Hydrogenaudio Forums
Hosted Forums => foobar2000 => 3rd Party Plugins - (fb2k) => Topic started by: shaneh on 2005-02-17 14:09:51
Title: Foo_msn
Post by: shaneh on 2005-02-17 14:09:51
Edit: See http://www.myplugins.info (http://www.myplugins.info) for updated version. 2.2
Now supports Messenger 7.0.0632 & 7.0.0777
Updated version now has support for configuration.
Title: Foo_msn
Post by: aurelio on 2005-02-17 14:44:04
Hi shaneh,
the zip archive seems to be corrupted.
Please take a look at my other post also: http://www.hydrogenaudio.org/forums/index....ndpost&p=274509 (http://www.hydrogenaudio.org/forums/index.php?showtopic=31486&view=findpost&p=274509)
Bye
Title: Foo_msn
Post by: shaneh on 2005-02-17 16:12:51
Ok, I fixed up the pause/resume problem.
I think it would be nice if someone made a nice GUI, or otherwise made it configurable for the formatting, like I have for Toaster.
Hopefully this .zip wont be corrupt.
Title: Foo_msn
Post by: aurelio on 2005-02-17 17:52:12
Thank you shaneh, so fassst!
Plugin works 100%.
I experienced zip archive corruption again, but maybe guilt of win xp internal zip manager. WinRAR opens successfully.
Title: Foo_msn
Post by: wortels on 2005-02-17 18:06:22
Zip is corrupt for me. Try using http://7-zip.org/ (http://7-zip.org/)
Title: Foo_msn
Post by: alexp2_ad on 2005-02-17 18:52:37
WinRAR wouldn't open it for me but using Tools > Repair archive proved successful.
Title: Foo_msn
Post by: Bad Seed on 2005-02-17 19:05:00
No problems for me extracting the file with PowerArchiver .
Title: Foo_msn
Post by: alexp2_ad on 2005-02-17 19:27:37
BTW, somehow I forgot to say... thanks for this class plugin!
Just applied the Mess Patch from mess.be to switch it to Artist - Track and now I'm set to go!
Thanks again for a great plugin!
Title: Foo_msn
Post by: Bad Seed on 2005-02-17 20:10:46
Hello again. I think I'm missing something , I extracted the file in the zip to the Components folder and I turned on the "What I'm listening to" feature in MSN Messenger but I only get <Unknown Title> - <Unknown Artist> .
All my mp3 are correctly tagged. I need to configure something? .
Cheers and thank you in advance.
EDIT: I'm using Windows Me. Maybe this feature is only available for Windows XP/2000?
Title: Foo_msn
Post by: wortels on 2005-02-18 10:16:10
For anyone experiencing zip corruption
Title: Foo_msn
Post by: 1for-matik on 2005-02-18 11:23:35
New problem, i have saw that the plug-in doesn't work with stream tag...
The plug-in shows the name of the radio ( like : "? - Frequence 3")
When i'm deleting the name of the radio, it shows "? - ?"
PS: I'm french, sorry for my english...
Title: Foo_msn
Post by: shaneh on 2005-02-18 12:40:44
Thats because it just uses %title% and %artist% for the track. What is needed is a configuration where you can specify the tag particulars that you want. I do this with toaster with (basically):
$if(ishttp, %httptitle%, %tracktitle%)
You would need to modify the source to either make this configurable, or put in the appropriate tags required for foobar to pick up the correct info.
Title: Foo_msn
Post by: AssiuM on 2005-02-19 16:37:36
thank you for the plugin !
I had to repaired the archive with winrar, attachment is the repaired version
Title: Foo_msn
Post by: shaneh on 2005-02-20 13:27:19
Note that the Toaster plugin Ive posted in this forum has the ability to update MSN titles too. It will also let you format the titles to be updated.
Its possible to configure toaster to not show the popups but still update the msn titles if thats what you want.
Title: Foo_msn
Post by: aurelio on 2005-03-05 12:12:00
Hi Shaneh,
I'm using MSN Messenger 7.0.0632 and foobar with your latest foo_msn plugin (got from http://www.myplugins.info/) (http://www.myplugins.info/)).
