Topic: XLD found problems and bug list (Read 77732 times) previous topic - next topic
Reply #50
I'm using XLD to rip CD's to FLAC files. I'm using "Allow to embed cue sheet" and ripping as "Save as single file (+ cue)".
After creating the FLAC file, I intend to extract the tracks as MP3 an add them into iTunes.
I plan to use Max for that, so that I don't need to keep changing the XLD preferences everytime.
When I try to open the FLAC file in Max, it says it can't find the a cue sheet in the file.
It works ok if I open the CUE file.
I used metaflac in some of the FLAC files I've already created and it says that "FLAC file has no CUESHEET block".
Here is the command I tried and the result:
$ metaflac --export-cuesheet-to=- Creedence\ Clearwater\ Revival\ -\ Chronicle\,\ Vol.\ 1.flac
Creedence Clearwater Revival - Chronicle, Vol. 1.flac: ERROR: FLAC file has no CUESHEET block
It appears that XLD isn't embedding the cue sheet as I understand it was supposed to.
Am I doing something wrong, or is this an actual bug?
My configuration: MacBook Pro (Mid-2009), Leopard (10.5.8), XLD (20090924).
Best regards!
Reply #51
This is to echo DNOBel's problem on page 2, where there don't seem to be any solutions for....yet.
My (Test) gets to 25% then just hangs and reads 0.0x, 783:45 remaining. It hasn't even begun ripping the audio file yet. It has satyed like this for an hour so I shut off my machine before it ignited in flames.
my machine prefs:
OS 10.6.1
Macbook Intel Core 2 Duo, 2gHz
drive: MATSHITA CD-RW  CW-8221
XLD Version 20090924 (109.9)
using Lame MP# encoder
all the following are checked:
CD Paranoia Mode
Offset correction value 102
Query AccurateRip database to check integrity
Verify suspicious sectors
TEst before copy
apparently, the same issue as this guy:
I am having an issue with XLD effectively hanging when trying to rip certain CDs with little to no visible damage. With some of them, the problem starts right away when XLD takes forever to read the gap info. In all cases, the ripping of one or more (or all) tracks slows to a virtual crawl, registering "0.0 x" rip speed and showing many hundreds or thousands of minutes to finish ripping a single track.
All of these discs play back without problems in all my CD players and will play from the same drive in iTunes. I can also rip them no prob in Max.
I have listed my machine specs and XLD rip prefs below.
Anybody have any ideas to resolve this? This is kind of a pain.
Machine and set-up:
2 Ghz DP G5
OS 10.5.5
Pioneer DVR-107D
XLD version  20080926 (93.3)
XLD CD rip prefs (checked or with values entered):
Rip as accurate as possible
Max retry count: 100
Offset correction: 48 (auto)
Query AccurateRip
Automatically save log file: Always
Test before copy: only when track does not exist in AccurateRip DB
Reply #52
Did you contact the developer (write a mail)? He tends to react to bug reports (he did to mine at least). I don't think he reads this forum though.
Reply #53
I too sometimes see xld taking ages or hanging in the pregap detection phase. not sure what causes this but it would be great to have a.) the option to turn of pregap detection, b.) have a cancel button.
otherwise this is an excellent app!
Reply #54
wow - skipping pre-gap just got added. awesome responsiveness by the devs. thx so much and happy new year
Reply #55
while trying to rip two lightly scratched cd's xld made no progress for hours on certain tracks. hitting cancel did nothing so ultimately I had to force-quit the app.  xld will disappear from the active processes list in activity monitor but the icon will stay in both the dock and the taskbar. also the cd will stay in the drive which can't be accessed by any other application.
restarting finder does not fix this. restart required. problem is reproducible for me. mabook 4.1., osx 10.5.8, uj-857e drive.
anybody else seeing similar problems?!
thx!
Reply #56
thx!
This has been a problem for some time.
I found a way at one point to eject the disk using another application without having to restart. It was a while ago, but I think Rip did it ... perhaps iTunes too.
A graceful exit from a hung up rip is one of the last parts missing from XLD.
Reply #57
I suspect that this problem is caused by a hung, or thrashing, cdparanoia.  cdparanoia will try very hard to extract data from a damaged CD and can become unresponsive and impossible to quit at times.  At least, I've experienced that behavior when ripping a bad disc with the command line cdparanioa and then the same problem when ripping with paranoia turned on in XLD.
