Topic: Spotify theme (Read 11459 times) previous topic - next topic
Spotify theme
Hello!
I wonder if anyone know a theme to foobar2000 which looks like spotify.
You can check how it looks like, very simple but also very nice!
http://techblogger08.files.wordpress.com/2009/09/spotify.png
I will be very happy if anyone can find a theme like that or
maybe got the skills/time to make one!
Best Regards Rank1
Spotify theme
Try foo_facets.
Spotify theme
I guess there's a filter panel in columns ui that does the job.
Spotify theme
Spotify theme
Maybe you should update Columns UI to the latest version...
Spotify theme
Also, if you didn't notice from my screenshot, I pretty much helped you out with your layout
Spotify theme
Since this thread is not so old I borrow it.
I'm using filter as well but I want to change its position.
This is how it look like.
And I want to lower it abit so it's line with the NG playlist, like this:
In layout setting I have inserted a "Vertical splitter / Filter" under "Panel Stack Splitter".
Is there a way to fix it?
Spotify theme
I don't know your exact layout, but you could try putting NG Playlist and filter in a horizontal spliiter and do something like this...
Spotify theme
It's under "Playlist tabs" and it can't hold more than one panel. And if I change it to another splitter the playlist tabs disappers.
Spotify theme
you went to all that effort uploading that screenshot but didn't think of trying to put the splitter under playlist tabs?