It's good it now displays artist name first.
When I click on the title in Messenger window, MSN Music window appears as in the screenshot. The album name is right, but the artist seems to be got from the track title...
I tried foo_toaster 0.1.6 and it works correctly instead.
Greetings and thanks for your work.
Title: Foo_msn
Post by: shaneh on 2005-03-05 14:21:07
hmmm, i mustve put it the wrong way 'round. If I fix it, the artist name and title will be reversed again, the same as in WMP.
This is customizable, but foo_msn doesnt have this, use foo_toaster for customisation. You should not use foo_msn with foo_toaster together. I dont see why anyone would want to click on it anyway.. ?
Title: Foo_msn
Post by: aurelio on 2005-03-05 15:48:17
Yes I noticed, they are reversed with WMP and iTunes.
With both foo_toaster (by customization) and foo_msn I have the good order (artist - title) displayed, but: foo_toaster sends the artist name in the correct way (see following screenshot); foo_msn does not (see screenshot in my previous post).
If possible, I would like to keep using foo_msn because I don't need the (nice!!) features of foo_toaster for now.
I agree it's useless you click on your own songs, but sometimes I want to click on the ones of my contacts to get some info.
All things considered it's not a serious issue - album title is obtained correctly so I can get info in other ways.
Thanks again!
Title: Foo_msn
Post by: shaneh on 2005-04-17 16:09:36
I have now updated the plugin to support some basic configuration, as well as made the source code public again.
Its available at http://www.myplugins.info (http://www.myplugins.info)
Some further improvements may be to add some better support for http streams etc. Feel free to make updates and send them to me
Title: Foo_msn
Post by: aurelio on 2005-04-18 00:11:43
Great update!! Thanks shaneh!
Title: Foo_msn
Post by: acedriver on 2005-04-18 06:10:21
thx for the update.. what is WM/ID in config panel?
Title: Foo_msn
Post by: shaneh on 2005-04-18 07:07:24
Wm/ID is just windows media content id garbage. You can put whatever you want in there, and use it as an extra field if you like, through the {3} selector.
Be advsied this will be sent to all your contacts even if you arent showing it. When you click on a contacts currently playing song, it uses the fields to try locate the song. If WM/ID is present, it may use that field to try locate the song. So I suppose you could be clever and set it to the wmid of some britney speares song to give people clicking on your song a cute surprise. I assume if the WMID isn't valid, it then uses the album/artist/title to try locate the song.
I havent really experimented with it that much, but the WMP seems to use that field for that purpose, so its labeled as such.
Title: Foo_msn
Post by: acedriver on 2005-04-19 02:25:56
cool... thx shaneh
Title: Foo_msn
Post by: Trigger911 on 2005-05-16 19:20:54
omg i leave for a week and everything i was gonna post about magicly shows up omg ur guys r alsome thanx for all the hard work i wubz j00 yallz
btw works alsome im in love no more wmp to soo friends and family what im jammin 2 thanx sooooooooooooooooooooooo much wmp is a resource hog
Title: Foo_msn
Post by: ExUser on 2005-05-16 21:22:21
[a href="index.php?act=findpost&pid=298110"][{POST_SNAPBACK}][/a]
Ever read TOS #10?
Title: Foo_msn
Post by: fakeplastictrees on 2005-05-23 09:03:11
Can anyone help? The plug-in was working fine 12 hours ago, and now it doesn't seem to work.
Title: Foo_msn
Post by: webwarp on 2005-07-18 12:36:22
How can I make i work with newest foobar ?? 0.9 build 5 ..
Title: Foo_msn
Post by: LessThanSte on 2005-07-20 12:27:56
Quick question, will any of these work with v0.7.1 of foobar?
