Topic: WSH Panel Mod script discussion/help (Read 1414620 times) previous topic - next topic
Reply #1425
here the console output with the script from pastebin:
Error: WSH Panel Mod (CoverFlow View v1 beta7.1 v0.0.7.20120401.2320 by Br3tt): Laufzeitfehler in Microsoft JScript:
'list.item[...]' ist Null oder kein Objekt
File: <main>
Ln: 1333, Col: 2
ok for this bug, fixed in this new version normally:
http://pastebin.com/WdkYVzrn
thanx for the feedback
Reply #1427
Falstaff
In my configuration (foo_playlist_attributes) played tracks removed from playlist after playing.
But covers of this tracks not deleted automatically from WSH Coverflow panel. It is possible add this future in next version of coverflow script.
Reply #1428
@Falstaff
I am pleased to say that I am no longer experiencing crashes with beta 8; the catch (e) seems to have solved the problem.
I have troubleshooted the sticking cover issue further. Essentially it's a similar problem to that reported by pIv above. The problem occurs when using foo_lastfm_radio but not when playing tracks in the media library. foo_lastfm_radio removes played tracks from the playlist, but covers of these tracks remain in coverflow and so coverflow is not updating to reflect the changed playlist. If I remain in foobar2000 when a track change occurs the correct cover is nonetheless highlighted. If I toggle away from foobar2000 while a track change occurs the incorrect previous cover is often highlighted as the now playing cover (not corrected by pressing the music note button).
Thanks for your hard work on this. Previously I have been using a wsh coverflow based on the Grimes code but yours automatically updates and is visually an improvement.
Reply #1429
Falstaff
...But covers of this tracks not deleted automatically from WSH Coverflow panel. It is possible add this future in next version of coverflow script.
i'll check that, should not be a big deal to fix ....
Reply #1430
...The problem occurs when using foo_lastfm_radio but not when playing tracks in the media library. foo_lastfm_radio removes played tracks from the playlist, but covers of these tracks remain in coverflow and so coverflow is not updating to reflect the changed playlist.
are you sure of that, i've just tested lastfm_radio component (lastest version) and coverflow updates as well the tracks change!
Reply #1431
I have just retested under DUI & CUI with foo_lastfm_radio 0.5.7e which I believe is the latest. On track change I see the track and cover of the played track disappear from the playlist but the cover remains in coverflow (the only exception to this is if there are less than ~4 tracks in the playlist and the playlist updates by adding new tracks, then coverflow updates correctly). This behaviour is confirmed on 2 different PCs. Clicking refresh coverflow on the menu will, however, update coverflow.
Reply #1432
I have just retested under DUI & CUI with foo_lastfm_radio 0.5.7e which I believe is the latest. On track change I see the track and cover of the played track disappear from the playlist but the cover remains in coverflow. This behaviour is confirmed on 2 different PCs. Clicking refresh coverflow on the menu will, however, update coverflow.
v 0.5.7e here too but different behaviour here, weird, i'll try on another PC...
Reply #1433
New simplified and revised map only version of WSH-Script FooTour.
Download: http://pastebin.de/24891
Screenshot:
Installation: Download world map and FooTour banner from
http://eoimages.gsfc.nasa.gov/images/image...w_topo_2048.jpg
http://www.abload.de/image.php?img=footouro74r.png
credits: NASA
http://foobar-users.de/index.php?topic=200...g17454#msg17454
and put pictures in new created (profile)\foobar2000\pictures folder
Reply #1434
@falstaff
no more crashes!
Reply #1436
ok, i see what you mean now, i've not understood, because coverflow refresh when lastfm radio add a new track to the playlist, and so, your issue is when a track is played, it should be removed immediatly. i'll see if i can catch this event! well see.
Reply #1437
Yes there's that plus the presumably knock-on effect with foo_lastfm_radio (may be also when foo_playlist_attributes is set to remove tracks as posted above) that the cover highlighted/centred & the displayed information soon get out of sync with the playing track. For example, with foo_lastfm_radio, in my hands pressing play next track a few times soon results in it sticking on the wrong cover/info.
HTH
Reply #1439
@Falstaff
Thanks for beta 8.1. All is now working well.
Reply #1441
is this fixed for you with beta 8.1 ? thanx by advance for your feedback about the use of foo_playlist_attributes with my script now (should be ok)
Reply #1442
New version beta 8.1 work now very good!
Reply #1444
Maybe it makes sence to add mouse gestures to scroll ? It works, it is convenient. I made it very easy (in other script) :
var gest_x1, gest_y1, gest_x2, gest_y2;
function on_mouse_lbtn_down(x, y) {
    gest_x1 = x;
    gest_y1 = y;
function on_mouse_lbtn_up (x, y) {
gest_x2 = x;
                gest_y2 = y;
        if ( (gest_y2 - gest_y1 < 10) && (gest_y2 - gest_y1 > -10))  {
        if (gest_x2 - gest_x1 > 30) {Cover.NextCover(); window.Repaint();};
        if (gest_x2 - gest_x1 < -30) {Cover.PrevCover(); window.Repaint();}
Reply #1447
WSH CoverFlow v1 beta 9.1 : http://pastebin.com/ANFNNA3Q
What's New in beta9.1:
- transition effect enhanced on cover change, and propagated to mousewheel and keys now
- small glitch on cover reflection fixed
