Topic: mp3DirectCut - cut, split, fade and record mp3s (Read 36268 times) previous topic - next topic
Re: mp3DirectCut - cut, split, fade and record mp3s
It is very useful... and runs with wine on linux
The most important audio cables are the ones in the brain
  - UTF-8 character encoding for cue, project and ini files
  - Inernal ANSI/Win98 compatibility removed
  - Checking 4GB size limit
  - Cut noise mute function
  - Settings button in the toolbar
  - Graph font localization issues fixed
  - Some other corrections and improvements
http://mpesch3.de
- Multilanguage support changed to UTF-8
- Bright symbols layout for smaller window width
- Lots of minor improvements
https://mpesch3.de/
Keep up the good work!
Glass half full!
- Possible startup crash fixed (on text button layout set)
- Some minor improvements and corrections
https://mpesch3.de/
Reply #30
https://mpesch3.de/
Thans for this.
How does the "Cut noise mute function" work? There's no entry in the manual and I cannot figure it out / get it to work.
- Level activated recording feature
- Batch search and path fields reacting on killfocus
- Larger range of graph level adjustment (Num +/-)
- Some more improvements
https://mpesch3.de
Does not work for me, doesn't accept cue file formats and you can't even uninstall it..beware
Reply #33
what do you mean by "beware"?
wagner reatto
Reply #34
- Cue sheet load problem (wrong null char) fixed
- Longer delay time for tooltips
- Check for overdrive function (Normalize)
- Fixed garbage bytes on Xing header creation
- Some corrections
https://mpesch3.de/
Reply #35
- Overdrive check feature removed (inacurate detection possible)
- Minor corrections
https://mpesch3.de/
Reply #36
- Tooltip glitch fixed
- Timeline overflow fixed
- Audio display glitches fixed
https://mpesch3.de/
Reply #37
- Titles in total view
- Reading of M3U playlists
- Possible multi selection on open
- Direct append without clipboard
- Copying multiple filenames to titles
- Fast play improved
- Cue time stamp for Split
- Arrows on scrollbar option
https://mpesch3.de/
Reply #38
Windows is adamant that it contains a virus. Is there any way around that? Tried a couple download sites.
Reply #39
Then your ISP or your computer is inserting a virus into it. The file I just downloaded from FOSShub, freshly uploaded to Virustotal, registers a 0 out of all scanners.
Reply #40
Thanks, the FOSShub download was successful.  Win 10 threw up an "unrecognized app" warning, but did not delete the download as it did with my earlier attempts.
FWIW, this was the previous result:
Same for d/l from MajorGeeks.
Reply #41
LosslessCut is a (better, IMHO) open source alternative:
https://github.com/mifi/lossless-cut
Hybrid Multimedia Production Suite will be a platform-indipendent open source suite for advanced audio/video contents production.
Official git: https://forart.it/HyMPS/
Reply #42
OK, so how do you use LosslessCut to (coarsly) fade an mp3 without re-encoding? Is that more convenient than using mp3directcut to view video files to set cut marks?
Different tools for different tasks, this thread is about one of them and not for spamming the other.
Reply #43
Fading volume CAN'T be lossless AFAIK.
Reply #44
The MP3 format can shift volume in 1.5 dB steps. One can achieve a coarse fading effect by successive 1.5 dB volume changes, and mp3directcut can do that.
Now, what is even the purpose of trying to hijack the mp3directcut thread to peddle some ffmpeg video cutting frontend?
Reply #45
- Crash on reaching end of certain files fixed
- Multi file graph glitch corrected
- Multi file opening bug fixed
- Natural numerical ordering in batch list
- Batch hides unsupported extensions
https://mpesch3.de/
Reply #46
- DPI awareness
- File size in MB in batch list
- Possible bug on file dropping fixed
- Some modifications and corrections
https://mpesch3.de/
Reply #47
- Own volume slider storage
- Info header save option
- Batch dialog improvements
- Some corrections
https://mpesch3.de/
Reply #48
For same reason as above, Win 10 is now blocking download from any of the distribution sites.
