Topic: question: how-to make relative m3u playlist default foobar setting (Read 4760 times) previous topic - next topic
my foobar version: v0.9.6.4 (will upgrade to latest foobar rev if NECESSARY to get this functionality)
I would like to make relative m3u references in foobar, as the DEFAULT setting.  My reason for wanting relative (as opposed to absolute) references in my m3u playlist, is that I experimented & found that when using a relative m3u playlist, I could copy the playlist to my usb stick, & play the playlist on a 2nd computer without needing to modify the playlist.
To be clear, this is what I mean by relative vs specific reference via example:
RELATIVE
..\D\Dilated Peoples 2000 The Platform\03 No Retreat.mp3
SPECIFIC
C:\Documents and Settings\PC\My Documents\My Music\Archive\D\Dilated Peoples 2000 The Platform\03 No Retreat.mp3
As of now, I can change a playlist to relative by editing the m3u file in a text file with "find/replace".  HOWEVER, if I ever change this m3u file in foobar, by say adding 1 track, & saving the m3u file, it will go back to specific references.
I apologize if I missed something obvious, I'm a n00b here on this forum.  Big thx in advance.
use Text Tools component, or XSPF output from foo_softplaylist
Saving an M3U playlist in an upper directory above its tracks will use relative paths.
For example, a playlist of "C:\Music\Artist - Album\*.mp3" saved to "C:\Music\Artist - Album\playlist.m3u" will contain just "Track 1.mp3", "Track 2.mp3", etc. When saved to "C:\Music\playlist.m3u", it will have paths like "Artist - Album\Track 1.mp3" and so on.
If there would need to be some upper directory "..\" parts or if the files are on a different drive, absolute paths are used.
THX YIRKHA!
I tested ur suggestion.  My playlists involve tracks from multiple folders, for example "Best of Artist" type playlist, 20 tracks chosen from 6 albums.  I moved the m3u playlist into my "Archive" directory, which is "top level directory" for purposes of where I keep all my music mp3 files.  When resaving the m3u, it uses the relative paths AUTOMATICALLY, eg
Thx again, this really helps me out, brotha (or sista)!
Moderation:Removed unnecessary full quote of the preceding post.
