Question about HDCD
Reply #9 – 2010-08-18 18:36:04
Thanks for your answer, I also noticed that HDCD are 6 dB lower in volume, so increasing the volume by 6 dB in the 24 bit file before the conversion with dithering to 16 bit make sense Not all are. Imho decoding and dithering back only is worth with HDCDs using real Peak Extension. bryant mentioned it. On some it is shown as used but it it doesn´t change the peaks, at least the parts i checked. ? I've never seen that. Anywhere I've seen PE used, there was an obvious difference in a waveform comparison to non-decoded (actual 'extended' peaks, not just renormalization) Think it was on my Oldfields. Sometimes the "low level range extend" kicked in but never the "peak extend" ? Here's how mine read.Mike Oldfield 1974 - Hergest Ridge 01 - Hergest Ridge Part One.wav HDCD detected Peak extend : Enabled permanently Mike Oldfield 1974 - Hergest Ridge 02 - Hergest Ridge Part Two.wav HDCD detected Peak extend : Enabled permanently Mike Oldfield 1975 - Ommadawn 01 - Ommadawn Part One.wav HDCD detected Peak extend : Enabled permanently Mike Oldfield 1975 - Ommadawn 02 - Ommadawn Part Two.wav HDCD detected Peak extend : Enabled permanently Mike Oldfield 1990 - Amarok 01 - Amarok.wav HDCD detected Peak extend : Not enabled HDCD.exe only samples the first few seconds of a track, to gather info. IIRC, HDCD encoding actually stops for the final 'Horses' part of Ommadawn.
