Topic: Convert stereo to 5.1 DSP (Read 8426 times) previous topic - next topic
Hey people so I was wondering if there is a(or will be) a DSP that will Convert stereo to 5.1? There is one that converts stereo to 4 channels and from 5.1 to stereo but no stereo to 5.1. I would really enjoy one.
I've had good results with foo_channel_mixer.
You can use the matrix mixer.
http://skipyrich.com/wiki/Foobar2000:Matrix_Mixer
or the channel mixer
http://skipyrich.com/wiki/Foobar2000:Channel_Mixer
or the FreeSurround dsp
http://www.hydrogenaudio.org/forums/index....showtopic=52235
With the VST adapter you can use the V.I STEREO TO 5.1 CONVERTER VST PLUGIN SUITE
http://stevethomson.ca/vi/
There are also professional upmix plugins that can be used with the vst adapter.
Another upmix plugin can be found here:
http://www.devir.de/temp/foo_dsp_upmix.zip
Not all upmix dsp use the LFE Channel but you can combine the channel mixer with every dsp in in order to get the LFE channel.
