Topic: When should you use joint stereo over normal stereo? (Read 16387 times) previous topic - next topic
when and at what bitrates shud joint stereo be used
heard it is just for low bitrates, if so where to the point shud u use joint and where to a point just use normal stereo
wud it be used as high as 256 mp3, then after at 320 use normal stereo
or am i missing somethin
whats the deal?
Normal joint stereo (default) is recommended for all bitrates.
joint stereo
In this mode, the encoder will make use of correlation between both channels. The signal will be matrixed into a sum ("mid"), computed by L+R, and difference ("side") signal, computed by L-R, and more bits are allocated to the mid channel.
This will effectively increase the bandwidth if the signal does not have too much stereo separation, thus giving a significant gain in encoding quality. In joint stereo, the encoder can select between Left/Right and Mid/Side representation on a frame basis.
Using mid/side stereo inappropriately can result in audible compression artifacts. To much switching between mid/side and regular stereo can also sound bad. To determine when to switch to mid/side stereo, LAME uses a much more sophisticated algorithm than that described in the ISO documentation, and thus is safe to use in joint stereo mode.
🇺🇦 Glory to Ukraine!
what about lame presets
preset standard
extreme
insane
they all use joint stereo
or are these presets encoded specifically for joint stereo
Joint stereo is not only recommended, but default. Thus, it's used unless you specify otherwise, which you shouldn't. It's recommended and default for a reason. If you need more information, there are countless past topics on this, as well as information on the Knowledgebase and Wikipedia. People must try to search instead of making others repeat themselves.
i have searched but theres nowt wrong in asking,
i am using cdex with preset insane for best quality
so that must be the most i can get out of it
presets:
insane = -b 320
extreme = -V 0 --vbr-old
standard = -V 2 --vbr-old
As you see, some presets enables old VBR algoritm which is not recommended for latest LAME versions.
Also presets don't use any stereo mode switches so thay use default Joint Stereo mode
Are you sure that presets still use vbr-old? I know that adding "fast" was previously necessary to enable vbr-new, but logic suggests that since it's default now, this would be redundant. Anyway, simple -V and -b switches are now equivalent to and effectively recommended over presets, as the OP would have realised if he'd read the wiki.
Presets do not enable vbr-old.
Actually they do.
I'm 100 % sure that it is true for lame 3.98.2/3/4 (verified with EncSpot & foobar2000 bitcomparator)
Upon consulting the wiki as per my own advice (which tastes strangely like humble pie), I saw that. Although presets are now technically redundant, this seems to me to be worth changing since vbr-new is now the recommended mode.
If you are aiming for best quality, you shouldn't use a lossy codec at all. Use FLAC (or any other lossless codec) to store your music. If you need a lossy encode (e.g. for portable use) you can always transcode it quickly using foobar2000. When you have a lossless archive, you don't need to worry about any possible artefacts - You can always make a new encode if you encounter any. To date I haven't been able to hear an artefact using LAME -v5 during casual listening.
This is not the case with LAME 3.98.4 [downloaded from Rarewares]. Here are three different encodes of the same track:
C:\tmp>lame --verbose -V 2 rts.wav rts-default.mp3
LAME 3.98.4 32bits (http://www.mp3dev.org/)
CPU features: MMX (ASM used), SSE (ASM used), SSE2
Using polyphase lowpass filter, transition band: 18671 Hz - 19205 Hz
Encoding rts.wav to rts-default.mp3
Encoding as 44.1 kHz j-stereo MPEG-1 Layer III VBR(q=2)
misc:
        scaling: 1
        ch0 (left) scaling: 0
        ch1 (right) scaling: 0
        huffman search: best (outside loop)
        experimental Y=0
stream format:
        MPEG-1 Layer 3
        2 channel - joint stereo
        padding: all
        variable bitrate - VBR mtrh (default)
        using LAME Tag
psychoacoustic:
        using short blocks: channel coupled
        subblock gain: 1
        adjust masking: -4.4 dB
        adjust masking short: -1.8 dB
        quantization comparison: 9
        ^ comparison short blocks: 9
        noise shaping: 1
        ^ amplification: 2
        ^ stopping: 1
        ATH: using
        ^ type: 4
        ^ shape: 2 (only for type 4)
        ^ level adjustement: -0.2
        ^ adjust type: 3