Reply #58
When trying to get CD Track names (CDDB) with XLD Version 20091230 (115.2), the application crashes.
This was with Disney's Princess and the Frog Soundtrack
Process:         XLD [1206]
Path:            /Applications/XLD.app/Contents/MacOS/XLD
Identifier:      jp.tmkk.XLD
Version:        20091230 (115.2)
Code Type:      X86 (Native)
Parent Process:  launchd [175]
Date/Time:      2010-01-04 17:45:50.310 -0800
OS Version:      Mac OS X 10.6.2 (10C540)
Report Version:  6
Interval Since Last Report:          660056 sec
Crashes Since Last Report:          9
Per-App Interval Since Last Report:  1548 sec
Per-App Crashes Since Last Report:  6
Anonymous UUID:                      FDF3280B-A366-4074-9608-0B389E8139CC
Exception Type:  EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000008
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
0  Musicbrainz                  0x0008aedd MusicBrainz::Artist::getName() const + 13
1  jp.tmkk.XLD                  0x0002c308 -[XLDCDDBUtil query] + 878
2  jp.tmkk.XLD                  0x000162da -[XLDController cddbGetTracksWithAutoStart:] + 489
3  com.apple.AppKit              0x98d34f86 -[NSApplication sendAction:to:from:] + 112
4  com.apple.AppKit              0x98d34e39 -[NSMenuItem _corePerformAction] + 435
5  com.apple.AppKit              0x98d34b2a -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 174
6  com.apple.AppKit              0x98d34a16 -[NSMenu performActionForItemAtIndex:] + 65
7  com.apple.AppKit              0x98d349c9 -[NSMenu _internalPerformActionForItemAtIndex:] + 50
8  com.apple.AppKit              0x98d3492f -[NSMenuItem _internalPerformActionThroughMenuIfPossible] + 97
9  com.apple.AppKit              0x98d34873 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 336
10  com.apple.AppKit              0x98d28f79 NSSLMMenuEventHandler + 404
11  com.apple.HIToolbox          0x90aebe29 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
12  com.apple.HIToolbox          0x90aeb0f0 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
13  com.apple.HIToolbox          0x90b0d981 SendEventToEventTarget + 52
14  com.apple.HIToolbox          0x90b39e3b SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448
15  com.apple.HIToolbox          0x90b5eb20 SendMenuCommandWithContextAndModifiers + 66
16  com.apple.HIToolbox          0x90b5ead7 SendMenuItemSelectedEvent + 121
17  com.apple.HIToolbox          0x90b5e9d3 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 152
18  com.apple.HIToolbox          0x90b2e212 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 440
19  com.apple.HIToolbox          0x90b2d9a9 _HandleMenuSelection2 + 465
20  com.apple.HIToolbox          0x90b2d7c7 _HandleMenuSelection + 53
21  com.apple.AppKit              0x98d224ba _NSHandleCarbonMenuEvent + 285
22  com.apple.AppKit              0x98cf7076 _DPSNextEvent + 2304
23  com.apple.AppKit              0x98cf6306 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
24  com.apple.AppKit              0x98cb849f -[NSApplication run] + 821
25  com.apple.AppKit              0x98cb0535 NSApplicationMain + 574
26  jp.tmkk.XLD                  0x00002a9a _start + 216
27  jp.tmkk.XLD                  0x000029c1 start + 41
Thread 1:  Dispatch queue: com.apple.libdispatch-manager
0  libSystem.B.dylib            0x94b040ea kevent + 10
1  libSystem.B.dylib            0x94b04804 _dispatch_mgr_invoke + 215
2  libSystem.B.dylib            0x94b03cc3 _dispatch_queue_invoke + 163
3  libSystem.B.dylib            0x94b03a68 _dispatch_worker_thread2 + 234
4  libSystem.B.dylib            0x94b034f1 _pthread_wqthread + 390
