Topic: BASSMIDI MIDI synthesiser for Windows XP/Vista/7 (Read 330869 times) previous topic - next topic
Reply #275
Some Roland and Yamaha official demos are very good, these files can demonstrate BASSMIDI's GS/XG compatibility as well.
http://www.sendspace.com/file/pwcw2v
OXYCUTE.MID (XG) is very interesting, changing foo_midi's sample rate will change the filter/resonance response dramatically. Other two files are GS.
Reply #276
added configurable sound buffer lengths for xaudio2 output.
should fix some issues.
Reply #277
With the default buffer length (100), I get an APPCRASH error in faulty module XAudio2_7.dll (version 9.29.1962.0). Setting the buffer to 64 or less apparently prevents the library from crashing.
[Win7-64]
Reply #278
Same here but I don't really care because I have no problem with low latency (10). This level of latency is comparable to running VSTi in DAW. Good job, thanks!
Reply #279
Seems to work OK here  I had a few 'inital loading' stutters, but not that many after the samples were completely loaded.
I didn't really notice any difference though no matter where the buffer slider was set... does this Xaudio2 thing apply to me? I was really excited about the possibility of real low latency.
Reply #280
Seems then your system prefers the DirectSound driver, or it must hate xaudio2?
Did the build just before the x64 changes work for you?
Reply #281
I'm not sure if you were reply to me (or the previous posters), mudlord.
Anyhow, I had no problems with the versions before the x64 changes.
Reply #282
Please try http://www.mudlord.info/bassmididrv/bassmididrv.exe again. I dropped out the floating point XAudio2 support, since a kind WikiPedia has informed me that it wraps to DirectSound on Windows XP, so probably won't work with floating point output there either.
Just to reiterate, the problems you are experiencing are more likely due to me bypassing BASS as an output method and using my own output interfaces instead.
Reply #283
Seems to be working OK  It might be my ears, but I think there's a little less stuttering when first playing a MIDI file and the initial samples from the SoundFont are loaded in.
I still don't hear any difference with the buffer slider though (I'm on another PC that I've been testing the BMD driver on, so I'm comparing the BMD with the MS SoftSynth's latency).
(Edit) P.S. Just a-wondering: Does the BMD still use BASS.DLL and BASSMIDI.DLL (I'm assuming so)?
Reply #284
yes, it still uses bassmidi.dll as the synthesiser. and bass.dll as the base.
Reply #285
I have recently downloaded the latest version pf BASSMIDI and I am having troubles using this with DooM's MIDI music. Specifically with the music skipping, fading out, and/or stuttering (mostly on note-heavy parts like guitar riffs or when there is lag in the game). Using the XAudio2 buffer length slider helps a little bit but theirs still slight problems. Is there any way you all can fix this? My audio card is a Realtek AC97 Audio and a computer with 1GB RAM if it helps.
Reply #286
Actually, I have just found out these problems pertain to just listening to MIDI music in general.
Reply #287
OS? CPU?
Reply #289
I uploaded a new version with DirectSound buffer changing. try that?
Reply #290
It helps quite a significant bit. Although there's still bits of stutter/cutout when the synth first starts up (like at Doom/Doom II's title) but once it gets going, it's sounds flawless. Just that wee hiccup.
I have both buffer sliders at max and the sync interpolation box is ticked
Reply #291
Same here... sliding the DS buffer up, all stutters are now gone (short of the initial load when the MIDI starts, which I've experienced in almost all of the other older drivers as well... so no biggie).
P.S. NOW I can actually hear a difference in latency with the DS slider (I noticed no difference with the XAudio2 slider in all of the versions).
Reply #292
Yay. >_>
Reply #293
I checked the driver for Windows XP 32bit.
-Missing Tracks on Playback ( windows prof. 64bit 7 works ) example MIDI Human.MID Warcraft II 047 for example ( Timpani ) missing
Reply #294
Which WarCraft II MIDI file are you refering to? My track listing is:
INTROGM.MID
HWRRMGM.MID
HUMAN1GM.MID
HUMAN2GM.MID
HUMAN3GM.MID
HUMAN4GM.MID
HUMVGM.MID
HUMDTHGM.MID
OWRRMGM.MID
ORC1GM.MID
ORC2GM.MID
ORC3GM.MID
ORC4GM.MID
ORCVGM.MID
ORCDTHGM.MID
...which has no MIDI named only "HUMAN.MID".
Reply #295
Human1GM.MID for example. In windows 7 i can hear all tracks. In windows xp the timpani 047 is not present and sweep pad 095 maybe. (tested with v3.19 and v3.17)
Reply #296
I just tested it under Windows XP (with an older version 3.16), the timpani and sweep pad sounds just fine.
Are you _sure_ that it's not the SoundFont that you're using/loading?
Reply #297
LOL I found out what it is. I just forget to loading the 4th soundfont bank XD. Now seems to work. Sry for that
Reply #298
Looks like Windows 8 loathes MIDI. I'm trying to set the default MIDI device and it always reverts back to the crappy Windows default. I've tried setting the default device through BASSMIDI, Creative Soundfont Bank Manager, and Putzlowitsch's Vista MIDI Mapper Control Panel. It just doesn't save. Any tips?
Reply #299
Ask kode54. IIRC he has Windows 8 installed, im stuck on 7.
