Topic: How many bits is 128 "kbps"? 128*1000 or 128*1024? (Read 8091 times) previous topic - next topic
Hi everyone,
Does "128 kbps" for AAC mean 128*1000 bits per second, or 128*1024 bits per second? What's the right way?
http://en.wikipedia.org/wiki/Bit_rate
Note that, unlike many other computer-related units, 1 kbit/s is traditionally defined as 1,000 bit/s, not 1,024 bit/s, etc., also before 1999 when SI prefixes were introduced for units of information in the standard IEC 60027-2.
Ok, so it's 1000!
In general, when talking about transmiting data, units are expressed in SI ( 1000 ). That also applies to Internet speeds (ADSL, 3G...).
That said, Microsoft used 1024 as kbits in their wma codec.  (which translates in 131072 bits for its 128kbps setting).
The reason why computers have historically used 1024 is because of its usage of binary data ( 2^10 = 1024). This, then, defined the addressable space for data, which means: If i have x bits, i can have 2^x different addresses in which to store data.
The most recent effect of this is the reason why one needs a 64bit Operating System if needing to use more than 4GB of RAM (let's forget about the fact that it is more like 3.5GB in practice) 2^32 = 4GB in 1024, or 4.29GB if expressed in 1000.