5  libSystem.B.dylib            0x94b03336 start_wqthread + 30
Thread 2:
0  libSystem.B.dylib            0x94b03182 __workq_kernreturn + 10
1  libSystem.B.dylib            0x94b03718 _pthread_wqthread + 941
2  libSystem.B.dylib            0x94b03336 start_wqthread + 30
Thread 3:
0  libSystem.B.dylib            0x94add8da mach_msg_trap + 10
1  libSystem.B.dylib            0x94ade047 mach_msg + 68
2  com.apple.CoreFoundation      0x94d3377f __CFRunLoopRun + 2079
3  com.apple.CoreFoundation      0x94d32864 CFRunLoopRunSpecific + 452
4  com.apple.CoreFoundation      0x94d32691 CFRunLoopRunInMode + 97
5  com.apple.Foundation          0x91001430 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 329
6  com.apple.Foundation          0x90fc88d8 -[NSThread main] + 45
7  com.apple.Foundation          0x90fc8888 __NSThread__main__ + 1499
8  libSystem.B.dylib            0x94b0afbd _pthread_start + 345
9  libSystem.B.dylib            0x94b0ae42 thread_start + 34
Thread 4:
0  libSystem.B.dylib            0x94afc856 select$DARWIN_EXTSN + 10
1  com.apple.CoreFoundation      0x94d72ddd __CFSocketManager + 1085
2  libSystem.B.dylib            0x94b0afbd _pthread_start + 345
3  libSystem.B.dylib            0x94b0ae42 thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
  eax: 0x00000000  ebx: 0x00615040  ecx: 0x006b5760  edx: 0x006b5768
  edi: 0x15831d00  esi: 0xbfffea68  ebp: 0xbfffe9c8  esp: 0xbfffe9b0
  ss: 0x0000001f  efl: 0x00010282  eip: 0x0008aedd  cs: 0x00000017
  ds: 0x0000001f  es: 0x0000001f  fs: 0x00000000  gs: 0x00000037
  cr2: 0x00000008
Binary Images:
    0x1000 -    0x5efe7 +jp.tmkk.XLD 20091230 (115.2) <E2FE6829-8A92-485B-8E9A-2CF974B834F7> /Applications/XLD.app/Contents/MacOS/XLD
  0x73000 -    0x7efff +CDDB ??? (???) /Applications/XLD.app/Contents/Frameworks/CDDB.framework/Versions/A/CDDB
  0x8a000 -    0xebfcf +Musicbrainz ??? (???) /Applications/XLD.app/Contents/Frameworks/Musicbrainz.framework/Versions/A/Musicbrainz
  0x152000 -  0x174fdf +Cdio ??? (???) /Applications/XLD.app/Contents/Frameworks/Cdio.framework/Versions/A/Cdio
  0x18c000 -  0x1e7fe7 +Sndfile ??? (???) <5486AA14-2EB2-4708-9100-B8BA6C13247F> /Applications/XLD.app/Contents/Frameworks/Sndfile.framework/Versions/A/Sndfile
  0x29b000 -  0x29dfff +net.culater.SIMBL 0.8.2 (8) /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL
  0x2e2000 -  0x2e9ff3 +jp.tmkk.XLDAacOutput ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDAacOutput.bundle/Contents/MacOS/XLDAacOutput
  0x2ef000 -  0x2f9ffb +jp.tmkk.XLDAacOutput2 ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDAacOutput2.bundle/Contents/MacOS/XLDAacOutput2
  0x789000 -  0x78dffb +jp.tmkk.XLDAlacDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDAlacDecoder.bundle/Contents/MacOS/XLDAlacDecoder
  0x793000 -  0x79afff +jp.tmkk.XLDAlacOutput ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDAlacOutput.bundle/Contents/MacOS/XLDAlacOutput
  0x79f000 -  0x7bafe5 +jp.tmkk.XLDApeDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDApeDecoder.bundle/Contents/MacOS/XLDApeDecoder
  0x7c8000 -  0x7caff3 +jp.tmkk.XLDFlacDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDFlacDecoder.bundle/Contents/MacOS/XLDFlacDecoder
  0x7cf000 -  0x7d4fd3 +Ogg ??? (???) /Applications/XLD.app/Contents/Frameworks/Ogg.framework/Versions/A/Ogg
  0x7db000 -  0x7defff +jp.tmkk.XLDFlacOutput ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDFlacOutput.bundle/Contents/MacOS/XLDFlacOutput
  0x7e4000 -  0x7e9fff +jp.tmkk.XLDHEAACOutput ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDHEAACOutput.bundle/Contents/MacOS/XLDHEAACOutput
