Topic: 32 bit Float or Linear? (Read 11315 times) previous topic - next topic
What is the technical difference between 32 bit float and linear?
That's like comparing apples and oranges. Please re-formulate your question in a more understandable way, or at least in a context.
What makes it either 'linear' or 'float.'
Is 32 bit linear mathematically the same as 32 bit float?
Is linear different to float when it comes to dsp?
32bit linear = 32bit integer, it contains whole-number values within a certain fixed range, just like 16 bit linear contains integer values from -32767 to 32768.  And then 32bit floating point contains, well, floating point values, fractional number values.  I believe, and I could be wrong, it is a 24bit fractional number with an 8 bit exponent or modifier component.  Not sure I have the exponent/modifier description correct, but I think that's how it works.  Almost 3am here and I'm just about to hit the hay so I'm a little hazy at the moment
<edit> and please correct me if I'm wrong (as I most possibly could be)
The right word would be "integer" or better fixed point, instead of "linear". So, 32 bit float gives more flexibility when comes to DSP, as opposed to 32 bit fixed point.
As to the exact meaning of the terms  floating point vs. fixed point, it's a bit complicated for me to explain now, I'm somewhat in a hurry, but just do a Google search.
is there an audible difference which can be heared by the human ear? Does it affect output quality if using floating point or integer?
Celeron 1300 Tualatin @ 1589, 512 MB Micronchip CL2, 0,5 TB HD, Audigy 2 ZX Platinum Pro, Sony MDS-JE530 DAC, Sony STR-GX 311 Ampifier, Sennheiser HD 570 Headphones, Creative Inspire T7700 7.1
If you mean at Foobar, 32 bit float. point output won't give better quality than 24 fixed point. bit output, due to real-world limitations of hardware. If you don't have a 24 bit card, output at anything higher than 16 bit will give worse quality.
I liked the 1500dB remark, but it made me think.  Would it not be possible to use the bits to give you better volume resolution within the same dynamic range?  Granted, we can only hear so much difference in volume, but you'd think it could still make a difference in certain situations.
I guess our soundcards end up being the 'bottleneck' in quality, being only 16 - 24 bit integer.
Compatibility?
I wonder whether 32 bit audio is constant across different programs like linear is.
E.G. would a 32 bit float WAV from Foobar2000 work the same if played back in 32 bit Cubase?
32 bit float is a standard wav format. I've used Foobar to convert an mp3 to 32 bit float for editing in Steinberg WaveLab 4 and Cool Edit Pro. I have no doubt Cubase will also work, although I've never tried it.
true, but for intermediate editing etc was what I was thinking.  I guess it'd be largely if not wholy imperceptible anyways.  I was just thinking that a similar concept in graphics might apply.  While 24bit colour should be enough for a given picture, when blending a lot of things together to get the finished picture, as they do in games, you sometimes get an accumulation of errors which results in visible banding in the finished image.  And now video card manufacturers are starting to use 64bit and 128bit colour to combat that, among other things.
You're certainly right about that. It's best to work in the highest bitrate that your software/hardware will allow, then master down to your target -- for example, 16 bits with dithering. Foobar works the same way.
Naw, I'd say it's more like our ears being the 'bottleneck' in quality, only perceiving a maximum of 17/18 bit quality, in very, very rare circumstances.
Note: numbers are somewhat subjective, but apparently it is very, very difficult to notice bit-difference at the 16-bit level. Thus, would it be correct to say that our ears can perceive 17 or 18 bit max?
Floating point allows one or the other, or anything inbetween.
The max. theorical dynamic range of human ear is around 120 dB (equivalent to 20 bit). 0 dB is around the lowest we can hear (IIRC in practice it's a little bit less, <0 dB can be audible), and at the threshold of pain is around 120 dB.
But this is all under ideal conditions. In practice all listening rooms have a noise floor of around 30 dB and more, and I guess nobody wants to reach the 120 dB pain limit of his ears
I believe that under real world conditions, 16 bit is above the usual range of operation of our ears.
As 32 bit float has a resolution well beyond (according to the creators of Cubase) 32 bit linear, could 32 bit float be likened to a form of lossless compression?
They're both 32 bits - they both have exactly the same 'resolution'.
You could say that 32 bits linear has more accuracy and 32 bits float has more range.
There is no relation to lossless compression.
Ok... now i am so confused.  I have a M-Audio Revolution... which should I use?  24bit, 32bit linear, or 32 float?
Ok... now i am so confused.  I have a M-Audio Revolution... which should I use?  24bit, 32bit linear, or 32 float?  :blink:
You should use 24 bit dithered.
And in the future, please search the forums before asking.
I did. I searched for m-audio revolution and found nothing saying if it supported 32bit.
So my Revo card doesn't support either of those 32bit settings?  If so, what the hell am I supposed to use in Cool Edit Pro?  I want to take advantage of my cards 24bit recording capability, but Cool Edit only allows 16 or 32bit recording.  So I've just been using 32bit floating point, and it seemed to work fine.
P.S. In Foobar, should I keep dither on?
Now that I think about it, why do we even have to choose which resolution to have all audio played at?  Why doesn't foobar just play a file at whatever the resolution of that file is?  Like, if u load and play a 16bit mp3 or wave file then it playes back at 16bits, unchanged.  Then in the same playlist, u play a 24bit wave file and it is plays back at 24bits, unchanged.  And the same for 32bits.
because if you have a 16bit mp3 and it's using a replaygain value then you are losing data if you play it back as 16bit vs 24bit
and if u play back a 24bit file using replay gain at 24bits it would loose data?
Is that why 32bit was brought about?  for things to be done with the 24bit files without loosing data?  like headroom?
so thats why cooledit does all its mixing in 32 bit even on 16bit tracks.... oooooohh
There is no 16 bit mp3.
