Topic: EAC Sound Quality (Read 4591 times) previous topic - next topic
EAC Sound Quality
Just played some of my music ive ripped using EAC...the sound quality is outstanding!
As some of you know I was using WMP9 to rip, all I can say to the people that suggested I use EAC is, Thank You.
Im only using a SB Audigy and the sound quality easily rivals my NAD 521i CD player, I actually think it beats it!
Clarity is excellent and there is so much more bass than when I ripped with WMP.
It just all together sounds more "hifi"
Im just going to leave the files as wav as space is not an issue.
Thank you again
EAC Sound Quality
Audio ripped with EAC (in secure mode) from CDDA to 44.1 kHz 16 bit stereo wav is not better or worse than the original, it's just identical.
You could consider lossless compression of your wav files to enable you to add Artist/Title... info tags to your files, saving some 30 upto 50% storage space and adding some extra file integrity checking, while keeping exactly the original digital quality. Read along the lossless forum section to learn more.
EAC Sound Quality
I know its not better than the original.
But it is better than files ripped with WMP & at least as good as what my CD player reproduces.
EAC Sound Quality
Were you ripping CDs to WAV with WMP?  If so then sound quality should have been identical to the original recording.  EAC is better because of its secure ripping mode; this ensures proper rips of audio, especially important if the CD has some minor marks or scratches.
If you were indeed ripping to WAV with WMP, and you are also ripping to WAV with EAC, they you definitely would not be hearing “much more bass”.  Perhaps you were in reality ripping from CD to WMA with WMP.(Please forgive all these abbreviations)
EAC can give you exact copies.  WMP may fail at giving you a secure rip in terms of defects on the disc, or due to a problem with your drive.  It will never take away bass, nor will EAC make music sound “more betterer”
You are experiencing the Placebo effect
EAC Sound Quality
I was ripping to WMA lossless with WMP, but surely if it is lossless then it is as good as wav?
Maybe it is the fact that I was not ripping to wav.
Whatever the reason I can garuntee you that the SQ is better ripping to wav with EAC than ripping to WMA lossless with WMP9.
One other thing that may be playing a part is that files ripped with EAC are louder at a given amp level than the WMP9 files are.
Can you determine the reason from that? Its not the Placebo effect, its not subtle enough. There is a big difference.
EAC Sound Quality
whatever crappy WMP / WMA has done to your copies,
by EAC you are simply safe to get the best out of your CDs, the original.
I recommend you to try www.wavpack.com , wavepack hybrid for storing your waves lossless.
That will save you already a lot space.
perhpas wavepack-hybrid-lossy files are the first step for you into world of lossy compression and still having transparent audio in archival quality.
Or go for MPC,
MOD:* No links to or names of ripping groups please.
EAC Sound Quality
  Do you play both type of files (WMP9 lossless and EAC WAV files) on the same player? Or you
  play WMP9 files with WMP and WAV files with Winamp, ...?
  I don't have/use WMP9 but I almost definitely claim that  the differences in *sound quality*  is totally
  caused by your player's DSP effects.  Try to play your files with a player other than WMP and
  make sure all DSP effects are off. I remember that WMP8 had some *destructing* DSP effects
  enabled by default. I guess the DSP engine for playing WM files are different with those of other
  file types. (Like what Winamp's equalizer do with MP3 files and other file types)
  Mehrtash
EAC Sound Quality
The volume of the ripped files depends on the "normalization" option. It must be disabled in order to get a lossless copy.
EAC Sound Quality
I used WMP9 to play both file types..and all DSP & EQ are turned off.
I am also not using normalisation.
It is strange, the only conclusion I could make so far is that the difference was because I was ripping to WMA and not WAV..but this would mean that it is in fact not lossless, however you asure me that it is...
What ever the reason, the files ripped with EAC are very noticably better than the ones ripped with WMP9..so ill stick to using EAC.
Thanks again to everyone.