I like hte style of this version and dont really want to change. When i load it i get a 'could not load dll' message
Title: Foo_msn
Post by: Marv007 on 2005-09-29 11:48:42
this should do the trick for DLL load errors:
http://www.hydrogenaudio.org/forums/index....showtopic=34890 (http://www.hydrogenaudio.org/forums/index.php?showtopic=34890)
Title: Foo_msn
Post by: LessThanSte on 2005-10-18 19:39:01
Doesnt help me
Anyone know if it can be made to work with v0.7.1, or alternatively if the newest version can be made to look exactly the same as, and have all the features of v0.7.1?
Title: Foo_msn
Post by: shof515 on 2006-03-20 17:05:57
update to .09
Title: Foo_msn
Post by: PHOYO on 2006-03-20 17:29:09
update to .09
[a href="index.php?act=findpost&pid=372971"][{POST_SNAPBACK}][/a]
Please
+1
Title: Foo_msn
Post by: G-Lite on 2006-03-22 14:15:19
I've got this to work with 0.9. This is experimental but seems to work fine:I hope Shane is alright with this. I've already had contact with him on modifying foo_msn before and he was okay with it. But I turned out to be lazy and never really sent him anything.
I changed the name to foo_msnalt at his request to set it apart from the official version, though.
Title: Foo_msn
Post by: wortels on 2006-03-22 18:37:20
doesn't seem to work with windows live messenger :S
Title: Foo_msn
Post by: aurelio on 2006-03-22 21:54:29
[a href="index.php?act=findpost&pid=373976"][{POST_SNAPBACK}][/a]
It's due to a different display behaviour of WLM beta, but your Msngr 7.5 contacts will see your song properly.
Title: Foo_msn
Post by: amonrei on 2006-03-23 10:40:43
Cool. It works with 7.5.
Title: Foo_msn
Post by: Chri5peed on 2006-03-23 12:14:59
I found foo_msnalt for 0.9 yesterday.
Looked for the link, can't find it, but I found the plugin pretty easily.
Title: Foo_msn
Post by: zoidbergslo on 2006-03-23 13:01:37
works great with 7.5 thanks
Title: Foo_msn
Post by: Andrea on 2006-03-23 18:01:35
Works like a charm on MSN 7.5, thank you!
Title: Foo_msn
Post by: Naveb on 2006-03-24 07:50:51
got this for 0.9.
its great. configured it just like my notification area pop-up
thanks
Title: Foo_msn
Post by: philipshu on 2006-03-24 08:15:56
foo_msnalt works with foobar 0.9 + WLM 8 build 566
well done
Title: Foo_msn
Post by: The_Sims on 2006-03-24 20:53:50
Is it possible to change tags ?
I mean, with shaneh's release, we were able to display this : "[TITLE] - [ARTIST] ([ALBUM])".
I didn't found this options with foo_msnalt
Title: Foo_msn
Post by: bonk on 2006-03-28 08:52:04
I didn't found this options with foo_msnalt :(
[a href="index.php?act=findpost&pid=374896"][{POST_SNAPBACK}][/a]
seems the new wlm uses a different method for display
a workaround is to change the value of "Title {1}" to %title% - %artist% %album%
can't get the parenthesis to work though
till the next release  :)
Title: Foo_msn
Post by: G-Lite on 2006-03-29 13:04:14
I'm not sure I understand the problem. The MSN format string is still configurable. There's a bug in Windows Live Messenger that it doesn't show the artist, but others (not using WLM) can see it.
Title: Foo_msn
Post by: TS2Master on 2006-03-31 10:52:23
Can we have a summary?
What are the best plug-ins to use?
For 0.83 or 0.9, and MSN or Live Messenger?
I have 0.83 and Live Messenger, with the old Toaster, but its been dodgy recently. Especially since upgrading to Live Messenger. What do you guys suggest?
Thanks...
Keep up the good work shaneh!
Title: Foo_msn
Post by: G-Lite on 2006-04-10 14:48:43
Okay, looks like I was wrong. They (unfortunately) ditched the format string in the later Windows Live Messenger builds. I've added a Windows Live Messenger mode checkbox to the preferences, and it shows up fine now for me.