  0x7ee000 -  0x7efffb +jp.tmkk.XLDLibsndfileDecoder ??? (1.0) <A3003289-D079-46A0-ABA4-C23BCADEF830> /Applications/XLD.app/Contents/PlugIns/XLDLibsndfileDecoder.bundle/Contents/MacOS/XLDLibsndfileDecoder
  0x7f4000 -  0x7f5ffb +jp.tmkk.XLDMP3Decoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDMP3Decoder.bundle/Contents/MacOS/XLDMP3Decoder
  0x7fa000 -  0x7fafff +jp.tmkk.XLDSparkleUpdater ??? (1.0) <FEC6C495-3DB7-4083-B9FD-DE45448D9EBC> /Applications/XLD.app/Contents/PlugIns/XLDSparkleUpdater.bundle/Contents/MacOS/XLDSparkleUpdater
 0x2559000 -  0x25a0fd7 +FLAC ??? (???) /Applications/XLD.app/Contents/Frameworks/FLAC.framework/Versions/A/FLAC
 0x25bd000 -  0x25c4fef +jp.tmkk.XLDShortenDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDShortenDecoder.bundle/Contents/MacOS/XLDShortenDecoder
 0x25cc000 -  0x25dffff +org.andymatuschak.Sparkle 1.5 Beta (bzr) (1.5) <C1C2F3B9-7EC8-116D-B7C6-4900BAAF3197> /Applications/XLD.app/Contents/PlugIns/XLDSparkleUpdater.bundle/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
 0x25ed000 -  0x25f0ff3 +jp.tmkk.XLDTtaDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDTtaDecoder.bundle/Contents/MacOS/XLDTtaDecoder
 0x25f5000 -  0x25f7ff3 +jp.tmkk.XLDWavpackDecoder ??? (1.0) <ADCD0EC9-B288-4A67-94C4-18A9F7C1F930> /Applications/XLD.app/Contents/PlugIns/XLDWavpackDecoder.bundle/Contents/MacOS/XLDWavpackDecoder
0x12f8d000 - 0x12fc5fff +com.yourcompany.yourcocoabundle ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDLameOutput.bundle/Contents/MacOS/XLDLameOutput
0x12fe2000 - 0x13097fe7  libcrypto.0.9.7.dylib ??? (???) <4917E4F2-817F-5AC4-3FBE-54BC96360448> /usr/lib/libcrypto.0.9.7.dylib
0x130dd000 - 0x130fcfff +jp.tmkk.XLDVorbisOutput ??? (1.0) <1B74F58F-4102-47D9-BB81-3486963A8C84> /Applications/XLD.app/Contents/PlugIns/XLDVorbisOutput.bundle/Contents/MacOS/XLDVorbisOutput
0x13229000 - 0x13252fe3 +WavPack ??? (???) <A9286F5E-D2B3-4AA4-95E6-9E27AF1AD5B8> /Applications/XLD.app/Contents/Frameworks/WavPack.framework/Versions/A/WavPack
0x13261000 - 0x13264fff +jp.tmkk.XLDWavpackOutput ??? (1.0) <55E6C932-1F36-40CA-BC9E-16612B36789F> /Applications/XLD.app/Contents/PlugIns/XLDWavpackOutput.bundle/Contents/MacOS/XLDWavpackOutput
0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <211AF0DD-42D9-79C8-BB6A-1F4BEEF4B4AB> /usr/lib/dyld
0x90003000 - 0x9000eff7  libCSync.A.dylib ??? (???) <9292E6E3-70C1-1DD7-4213-1044F0FA8381> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x9000f000 - 0x9000fff7  com.apple.vecLib 3.5 (vecLib 3.5) <17BEEF92-DF30-CD52-FD65-0B7B43B93617> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x90057000 - 0x900ffffb  com.apple.QD 3.33 (???) <196CDBA6-5B87-2767-DD57-082D71B0A5C7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x9010e000 - 0x9010eff7  com.apple.Accelerate.vecLib 3.5 (vecLib 3.5) <3E039E14-2A15-56CC-0074-EE59F9FBB913> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x9010f000 - 0x9011fff7  libsasl2.2.dylib ??? (???) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x90120000 - 0x90148ff7  libxslt.1.dylib ??? (???) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
0x90433000 - 0x90474ff7  libRIP.A.dylib ??? (???) <9F0ECE75-1F03-60E4-E29C-136A27C13F2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x90475000 - 0x907dcff7  com.apple.QuartzCore 1.6.1 (227.8) <8B90AB08-46A4-1C5C-4E71-C6AB652477B9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x90827000 - 0x90928fe7  libxml2.2.dylib ??? (???) <B4C5CD68-405D-0F1B-59CA-5193D463D0EF> /usr/lib/libxml2.2.dylib