        ^ adjust sensitivity power: 1.000000
        ^ adapt threshold type: 2
        experimental psy tunings by Naoki Shibata
          adjust masking bass=0 dB, alto=0 dB, treble=0 dB, sfb21=4.5 dB
        using temporal masking effect: no
        interchannel masking ratio: 0
    Frame          |  CPU time/estim | REAL time/estim | play/CPU |    ETA
 14945/14945 (100%)|    0:19/    0:19|    0:19/    0:19|  20.463x|    0:00
 32 [  11] %
 40 [    0]
 48 [    0]
 56 [    0]
 64 [    0]
 80 [    0]
 96 [    1] %
112 [  16] %
128 [  27] %
160 [ 2685] %%%%********************
192 [ 7571] %%%%%%%%%%%%%%%%%%%%%%*********************************************
224 [ 2562] %%%%%%%%%**************
256 [ 1539] %%%%**********
320 [  533] %%***
  kbps        LR    MS  %    long switch short %
  202.6      29.4  70.6        96.1  2.3  1.7
Writing LAME Tag...done
C:\tmp>lame --verbose -V 2 --vbr-old rts.wav rts-old.mp3
Encoding rts.wav to rts-old.mp3
Encoding as 44.1 kHz j-stereo MPEG-1 Layer III VBR(q=2) qval=3
misc:
        scaling: 1
        experimental Y=0
stream format:
        MPEG-1 Layer 3
        padding: all
        variable bitrate - VBR rh
        using LAME Tag
psychoacoustic:
        subblock gain: 1
        adjust masking: -2.2 dB
        adjust masking short: -3.5 dB
        noise shaping: 1
        ^ amplification: 1
        ^ stopping: 1
        ATH: using
        ^ type: 4
        ^ level adjustement: -0.28
        ^ adjust type: 3
          adjust masking bass=0 dB, alto=0 dB, treble=0 dB, sfb21=5.25 dB
        using temporal masking effect: yes
 14945/14945 (100%)|    0:29/    0:29|    0:29/    0:29|  13.227x|    0:00
 32 [  12] %
 40 [    0]
 48 [    0]
 56 [    1] %
 64 [    0]
 80 [    0]
 96 [    1] %
112 [    6] *
128 [  54] %
160 [ 2372] %%*************************
192 [ 5950] %%%%%%%%%%%********************************************************
224 [ 4288] %%%%%%%%%%%%%%***********************************
256 [ 2081] %%%%********************
320 [  180] %**
  206.1      17.2  82.8        98.3  1.0  0.6
ReplayGain: -5.4dB
C:\tmp>lame --verbose -V 2 --vbr-new rts.wav rts-new.mp3
Encoding rts.wav to rts-new.mp3
misc:
        scaling: 1
        experimental Y=0
stream format:
        MPEG-1 Layer 3
        padding: all
        using LAME Tag
psychoacoustic:
        subblock gain: 1
        noise shaping: 1
        ^ amplification: 2
        ^ stopping: 1
        ATH: using
        ^ type: 4
        ^ adjust type: 3
 14945/14945 (100%)|    0:19/    0:19|    0:19/    0:19|  20.347x|    0:00
 32 [  11] %
 40 [    0]
 48 [    0]
 56 [    0]
 64 [    0]
 80 [    0]
 96 [    1] %
112 [  16] %
128 [  27] %
320 [  533] %%***
ReplayGain: -5.4dB
C:\tmp>fsum *.mp3
SlavaSoft Optimizing Checksum Utility - fsum 2.52.00337
Implemented using SlavaSoft QuickHash Library <www.slavasoft.com>
Copyright © SlavaSoft Inc. 1999-2007. All rights reserved.
; SlavaSoft Optimizing Checksum Utility - fsum 2.52.00337 <www.slavasoft.com>
; Generated on 05/22/10 at 08:48:19
55bfce3f3de63fa9a645b750b192267a *rts-default.mp3
55bfce3f3de63fa9a645b750b192267a *rts-new.mp3
e1619c7fba9f501eff0c758ffc5734db *rts-old.mp3
In fact, I'm fairly certain that the default VBR method was changed from RH to MTRH with 3.97 or 3.98 [if not earlier]. I seem to recall that MTRH is not only faster, but provided better results in many cases, hence the switch.
lvqcl was referring to presets, e.g. --preset standard is equivalent to -V2 --vbr-old. VBR-new must be activated by adding fast before the preset name. I understand the original reason for this, but it may be worth amending the behaviour, since VBR-new is now default. That said, as if to add to the confusion, the latest alphas have yet another VBR mode!
I must say this foot-in-mouth dish is quite nourishing, too    Silly me for not carefully reading the posts. You're all absolutely right, of course.
Could you tell me where to find more about this?
In terms of LAME, the joint-stereo mode will use both stereo and joint-stereo at its discretion. It's kind of a win-win situation over pure stereo or pure joint-stereo. (Can't speak of other MP3 encoders doing this the same.)
If I'm not mistaken, what you meant to say is:
"In terms of LAME, the joint stereo mode will use both left/right stereo and middle/side stereo at its discretion. It's kind of a win-win situation over pure left/right stereo or pure middle/side stereo."
Joint stereo allows LAME to switch between L/R and M/S on a frame-by-frame basis. Frames are not encoded in "joint stereo mode", because joint stereo is just the name for the decision ability, not the content of the decisions.