Grab it here (http://stephan.kochen.nl/proj/foobar2000.html#msn)
Title: Foo_msn
Post by: The_Sims on 2006-04-15 09:42:10
thanks a lot
Title: Foo_msn
Post by: wortels on 2006-04-28 21:38:26
[quote author=G-Lite link=msg=380873 date=1144676923]Okay, looks like I was wrong. They (unfortunately) ditched the format string in the later Windows Live Messenger builds. I've added a Windows Live Messenger mode checkbox to the preferences, and it shows up fine now for me.
Grab it here (http://stephan.kochen.nl/proj/foobar2000.html#msn)[/quote]
WLM Bug has been fixed...no need for the special mode now
Title: Foo_msn
Post by: Mangix on 2006-05-03 03:42:48
just out of curiosity but what does WM/ID do?
Title: Foo_msn
Post by: G-Lite on 2006-05-09 15:11:02
Looks like it. Odd in the latest WLM though, is that they seem to have switched around artist ({0}) and title ({1}) in the formatting string?
Some windows media player specific identification I think, not sure if it's for the song or wmp itself. You should probably leave it empty though.
Title: Foo_msn
Post by: ZZChess on 2006-05-13 13:34:25
Any chance that this can be made to work with 8.0 beta?
Title: Foo_msn
Post by: acedriver on 2006-05-13 14:37:40
it already works with latest WLM (build 689)
Title: Foo_msn
Post by: ZZChess on 2006-05-13 15:33:14
Wasn't working for me earlier but it is now thanks.
Title: Foo_msn
Post by: krazy on 2006-06-10 08:05:49
Any chance of an update to correctly show tag info for online radio streams?
Title: Foo_msn
Post by: SOS on 2006-06-19 16:25:29
[quote author=G-Lite link=msg=390787 date=1147183862]Odd in the latest WLM though, is that they seem to have switched around artist ({0}) and title ({1}) in the formatting string?[/quote]
It seems that way to me as well. I'm using WLM build 689.
Title: Foo_msn
Post by: drawing. on 2006-09-13 10:13:17
I just added a menu item to let user select if show now playing to the msn status bar. (View->Display now playing)
And fixed the parameter order defect. I tested it on foorbar 0.9.3 . It works fine:)
This is the plugin: [attachment=2530:attachment]
the modified source code: [attachment=2531:attachment]
[/quote]
Title: Foo_msn
Post by: omniwolf on 2006-09-27 06:14:41
thanks for this plugin!
it also works with miranda (http://miranda-im.org) in conjunction with the ListeningTo (http://forums.miranda-im.org/showthread.php?t=10912) plugin.  Keep up the good work.
Title: Foo_msn
Post by: decayed.cell on 2006-10-16 12:37:42
[/quote]
I'm using 812... and it seems to cut off the name of the song? Artist shows up though
EDIT: Unchecking WLM mode fixes it.
Title: Foo_msn
Post by: trixta on 2006-11-04 18:07:51
hi, could somebody please tell me what i do with the sourcecode? I have no idea
Title: Foo_msn
Post by: L0g0ff on 2006-11-13 23:37:09
Yeah, i'm only listining to radio streams so an (little) fix it would be very nice
Title: Foo_msn
Post by: LiD32 on 2007-02-10 20:45:55
Thanks. It works fine.
Title: Foo_msn
Post by: Cybermat on 2007-03-04 12:14:35
Hi, i'm using foobar 0.9.4 and MSN live 8.1 version.
Is there a way to make it working? I tried different plugins but no way to have the song displayed
Help!
Title: Foo_msn
Post by: Cybermat on 2007-03-04 18:17:40
Help!
I had the flag of "display the listening music" OFF in MSN
Disregard...
Title: Foo_msn
Post by: Arm@nd on 2007-03-20 17:18:07
This is indeed a fix I'd really like to see in the extension. It would be great if you could do it !
Title: Foo_msn
Post by: Earthworm on 2007-03-22 18:16:51
any progress here? i would appreciate this feature as well!
Title: Foo_msn
Post by: ailef on 2007-03-25 07:02:00
the plugin works with msn 8.1.0178.00 and foobar 2000 0.9.4.2
Title: Foo_msn
Post by: Earthworm on 2007-04-10 10:57:14
it doesn't show tag info for radio streams, does it?