0x90929000 - 0x909fafe3  ColorSyncDeprecated.dylib ??? (???) <1CEB1F35-EF10-A63D-AD9E-D7BD391D4719> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x909fb000 - 0x90a16ff7  libPng.dylib ??? (???) <3F8682CD-C05B-607D-96E7-767646C77DB8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x90ae4000 - 0x90e07fef  com.apple.HIToolbox 1.6.2 (???) <E02640B9-7BC3-A4B4-6202-9E4127DDFDD6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x90e38000 - 0x90f02fef  com.apple.CoreServices.OSServices 352 (352) <D9F21CA4-EED0-705F-8F3C-F1322D114B52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90f03000 - 0x90f85ffb  SecurityFoundation ??? (???) <29C27E0E-B2B3-BF6B-B1F8-5783B8B01535> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x90fb2000 - 0x91222ffb  com.apple.Foundation 6.6.1 (751.14) <CD815A50-BB33-5AA1-DD73-A5B07D394DDA> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x91223000 - 0x91235ff7  com.apple.MultitouchSupport.framework 204.9 (204.9) <B639F02B-33CC-150C-AE8C-1007EA7648F9> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x91236000 - 0x91239ff7  libCGXType.A.dylib ??? (???) <483FCF1C-066B-D210-7355-ABC48CA9DB2F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x9123a000 - 0x9123aff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x9123b000 - 0x9128bff7  com.apple.framework.familycontrols 2.0 (2.0) <E6CAB425-3E40-65A3-0C23-150C26E9CBBF> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x912ab000 - 0x912e0ff7  libcups.2.dylib ??? (???) <BE4E095C-EECA-017E-11AA-C65F4D2B15C8> /usr/lib/libcups.2.dylib
0x9133a000 - 0x9133cff7  libRadiance.dylib ??? (???) <462903E2-2E77-FAE5-4ED6-829AAB1980A4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x913d8000 - 0x913dcff7  libGIF.dylib ??? (???) <83FB0DCC-355F-A930-E570-0BD95086CC59> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x913dd000 - 0x913e0ff7  libCoreVMClient.dylib ??? (???) <A89D7A78-8FB0-2BDF-30DB-A35E04A6186B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x91501000 - 0x91527fff  com.apple.DictionaryServices 1.1.1 (1.1.1) <02709230-9B37-C743-6E27-3FCFD18211F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x91599000 - 0x9168bff7  libcrypto.0.9.8.dylib ??? (???) <792B8722-3091-5E9F-E25F-67499CFE0599> /usr/lib/libcrypto.0.9.8.dylib
0x9173c000 - 0x9173cff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x9173d000 - 0x91786fe7  libTIFF.dylib ??? (???) <5864AE5B-EAEB-F8B6-18FB-3D27B7895A4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91836000 - 0x91856fe7  com.apple.opencl 12 (12) <2DB56F60-577B-6724-5708-7B082F62CC0F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x91857000 - 0x918b1ff7  com.apple.framework.IOKit 2.0 (???) <1BE07087-27D5-0E62-F06B-007C2BED4073> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x91909000 - 0x9192dff7  libJPEG.dylib ??? (???) <649E1974-A527-AC0B-B3F4-B4DC30484070> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x9192e000 - 0x91acbfef  com.apple.JavaScriptCore 6531.21 (6531.21.9) <FF236E3F-A016-2AEB-3E62-7108E76EF825> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x91c26000 - 0x91da8fe7  libicucore.A.dylib ??? (???) <2B0182F3-F459-B452-CC34-46FE73ADE348> /usr/lib/libicucore.A.dylib
0x92097000 - 0x92253fef  com.apple.ImageIO.framework 3.0.1 (3.0.1) <598CF4F9-7542-E1A7-26D2-584933497A2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x92296000 - 0x922a0fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x922e8000 - 0x922f6fe7  libz.1.dylib ??? (???) <7B7A02AB-DA99-6180-880E-D28E4F9AA8EB> /usr/lib/libz.1.dylib
