Topic: Foo_msn (Read 237575 times) previous topic - next topic
Foo_msn
Reply #75
the one HERE works with foobar v0.9.5 and Live messenger 8.5.1302.1018
supports unicode tags too!! yay!
Trends UD-10 | Pioneer VSX-1015TX | Energy RC-10 | AV123 x-sub
Foo_msn
Reply #76
And simply doensn't work for me...
Is there any config needed?
Foo_msn
Reply #77
it works perfectly fine for me. you might want to try AMIP if you can't get this working.
Foo_msn
Reply #78
Samurro, you need to take the downloaded dll and copy it to C:\Program Files (x86)\foobar2000\components\ if you're running a 64-bit Windows OS...for a 32-bit Windows OS you need to copy it to C:\Program Files\foobar2000\components\ and you should be able to get it to work. It worked without a hitch when I did that.
Foo_msn
Reply #79
Thats a cool plug-in actually, thanks guys.
Foo_msn
Reply #82
For everyone who has problems: When I first tried it, it didn't work. But that's because i had disabled "Show song information from windows media player as a personal message".. Maybe that's your problem too, just a thought.
Foo_msn
Reply #83
Im sorry if this thread is a little old, but would it be possible for anyone to recompile this component with the newest SDK?
edit: oops, this is strange...
Im talking about foo_msnalt (not foo_msn), because the link from the wiki points to this thread...
Just to clarify
Foobar2000 @ Onkyo SE-90PCI @ Sennheiser HD595 :)
Foo_msn
Reply #85
Just to clarify
I'd also like an update to this component. The source code is available and msn_wlm isn't as good (it displays a song as 'now playing' even if it's just paused). thanks.
Foo_msn
Reply #86
well, foo_wlm indeed does show the song on WLM when paused, but there is a "(Paused)" tag at the end. It doesn't really matter to me, IMO...
but if u really want foo_msn style plugin (or foo_msnalt), there is a link to a modded foo_msnalt in the foo_wlm thread:
http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=66346&view=findpost&p=602143
srsly, someone ought to put this up in the wiki....
Foo_msn
Reply #87
foo_msnalt.dll doesn't seem to work with foobar2000 v0.9.6 on Vista Ultimate 64-bit.
Can we have a fix for it?
Foo_msn
Reply #88
+1
a+, =)
-=Finiderire=-
Configuration :
Foobar2000 v0.9.6.3 + Foo_msnalt # Last updated: 2006-04-10
Windows Vista 64 SP1 Ultimate
Foo_msn
Reply #89
You can download a version build with latest SDK here.
Foo_msn
Reply #90
Hi, is there an MSN plugin capable of submitting trackinfo from streams (i.e. not the item's name but the currently playing track).
Foo_msn
Reply #91
foo_msnalt started to annoy Peter because of somewhat frequent crash reports from it. I tried to fix what I could and added stream title display support. Download version 2.41.
Foo_msn
Reply #93
Use foo_wlm instead.
Foo_msn
Reply #96
Hi, is there a variable or a way to show the name of a streaming radio station as well as the artist and song currently playing?
eg. Radio 1 (blah blah) - Radiohead - Creep
PS (I switched to using this today, I got tired of AMIP wrapper restricting the amount of characters in the title and struggling to work it out properly).
Foo_msn
Reply #97
Hi there,
this being my first post
Im having trouble running the plugin, it doesn't dsplay the info at all.
restarting Foobar and WLM did not help until now.
Win 7 64bit
fb 1.0
wlm 2009
wlm not 1.1.3
