Topic: foobar2000 v1.0 beta 3 (Read 30807 times) previous topic - next topic
Issues fixed in 1.0 beta 3:
  • Bug: Certain ASX files fail to load when dragged from a webbrowser or added through "add location".
  • Bug: Windows Media stream .WAX files can't be opened.
  • Bug: Titles of certain Windows Media streams are not displayed.
Download .torrent
v1.0 release notes
Topic Splits: Converter Output Formats [...] button discussion
Also fixes cuesheet creation when encoding to TAK or APE without updated decoder components.
When I open ASX of certain radio stations (BBC, e.g.), the playlist looks like this:
BBC 1Xtra - BBC 1Xtra
1xtra_bb_live_int_ep1_sl0?BBC-UID=a47a2c4bfd4056d3af34b2d3213b2ab630c492c3d0806281e2f86004333c2038&SSO2-UID=
1xtra_bb_live_int_eq1_sw0?BBC-UID=a47a2c4bfd4056d3af34b2d3213b2ab630c492c3d0806281e2f86004333c2038&SSO2-UID=
1xtra_bb_live_int_ep1_sw0?BBC-UID=a47a2c4bfd4056d3af34b2d3213b2ab630c492c3d0806281e2f86004333c2038&SSO2-UID=
1xtra_bb_live_int_eq1_sw1?BBC-UID=a47a2c4bfd4056d3af34b2d3213b2ab630c492c3d0806281e2f86004333c2038&SSO2-UID=
1xtra_bb_live_int_ep1_sw1?BBC-UID=a47a2c4bfd4056d3af34b2d3213b2ab630c492c3d0806281e2f86004333c2038&SSO2-UID=
1xtra_bb_live_int_eq1_sl1?BBC-UID=a47a2c4bfd4056d3af34b2d3213b2ab630c492c3d0806281e2f86004333c2038&SSO2-UID=
1xtra_bb_live_int_ep1_sl1?BBC-UID=a47a2c4bfd4056d3af34b2d3213b2ab630c492c3d0806281e2f86004333c2038&SSO2-UID=
When I open the very same ASX in WMP, the GET parameters from urls are omitted, and the playlist looks like this:
Could foobar2000 omit parameters from urls, when displaying them on the playlist, too?
Thanks for your continous support of Windows Media Streams. BBC streams still fail to work here.
Complete BBC local radio list: http://iplayerhelp.external.bbc.co.uk/help...l_radio_streams
I tested: http://bbc.co.uk/radio/listen/live/rc.asx and http://bbc.co.uk/radio/listen/live/rf.asx
Could not read info (Unsupported format or corrupted file) from: "http://wmlive.bbc.net.uk/wms/nations/cymru?BBC-UID=445ba1e9e26bf618ad84a38a71d620bc4799d107f0709124245f8496835a090a&SSO2-UID="
Unable to open item for playback (Unsupported format or corrupted file):
@Squeller: Both stations that you've posted are working perfectly for me. But I use Continuator DSP, and with this enabled  the first 10 seconds (buffer size of dsp) the sound is choppy. With MP3 streams is no problem. Could be a Continuator DSP? It's a bit outdated...
LAME 3.100.1 -V0
No, no active DSP... But you're right, with a fresh fb2k install it works. I need to sort this out, but no idea currently.
EDIT: Removed my component list. It's not a components fault IMO. I deleted all component dll's and copied components of a working fb2k to this component folder: Same problem, stream does not start. I also do not think it's a firewalling issue. http://www.abc.net.au/hobart/onair/936stream.asx works for instance. Still I have no idea.
Man, Peter's been on fire releasing these betas! I remember when Beta 1 was released & some people were worried the next beta wouldn't be released before it expired in 4 weeks.
Awesome job, Peter. Just awesome.
I don't think that is a foobar2000 problem, i have this config for almost a year, i've been upgrading every time my foobar, never done reconfigure from scratch
LAME 3.100.1 -V0
Using beta 3, most streams in that list work, however the ones listed under "Windows Media Player" (towards the bottom) do not, due to their use of recursive playlist files. This has been fixed for the next beta.
There's no telling which other BBC .asx streams would fail for the same reason.
elevatorladylevitateme
Squeller: Having "full file buffering" enabled in Advanced Preferences somehow breaks WM streaming over HTTP, that's probably what you're experiencing, I'm looking into it now. Thanks for reporting.