0x922f7000 - 0x92393fe7  com.apple.ApplicationServices.ATS 4.1 (???) <EA26375D-8276-9671-645D-D28CAEC95292> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x926b9000 - 0x926f6ff7  com.apple.SystemConfiguration 1.10.1 (1.10.1) <BA676C76-6AAD-F630-626D-B9248535294D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x92708000 - 0x9270dff7  com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9270e000 - 0x92723fff  com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x928a7000 - 0x92955ff3  com.apple.ink.framework 1.3.1 (105) <CA3FBDC3-4BBA-7BD9-0777-A7B0751292CD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92956000 - 0x92972fe3  com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x92973000 - 0x929b6ff7  com.apple.NavigationServices 3.5.3 (181) <28CDD978-030E-7D4A-5334-874A8EBE6C29> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x929b7000 - 0x92a26ff7  libvMisc.dylib ??? (???) <59243A8C-2B98-3E71-8032-884D4853E79F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x92a29000 - 0x92a35ff7  libkxld.dylib ??? (???) <3D2C5BA3-6A8D-C861-B346-0E19942D9AF1> /usr/lib/system/libkxld.dylib
0x92a36000 - 0x92a6cfff  libtidy.A.dylib ??? (???) <DDFAB560-3883-A6A2-7BDD-D91730982B48> /usr/lib/libtidy.A.dylib
0x92a6d000 - 0x92abdfe7  libGLU.dylib ??? (???) <659ADCA2-10EC-59BD-1B0A-4928A965F1D1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92b3a000 - 0x92b8bff7  com.apple.HIServices 1.8.0 (???) <B8EC13DB-A81A-91BF-8C82-66E840C64C91> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x92b8c000 - 0x92b8cff7  com.apple.Carbon 150 (152) <608A04AB-F35D-D2EB-6629-16B88FB32074> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92b8d000 - 0x92b8dff7  com.apple.Accelerate 1.5 (Accelerate 1.5) <F642E7A0-3720-FA19-0190-E6DBD9EF2D9B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x92b8e000 - 0x92b8fff7  com.apple.TrustEvaluationAgent 1.1 (1) <6C04C4C5-667E-2EBE-EB96-5B67BD4B2185> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x92bc3000 - 0x92bc9ff7  libCGXCoreImage.A.dylib ??? (???) <5233872A-EAC6-1D42-3959-6CE6C5DEB931> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x92bd2000 - 0x92c6ffe3  com.apple.LaunchServices 362 (362) <8BE1C1A1-BF71-CE07-F3FB-6057D47AF461> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x92ca8000 - 0x92f0aff7  com.apple.security 6.0 (36910) <32B8FA26-CD73-4C45-C15A-EF8406D51FCC> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x92f0b000 - 0x92f51ff7  libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib
0x92f5a000 - 0x93088fe7  com.apple.CoreData 102.1 (250) <F33FF4A1-D7F9-4F6D-3153-E5F2588479EB> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x93089000 - 0x93109feb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x940d2000 - 0x940d6ff7  IOSurface ??? (???) <C11D3FF3-EB51-A07D-EF24-9C2004115724> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x940d7000 - 0x94901fe7  com.apple.WebCore 6531.21 (6531.21.8) <A1527339-942C-164F-03CB-0949EEA144C4> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x94942000 - 0x94942ff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9499e000 - 0x949d3ff7  libGLImage.dylib ??? (???) <A6007BF7-BF3C-96DC-C435-849C6B88C58A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x949db000 - 0x949fbfe7  libresolv.9.dylib ??? (???) <A48921CB-3FA7-3071-AF9C-2D86FB493A3A> /usr/lib/libresolv.9.dylib
0x949fc000 - 0x94ad9ff7  com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x94add000 - 0x94c81feb  libSystem.B.dylib ??? (???) <D45B91B2-2B4C-AAC0-8096-1FC48B7E9672> /usr/lib/libSystem.B.dylib
