Topic: TAK 2.1.0 - Beta release (Read 9899 times) previous topic - next topic
Beta release 1 of TAK 2.1.0 ((T)om's lossless (A)udio (K)ompressor)
It consists of:
- TAK Applications 2.1.0 Beta 1
- TAK Winamp plugin 2.1.0 Beta 1
- TAK Decoding library 2.1.0 Beta 1
The final release will additionally contain the SDK.
Download:
Download link removed. Beta 2 has been released.
What's new
This release adds a new user selectable codec, which significantly improves the compression efficiency of LossyWav-processed files. Files compressed with this codec can not be decoded by earlier versions of Tak, Takc, in_tak and tak_deco_lib! The default codec remains unchanged und is therefore backwards compatible to TAK V2.0.0.
Improvements:
- New additional codec that improves the compression efficiency of LossyWav-processed files by up to about 2 percent (relative to the original file size) for the quality setting -q5.0 (less or more for other settings). It supports any block size that is an integer multiple of 256 samples. Please don't specify the -fsl512 option at the command line. While this was required for the standard codec, it will severily hurt the performance of the new dedicated LossyWav-codec. Another advantage of the new codec: You will not loose much compression if LossyWav deceides to remove no bits, as can happen with for instance some low amplitude files with little signal complexity. Simply specify -cLW at the command line to activate the new codec. Earlier it wasn't advantegous to use presets higher than -p2m when encoding LossyWav-Files. That's no longer true, you may even benefit from -p4m.
Modifications:
- The file info function now also shows the name of the codec used to compress the file. The new codec is called "3 LossyWav (TAK 2.1)".
- Moved the verify-option from the details-dialog to the general compression options dialog.
Known issues:
- If you use pipe decoding and the application reading the pipe is beeing terminated before the whole file has been read, TAKC may get into an endless loop and has to be manually killed with the task manager. I don't think this is a big issue but i will try to fix it in one of the next versions. BTW: Big thanks to shnutils for testing the pipe decoding!
- There seem to be some compatibility issues with pipe decoding to some other applications ("crc1632.exe" has been reported). I will try to fix it in the next release.
Results
Here are some compression results for my primary test corpus. First a comparison of different codecs and LossyWav quality settings.
Comparison of Codecs
         FLAC 1.2.1 TAK 2.0    TAK 2.1    Advantage over
         -8         -p2m       -p4m       FLAC       TAK 2.0
-q0.0    20,61      19,07      17,25       3,36       1,82
-q2.5    27,43      25,95      23,93       3,50       2,02
-q5.0    33,26      31,78      29,62       3,64       2,16
-q7.5    38,79      37,28      35,03       3,76       2,25
Compression in percent relative to the original file size.
Sometimes LossyWav deceides not to remove any or only very few bits from a file. Then it can happen, that the LossyWav-Mode of the codec is less efficient then the standard mode. To test this i used a worst case scenario. I compressed my test corpus with TAK's standard (-cStd) and LossyWav (-cLW) codec, but without prior processing with LossyWav.
Compression of unprocessed files
         TAK 2.1    TAK 2.1
         -cStd      -cLW       Loss
-p0      58,74      58,99      -0,25
-p1      57,84      57,73       0,11
-p2      56,90      57,00      -0,10
-p3      56,36      56,44      -0,08
-p4      56,02      56,06      -0,04
-p4m     55,88      55,97      -0,09
Since the presets of the 2 codecs are constructed slightly different, they are not directly comparable. But i think it is safe to say, that the average loss is usually not bigger than about 0.1 percent.
Encoding and decoding speed are close to the standard codec, therefore i conducted no tests.
Beta testing
The beta version has already gone through extensive testing performed by my automatic scripts. Please try the beta release and report any bugs in this thread.
Thanks for testing and have fun
Thomas
Nice that TAK is still alive.
Any plans for a Linux version?
how about the planned flac merger?