You must be new around these parts... Beta cycles happen quite quickly, they always have.
Bug: if media library search has focus then I cant open (per key shortcut) playlist search, the other way round works fine.
plutogeek, please read relevant materials before posting:
http://www.foobar2000.org/?page=ReleaseNotes&version=10
New Edit Menu behavior
With Default User Interface, the Edit Menu commands operate on currently selected items, not just on the currently active playlist. This allows - for an example - to use the Copy command on Album List selection.
This feature currently does not work with third party user interfaces - Edit Menu commands operate on the active playlist just like in old foobar2000 versions; relevant components will need to be updated to comply.
So if the playlist doesn't have focus, the edit menu isn't referencing the playlist
Is there a way to show lyrics, whit this beta?
What about to make foobar remember the column width in Playlist Manager and Selection Properties. It would be great....I hate horizontal scrollbars.
LAME 3.100.1 -V0
The Value column of Selection Properties changes with the content and won't be changed; I've asked about it before.
What changes in the playlist manager exactly?
I've always had this problem using Continuator DSP. It doesn't handle playback of livestreams properly I think. Actually I don't understand why the integrated crossfader doesn't add smilar functionality (Instead of crossfade, just overlap if two tracks doesn't blend seamlessly. Eventually fadeout a track if it ends abruptly).
(maybe-not-so) Major bug here from the Metadata/Properties dialog.
When selecting multiple files, the "Individual Values" tab always shows the Title tag/field/I forget the name for it in foobar2000 and is not editable:
http://img686.imageshack.us/img686/1183/foobar10b3bug.png
You need to scroll all the way to the right and bring the editable column back into your view. The item column is there so that you know for sure which item you are editing.
It's nice to Built-in support for Windows Media streaming!I find there are still several shortage or bug of reading the streaming file -- asx.
1)It can't read the asx file when it contains asx address,while FK can read the Url address using the command "add location".
The script is like this:
<asx version="3.0">
<title>BBC</title>
<author>BBC</author>
<entry>
<ref href="http://www.bbc.co.uk/radio/listen/live/r1.asx"/>
<title>BBC Radio 1(The Best New Music)</title>
<author>BBC Radio 1</author>
</entry>
<entry>
<ref href="http://www.bbc.co.uk/radio/listen/live/r2.asx"/>
<title>BBC Radio 2(Music & Entertainment)</title>
<author>BBC Radio 2</author>
</entry>
</asx>
2)It can't read the whole streaming address when it contains multi radio stations;
3)I used to use mslive plug-in, it will recognise the <title> ,<author> before the entry as album(the station name) and album artist ,
and treat the <author> in the entry as track artist .It'll be greatly convenient to array and manage.
<asx version="3.0">
<title>1club.fm</title>
<author>1club.fm</author>
<entry>
<title>Dance Hits (Chicago)</title>
<author>Dance (EDM) Radio Stations</author>
<ref href="http://wms-11.streamsrus.com/dancehitshi"/>
<copyright>1club.fm</copyright>
</entry>
<entry>
<title>Electro House</title>
<ref href="http://wms-11.streamsrus.com/ElectroHousehi"/>
</entry>
<entry>
<title>House(Miami)</title>
<ref href="http://wms-11.streamsrus.com/afterhourshi"/>
</entry>
</asx>
can someone tell me how to generate a crash report?
since i installed the beta, i can't listen to Bjork. all my other 15000 tracks work, but if i try to listen to anything from my Bjork folder, foobar crashes.
Exactly the cause! FFB was set to 10000kB. At "0", the streams work. Thank you!
Could you give a better description, as I can't reproduce trying with either...
Ok. OS: WinXP, Portable installation.
1) Run player, Ctrl+P, go to Tools->Converter. On the right side press "Add New" button.
2) Create new preset like this: .
Press OK, Then Apply and OK. Pay attention to wrong encoder's file name(It's done on purpose).
3) Put lame.exe into player's directory. And try to convert something. Player will ask you to choose file. Press cancel. Let's correct it..
4) Go to Preferences and edit lame1.exe to lame.exe.
5) In the dialog "Convert Setup" combobox "Output format" contains two presets with the same name. One of them is working properly (new one), and the second isn't. If we simply choose "convert->[last used]" we will get an error.
is it normal behavior?.