Title: Foo_msn
Post by: Gordian Knot on 2007-05-07 17:23:38
I downloaded a different dll from http://stephan.kochen.nl/proj/foobar2000.html#msn (http://stephan.kochen.nl/proj/foobar2000.html#msn)
http://stephan.kochen.nl/proj/foo_msnalt/foo_msnalt.dll
Should I use the aforementioned plugin (it works with MSN v8.1.0178.00 / Foobar 2000 v0.9.4.3) or the one uploaded here?
Also, How do I get the Artist tag to appear BEFORE the song title?
edit: Never mind, I just figured it out...
Foobar Preferences => Display => MSN Now Playing  'MSN format' {1} - {0}, instead of {0} - {1}
Title: Foo_msn
Post by: Delftenaar on 2007-06-25 16:37:45
It works fine with xp, but i can only use "generic fields" to show on msn. Things like "%list_total%" doesn't seem to work. Is there a way to get other fields in your msn personal message?
Title: Foo_msn
Post by: RayMcCoy on 2007-07-11 21:05:34
I have modified foo_msnalt so now it updates the information of internet radio streams as it changes.
Tested with foobar 0.9.4.3 and MSN Messenger 8.1.0178.00 .
Source included in the zip.
Title: Foo_msn
Post by: L0g0ff on 2007-07-12 21:55:31
Wow thanks m8      the only problem is that i'm using Arch Linux on the moment
Title: Foo_msn
Post by: krazy on 2007-07-29 07:01:01
Thanks RayMcCoy! Just what I was after!
Title: Foo_msn
Post by: ailef on 2007-08-20 23:13:05
it works with foobar 0.9.4.4 and WLM beta 8.5 build 1238.
Title: Foo_msn
Post by: hexonn on 2007-11-21 02:27:05
does this work for anyone? i got the latest 8.5.1302.1018, and it doesn't anymore :/
Title: Foo_msn
Post by: m-z on 2007-11-21 03:28:45
It's working for me. I'm using foo_msnalt 2.4.
Title: Foo_msn
Post by: zombie on 2007-12-23 03:02:42
Same for me, I just updated live messenger today and it stopped working.  Using foo_msnalt 2.4 :/
Why oh why can't MS just stop re-inventing the wheel? lol
z.
Title: Foo_msn
Post by: ShadowVlican on 2008-02-08 22:01:21
the one HERE (http://stephan.kochen.nl/proj/foobar2000.html#msn) works with foobar v0.9.5 and Live messenger 8.5.1302.1018
supports unicode tags too!! yay!
Title: Foo_msn
Post by: Samurro on 2008-02-25 20:30:22
And simply doensn't work for me...
Is there any config needed?
Title: Foo_msn
Post by: snively on 2008-02-25 22:20:54
it works perfectly fine for me. you might want to try AMIP if you can't get this working.
Title: Foo_msn
Post by: adamb on 2008-05-04 03:07:32
Samurro, you need to take the downloaded dll and copy it to C:\Program Files (x86)\foobar2000\components\ if you're running a 64-bit Windows OS...for a 32-bit Windows OS you need to copy it to C:\Program Files\foobar2000\components\ and you should be able to get it to work. It worked without a hitch when I did that.
Title: Foo_msn
Post by: apul on 2008-05-21 20:10:32
Thats a cool plug-in actually, thanks guys.
Title: Foo_msn
Post by: Shizane on 2008-06-17 08:23:33
this link throws a error while downloading ne alternate valid link is available?
Title: Foo_msn
Post by: Alexxander on 2008-06-17 11:13:08
Link works for me on Firefox.
Title: Foo_msn
Post by: spectral on 2008-07-07 13:19:37
For everyone who has problems: When I first tried it, it didn't work. But that's because i had disabled "Show song information from windows media player as a personal message".. Maybe that's your problem too, just a thought.
Title: Foo_msn
Post by: vigylant on 2008-10-21 17:48:25
Im sorry if this thread is a little old, but would it be possible for anyone to recompile this component with the newest SDK?
edit: oops, this is strange...
