Topic: Cyberlink Audio Decoder+MPC-HC (Read 5048 times) previous topic - next topic
Hi Friends as Mr.Eevan suggested I use DTS NEO6 upmix in MPC-HC (Cyberlink Audio decoder 8),now,the problem is,
Eveytime I open MPC-HC I have to set the speaker config to 5.1 and Effect to DTS NEO,when i reopen MPC-HC again,settings are lost
what shall i do to make MPC-HC remember 5.1 and DTS NEO6...
(i have attached screen shots)
Thanks in advance
Joseph sanjeevi Manickaraj
"God is in details"
I think you're screwed, unless you can figure out something like this (hit the links there), but for the Cyberlink decoder.
We basically had the same problem with the Arcsoft (Total Media Theatre) blu-ray audio decoder, which is the only one that people can currently use for full DTS-HD decoding. It was reverting to stereo and default settings when closing the player. The fix is a bit complicated, and very specific. It won't work with Cyberlink, but perhaps you can figure out something if you know/try hard enough.