Thomas,
Many thanks for your efforts to make lossyWAV processed audio compress more efficiently!
n.b. It should be noted that these tests were carried out using an unreleased beta of lossyWAV which allows the duration of the codec-block to be changed from the default 10msec. This beta (or the one after it....) will be released in due course.
A good release, TAK still very strong in efficiency and uniquely devoted to its own agenda.
UNIX question: I was led to believe TAK runs uneventfully under WINE, correct my assumption.
FLAC merger question: The main argument for a merger was to make the 'ultimate' lossless format (the better-known FLAC combined with TAK proficiencies). It seems a universal lossless format fails to garnish much public interest, as proven by WMA lossless, ALAC and (ultimately) MPEG-4 ALS.
I support TAK having the ability to handle the area between lossless and lossy. It makes sense to compromise for space-savings with minimal artifact-induced side-effects.
I do have one question of my own for TAK:
The OpenCL FLAC (previously CUDA FLAC) totally rules in compression speed. It was intimated that other lossless codecs could not become parallel by design. Is this true with TAK as well?
Thanks (again) Thomas for making the holidays merrier!
Well, i have learned from the past...
I will not promise anything and only announce new features which i have already begun to work on. Development will proceed silently unless i need support from the users.
The results above are for the default block size of 512 samples. 256 surely would further improve the compression.
Nice to hear from you!
TAK's design is equally suited for parallel processing. When it comes to the processing of 24-bit-audio, it's even better suited than FLAC, because it will still work with 16*16=32 bits multiplications while FLAC usually has to switch to a higher resolution, which currently isn't supported very well by CUDA.
Currently i prefer to improve TAK's encoding speed by multi core support and some more assembler optimizations. Multi core support is planned for the next release (i just bought a second hand cpu to have better testing oppurtunities).
I have spend the last days working on assembler optimizations. Since TAK is already extremely optimized, there is not much to gain this way. Only the SSSE3 instruction set yielded some notable improvement of about 10 percent. Since SSSE3 (note the three 'S')  isn't supported by AMD, only intel users will benefit from those optimizations.
Possibly i will release another beta with those optimizations. This way TAK 2.1 will also be of interest for a lot more users (who don't use LossyWav).
...Only the SSSE3 instruction set yielded some notable improvement of about 10 percent. Since SSSE3 (note the three 'S')  isn't supported by AMD, only intel users will benefit from those optimizations.
Does this affect decoding too?
For encoding I like the idea of using multiple cores to encode the same file, this way HDD seeking can't be as much of a bottleneck as when I use more instances of the same encoder to utilize more threads.
(And thanks for thinking of us who don't use lossywav )
No. From my experiences with the encoder tuning i don't think SSSE2/SSSE3/SSSE3 would help much, but maybe i will try it sometime.
Sorry, i  was very insensitive...
Currently the new tuned encoder is undergoing  my comprehensive validation procedure. This will take several hours. Then there will be a Beta 2 release.
There was discussion a couple months back either here or on XMPlay's forums that using SSE/etc optimizations may actually add a lossy aspect to the decoding process (since it takes processor-specific "shortcuts"). Is there any truth to this?
Fine with me, decoder is fast enough
I'm still happy that SSSE3 in my CPU gets some use. I'm such a geek
A bit too many S' though
And I don't feel hurt  I'm just afraid of lossywav, as usual (even though it's just another lossy thing and I actually listen lossy w/o any problem)
.... could you please clarify that statement?
This depends on the specific implementation. In most cases it is possible to obtain the same accuray with an SSEx implementation if you use the same algorithm and data types. There is one exception: While SSE2 and above support the same 64-bit floating point format as the FPU, an FPU implementation can yield more accurate results, because it internally is working with 80 bits. But if this does matter depends on the algorithm.
Oh, we exchanged privs about it a year ago or so. I fear getting lossy things disguised as lossless. I hope their size will maki it apparent
Other than that, even I'd use it, except that I'd be afraid of mixing the files with true lossless ones. My memory is not perfect, you know
(On the top of that you also wrote how easy to spot these files. Thanks for reminding me again!)
