Topic: LAME 3.99 is out (Read 315781 times) previous topic - next topic
LAME 3.99 is out
Reply #175
Dropping LAME is a bad idea from branding standpoint. L is not a brand name, LAME is. This is way more important than any minor version.
Agree 100%.
LAME 3.99 is out
Reply #176
Just testing the latest 3.99.1 from Rarewares, there seems to be changes to the Lame header written, previously it was written LAME3.98  now (very quick glance) it seems to be 'L3.99r1' that is why no programs are picking up the lame header now.
Old Lame (after an info chunk):
New Lame
LAME 3.99 is out
Reply #177
Just by way of explanation, the problem relates to the desire to indicate that the release version is 3.99.1 as opposed to 3.99.
Under the old scheme it was not possible to indicate in the tag that it was 3.99 release, patch version 1, it was simply 'LAME3.99r', where 'r' indicated that it is a release version at a patch verion above '0', but the patch version number is not shown. If the release version was never at a patch version greater than '0', this was not an issue and the tag would read 'LAME3.99 ', but the change was to allow for the specification of what the patch version was above '0'.
const char *
get_lame_very_short_version(void)
    /* adding date and time to version string makes it harder for output
       validation */
#if   LAME_ALPHA_VERSION
#define P "a"
#elif LAME_BETA_VERSION
#define P "b"
#elif LAME_RELEASE_VERSION && (LAME_PATCH_VERSION > 0)
#define P "r"
#else
#define P " "
#endif
    static /*@observer@ */ const char *const str =
#if (LAME_PATCH_VERSION > 0)
      "L" STR(LAME_MAJOR_VERSION) "." STR(LAME_MINOR_VERSION) P STR(LAME_PATCH_VERSION)
#else
      "LAME" STR(LAME_MAJOR_VERSION) "." STR(LAME_MINOR_VERSION) P
#endif
    return str;
Above is the code that does the work.
So, as you can see, if the patch version is at '0', then the tag will read 'LAME3.99 ', as before, but if it is greater than '0' then it will read 'L3.99rn', where 'r' indicates that it is indeed a release version and 'n' = the patch version number.
Whether there may be a better way to do this is not for me to say, but knowing the patch version and, therefore, knowing if you are using the latest version must be of benefit.
LAME 3.99 is out
Reply #178
Programs can update to this new standard, but who knows any program which reads a lame header (even iTunes?) might be broken, and updates might not be forthcoming for all programs.
LAME 3.99 is out
Reply #179
I second spoon's concerns, improved standards should always be introduced with some measure of backward compatibility at least for a transition phase.
WavPack 5.7.0 -b384hx6cmv / qaac64 2.80 -V 100
LAME 3.99 is out
Reply #180
Simple fix why not write:
LAME3.991
instead of L3.99r1
Keep to the LAME3.99a for point releases
Also I echo the concern about dropping the LAME branding, having encoded by: L3.99r1  is confusing.
LAME 3.99 is out
Reply #181
Is this rule be "forever"? Is it good to remove "LAME" brand from the the "vendor" tag? Sorting is fun too (3.99r1, then 3.99a2, than 3.99b2, then 3.99r2, then 3.99a3... This is not trivial to sort, compared to L3.99.1r, L3.99.2a...). How someone who has never seen a LAME tag (this can happen!) can find that "L" or "L3.99" is the hint for "Lame" encoder? "Lame encoder" on Google redirects to http://lame.sourceforge.net, "L encoder" will never do it. I would have imagined something like "LAME3.99s" or "LAME4.00r"... (Why using .99 if you don't plan to rename it to .00 at some point? After 3.99.9, will the next one be 3.99.9.1?)
LAME 3.99 is out
Reply #182
The problem is that the LAME tag currently allows 9 bytes for the Version info. Without changing the size of this and causing more external software issues, no doubt, there has to be a compromise if the Patch Version Number is to be written. Previously, it wasn't written, so it wasn't an issue.
So, it really depends on whether people want the patch version number written into the LAME tag, or not.
LAME 3.99 is out
Reply #183
The next version is already designated as '3.100' which will cause a further problem!!
LAME 3.99 is out
Reply #184
Don't know if this is any help. When converting some FLAC to MP3 Lame 3.99.1 with XLD on OS X Lion and then playing them back with iTunes  under get info iTunes reports  "Encoded with LAME 32bits version 3.99.1 (http://lame.sf.net)"
The files play back gapless perfectly.
LAME 3.99 is out
Reply #185
Indeed. Since the maximum number of characters is 9 (9 bytes), for the next major version with a patch (LAME 3.100.1) one has the following options:
LAME31001
or
L3.100r1
Or something else in 9 characters.
XLD // ALAC // OGG VORBIS
LAME 3.99 is out
Reply #186
LAME31001
or
L3.100r1
Obviously, this is about priorities. Many people here including myself think that 'LAME' brand is way way way more important than squeezing in '.1'.
In addition there won't be 3.100 until it is released. It is not late to stop this silliness and reset the counter. Why not 4.0 already? Why not 5.0 if 4.0
is taken? Indeed dropping periods is much more harmless
LAME5000
LAME5001
LAME5101
LAME 3.99 is out
Reply #187
Why not just use a letter designation for now such as:
3.99a
3.99b
3.99z
This will give us 25 more revisions to fight about it!
Glass half full!
LAME 3.99 is out
Reply #188
3.99a
3.99b
3.99z
The 'a' and 'b' are already in use for 'alpha' and 'beta' versions.