Im talking about foo_msnalt (not foo_msn), because the link from the wiki points to this thread...
Just to clarify
Title: Foo_msn
Post by: n0obie4life on 2008-10-22 03:21:49
Just to clarify
http://www.hydrogenaudio.org/forums/index....showtopic=66346 (http://www.hydrogenaudio.org/forums/index.php?showtopic=66346)
Try this?
Title: Foo_msn
Post by: grrowl on 2008-12-01 09:30:32
Just to clarify
I'd also like an update to this component. The source code is available and msn_wlm isn't as good (it displays a song as 'now playing' even if it's just paused). thanks.
Title: Foo_msn
Post by: shinigami7th on 2008-12-02 11:25:00
well, foo_wlm indeed does show the song on WLM when paused, but there is a "(Paused)" tag at the end. It doesn't really matter to me, IMO...
but if u really want foo_msn style plugin (or foo_msnalt), there is a link to a modded foo_msnalt in the foo_wlm thread:
http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=66346&view=findpost&p=602143
srsly, someone ought to put this up in the wiki....
Title: Foo_msn
Post by: Zerox Millienium on 2008-12-11 02:23:49
foo_msnalt.dll doesn't seem to work with foobar2000 v0.9.6 on Vista Ultimate 64-bit.
Can we have a fix for it?
Title: Foo_msn
Post by: Finiderire on 2009-03-28 20:35:45
+1
a+, =)
-=Finiderire=-
Configuration :
Foobar2000 v0.9.6.3 + Foo_msnalt # Last updated: 2006-04-10
Windows Vista 64 SP1 Ultimate
Title: Foo_msn
Post by: Case on 2009-03-29 09:15:24
You can download a version build with latest SDK here (http://www.saunalahti.fi/~cse/foobar2000/foo_msnalt.zip).
Title: Foo_msn
Post by: Cutter on 2009-04-21 23:04:56
Hi, is there an MSN plugin capable of submitting trackinfo from streams (i.e. not the item's name but the currently playing track).
Title: Foo_msn
Post by: Case on 2009-05-21 09:27:42
foo_msnalt started to annoy Peter because of somewhat frequent crash reports from it. I tried to fix what I could and added stream title display support. Download version 2.41 (http://www.saunalahti.fi/~cse/foobar2000/foo_msnalt.zip).
Title: Foo_msn
Post by: letricolore on 2009-06-15 21:09:00
Is there a newer version that works with 9.6.8?
Title: Foo_msn
Post by: Rain on 2009-06-16 02:32:59
Use foo_wlm (http://www.hydrogenaudio.org/forums/index.php?showtopic=66346) instead.
Title: Foo_msn
Post by: Goldie Lin on 2009-06-16 03:28:08
foo_msnalt Here (http://www.saunalahti.fi/cse/foobar2000/)! thx to case
Title: Foo_msn
Post by: letricolore on 2009-06-16 04:27:05
Works perfect; thanks!
Title: Foo_msn
Post by: afx777 on 2009-07-11 18:01:26
Hi, is there a variable or a way to show the name of a streaming radio station as well as the artist and song currently playing?
eg. Radio 1 (blah blah) - Radiohead - Creep
PS (I switched to using this today, I got tired of AMIP wrapper restricting the amount of characters in the title and struggling to work it out properly).
Title: Foo_msn
Post by: niekw on 2010-04-12 20:52:10
Hi there,
this being my first post
Im having trouble running the plugin, it doesn't dsplay the info at all.
restarting Foobar and WLM did not help until now.
Win 7 64bit
fb 1.0
wlm 2009
wlm not 1.1.3
Title: Foo_msn
Post by: Finiderire on 2010-04-12 23:15:40
Hi there,
Win 7 64bit
fb 1.0
wlm 2009
wlm not 1.1.3
Maybe you should try AMIP instead
http://amip.tools-for.net/wiki/start (http://amip.tools-for.net/wiki/start)
a+,=)
-=Finiderire=-
SimplePortal 1.0.0 RC1 © 2008-2018
