means that the segments must be reassembled.  Libogg does this for the caller.
...SNIP...
Found the Ogg RFC and found the key piece of information that I was missing.  I managed to do it half right by arbitrarily considering any segment that was 255 bytes long as incomplete, which was half correct.  The other half was segments that are zero bytes, which I didn't realize was legal, to indicate the end of a packet that was exactly modulus(len,255)==0 is actually complete.
