Topic: ELPlaylist: How to change the font of my "playlist"? (Read 3089 times) previous topic - next topic
All the text here basically
I would like to change that font to better match the theme of my desktop but I can't find where exactly this is controlled from. Help appreciated.
It should be possible to change the font in the settings of the playlist view plugin. Judging from the screen shot, it is a third-party playlist view though I can't tell which one. As such I cannot provide you with more detailed instructions.
the component being used is ELPlaylist and it doesn't have columns like standard playlist viewers. the first place to check is by right clicking>settings>style tab> and there is a default font button. try changing that and see what happens.
if that doesn't work, you should then check the script tab. it's possible to set the font "on the fly" so it's possible the code is littered with references to a $font function. they should be fairly easy to spot and you can experiment with changing the text to match the font you want to use. BTW, there are 3 tabs under scripts you'll want to check "track list", "group header" and "per second". all fairly self explanatory i think.
Thanks. I actually was able to change it by going to Settings > Field Definition. Very simple.
