Topic: The Beatles in Mono > 1-Channel FLAC? (Read 5105 times) previous topic - next topic
I'm thinking to save space I'll use foobar2000 to rip and "downmix to mono" these CDs.
Is there any reason why that is a bad idea?
I'd be surprised if this saved any significant space.  I'm sure the FLAC encoder is smart enough to switch to Mid+Side for these files and essential just store one channel.
You probably save more space by switching to a higher compression setting, and it'd probably take about the same amount of time.  And take less thinking.
elevatorladylevitateme
Ripping the set in "true" mono was already discussed [a href='index.php?showtopic=77599']here[/a].
Thanks for your replies; I'd hadn't found that link.
@shakey, you are probably right about not overthinking it!
One more minor consideration...  Your mono FLACs will be flagged as stereo.
By default, I use Joint Stereo on my MP3s.  Since I didn't change anything when I ripped mono CDs, the mono tracks show-up as "Joint Stereo" when I play them.
FYI, FLAC figured out something was going on...
The folder for "A Hard Day's Night" in mono is 130MB vs. 202MB in stereo at same compression setting (36% reduction).
