Topic: EAC Burning Error: Invalid field in CDB (Read 3845 times) previous topic - next topic
When using BurnProof in EAC the cd-r will burn all the way to the end then produce this error.  As I am trying to compute the write offset when using the wavs off of the burnt copy the Compare Wav window produces no result also
Drive Model: HL-DT-ST DVD-RAM  GSA-4084N
Write Error !
Load/Eject CD :
Can anyone further explain what is happening?
Is it possible for my drive to be able to rip but not burn wavs through EAC?
I found what was going on to be the Cdrdao option needed to be enabled.  This seems to have fixed the problem as the burn finished successfully.