LAME 3.99 is out
Reply #189
r,s,t,u,v,w,x,y,z seems vaguely familiar somehow, gives just 9 "revisions", the new scheme leaves one char extra.
At least foobar2000 has no problems displaying the new version tag.
LAME 3.99 is out
Reply #190
Please change the LAME header back to the old more compatible format. Many SW & HW players can now read the LAME tag and play files gaplessly, but apparently the changed header does not work with every player.
For example, here is how JRiver Media Center sees the 3.98.4 and 3.99.1 headers:
LAME 3.98.4
MPEG-1 Layer 3
236 Kbit VBR
44.1 Khz Joint stereo
Copyrighted: No
Original: Yes
Protected by CRC: No
Encoder: LAME
Gapless: Yes (576 start, 828 end)
LAME 3.99.1
MPEG-1 Layer 3
273 Kbit VBR
Copyrighted: No
Original: Yes
Encoder: L3.9
Gapless: No
I'd request to label the current version as 3.99r and then do the 5.0 release. (4.0 must be skipped because of known reasons.)
Then the LAME developes can create up to 5 x 99 versions before the encountering the next problem - 10.0.
i.e. 5.00, 5.01, 5.02 ... 5.99, 6.00, 6.01 ... and so on.
IMHO, this a very important thing and even if the 5.00 release does not contain any other significant changes, fixing this header problem justifies the new version number.
LAME 3.99 is out
Reply #191
I second Alex B's proposal.
lame3995o -Q1.7 --lowpass 17
LAME 3.99 is out
Reply #192
... And as already reported EncSpot Pro is one of the programs that do not recognize the new header. Encspot Pro is a sacred relic from the past, but I still use it almost every day.
LAME 3.99 is out
Reply #193
So that would also explain the trouble I'm having with gapless playback in iTunes and my Ipod?
3.98.4 plays perfectly.
LAME 3.99 is out
Reply #194
I just tried the current Winamp build. It can be added to the list of victims. It does not recognize the encoder delay and padding values from the LAME v.3.99.1 header.
LAME 3.99 is out
Reply #195
Simple fix why not write LAME3.991 instead of L3.99r1
I proposed this awhile back, on a thread wishing that Lame 3.98.4 could be distinguished from 3.98.2 in the header info (as it was, both versions are denoted in the header as LAME3.98r).
Similarly, Lame 3.90.3 just shows up as LAME3.90.  with nothing after the decimal.
I think for now, dropping the decimal and making it LAME3.991 is the best solution, to keep the header consistent with previous versions.
God kills a kitten every time you encode with CBR 320
LAME 3.99 is out
Reply #196
I can't say for the iPod but with iTunes 10.5.1 on OS X MP3's created with XLD using LAME 3.99.1 play back perfectly gapless and play back perfectly gapless on the Apple TV 2
LAME 3.99 is out
Reply #197
It's also worth noting that this is only an option as long as the plans for the next version number are changed. Since 1999, the sub-version numbers have always been limited to a maximum of two digits (LAME 3.01, 3.22, 3.96.1, etc.), and since that is the case, removing the period before the final number works, as it's understood that the sub-version can only be two digits. If 3.100 is released, it will forever eliminate the possibility of removing the final decimal point, as it won't be clear whether the sub-version is two or three digits in any given future release without looking at the ChangeLog.
If the developers are still opposed to moving beyond LAME 3.x releases, they could always switch to numbering the releases in hexadecimal. They could then release LAME 3.9A - 3.FF (while still using lowercase letters "a" and "b" for alpha/beta) before having to deprecate the 3.x series.  (Yes, this is said in jest, but the sad thing is it would probably be less disruptive to software compatibility than removing the "LAME" string from the version identifier field.) I agree with those who have said that it's preferable to remove a decimal point to fit in full version numbers than to shorten the "LAME" name to "L", so I hope the developers can find a solution which satisfies their desire for version specificity while preserving software compatibility.
LAME 3.99 is out
Reply #198
And yet, two posts earlier?
LAME3.991
instead of L3.99r1
Then use LAME3100x for 3.100 (assuming version 3 lasts forever!). Something tells me that the one-, three-, and one-digit limits for major version, minor version, and revision numbers aren’t going to be exhausted any time soon.
Really, with how simple this seems, I don’t understand the amount of discussion that has come out of it!
LAME 3.99 is out
Reply #199
Everyone must keep in mind that we are speaking about a well hidden code that resides inside the LAME header. It has very little importance to the users. It does not necessarily need to be exactly identical to the actual LAME revision number. The most important thing is to keep the LAME header compatible with the existing player implementations. Thanks to LAME, gapless MP3 playback is now possible with many SW and HW players. There is no reason to make that anyhow more difficult.
However, it would not harm to use a string that indicates the actual version number if the code is 100% compatible.
In my opinion the idea to use 3.991, 3.992, etc or include additional letters like 3.99C would cause confusion and the road would dead end at 3.1000 or 3.100C. As already said, a sensible thing to do would be to proudly start a new numbering scheme from 5.0. Then the LAME developers could decide later if they want to simply use the numbers chronologically like 5.00...5.99, 6.00...6.99 and so on -- or continue releasing minor "point" versions like 5.0.1, 5.1.3, 6.2.5, etc
For comparison, the Firefox version number has quickly advanced from 3.6.xx to 8.0 in less than one year after the developers changed the numbering logic.