0x94cf7000 - 0x94e6efef  com.apple.CoreFoundation 6.6.1 (550.13) <AE9FC6F7-F0B2-DE58-759E-7DB89C021A46> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x94e6f000 - 0x94e87ff7  com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x94e93000 - 0x94f2bfe7  edu.mit.Kerberos 6.5.9 (6.5.9) <73EC847F-FF44-D542-2AD5-97F6C8D48F0B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x94f2c000 - 0x94f5dff3  libTrueTypeScaler.dylib ??? (???) <6C8916A2-8F85-98E0-AAD5-0020C39C0FC9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x9548e000 - 0x954eefe7  com.apple.CoreText 3.1.0 (???) <79FD1B5C-2F93-4C5D-B07B-4DD9088E67DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x954ef000 - 0x95529ffb  libFontRegistry.dylib ??? (???) <72342297-E8D6-B071-A752-014134129282> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x9552a000 - 0x9552dfe7  libmathCommon.A.dylib ??? (???) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x9554e000 - 0x95592fe7  com.apple.Metadata 10.6.2 (507.4) <DBCBAE7D-7B34-7806-C0B9-1E6E6D45562F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x95a42000 - 0x95a45ffb  com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x95a46000 - 0x95a53ff7  com.apple.opengl 1.6.5 (1.6.5) <0AE8B897-8A80-2C14-D6FC-DC21AC423234> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x95ac9000 - 0x95badff7  com.apple.WebKit 6531.21 (6531.21.8) <E2506911-46B5-0CFE-0C49-77EA8F216E8C> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x95bae000 - 0x95ecdfe7  com.apple.CoreServices.CarbonCore 861.2 (861.2) <A9077470-3786-09F2-E0C7-F082B7F97838> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x95ece000 - 0x95eceff7  com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x95ed1000 - 0x95f3bfe7  libstdc++.6.dylib ??? (???) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x95f5e000 - 0x96052fe7  libiconv.2.dylib ??? (???) <0C578460-3929-29DD-585A-DB1E0C977425> /usr/lib/libiconv.2.dylib
0x96279000 - 0x962a3ff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x96445000 - 0x9644cfff  com.apple.print.framework.Print 6.0 (237) <7A06B15C-B835-096E-7D96-C2FE8F0D21E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9644d000 - 0x9648ffe7  libvDSP.dylib ??? (???) <8F8FFFB3-81E3-2969-5688-D5B0979182E6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x96490000 - 0x964c3ff7  com.apple.AE 496.1 (496.1) <1AC75AE2-AF94-2458-0B94-C3BB0115BA4B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x965bc000 - 0x96600ff3  com.apple.coreui 2 (113) <D0FA9B36-3708-D5BF-0CC3-6CC1909BC8E6> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x96601000 - 0x96615ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x96616000 - 0x96742fe3  com.apple.audio.toolbox.AudioToolbox 1.6.1 (1.6.1) <C226DF5C-35B0-98B8-95ED-FE5FE24E62C8> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x96743000 - 0x9674dff7  libGL.dylib ??? (???) <76A207FE-889A-CF1B-AF9A-795EEE5A463E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9674e000 - 0x967fbfe7  libobjc.A.dylib ??? (???) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
0x96913000 - 0x96d48ff7  libLAPACK.dylib ??? (???) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x96d87000 - 0x96e36ff3  com.apple.ColorSync 4.6.2 (4.6.2) <F3F097AC-FDB7-3357-C64F-E28BECF4C15F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x96e6c000 - 0x96f62ff7  libGLProgrammability.dylib ??? (???) <82D03736-D30C-C013-BBB1-20ED9687D47F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x970a3000 - 0x970a9fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x970aa000 - 0x9788d4b7  com.apple.CoreGraphics 1.536.12 (???) <263EB5FC-DEAD-7C5B-C486-EC86C173F952> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x979db000 - 0x97ab5ff3  com.apple.DesktopServices 1.5.3 (1.5.3) <DA02AC94-7B0C-BD75-2305-C46A307A5FB0> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x97ac1000 - 0x97aceff7  com.apple.NetFS 3.2.1 (3.2.1) <5E61A00B-FA16-9D99-A064-47BDC5BC9A2B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x97acf000 - 0x97aedff7  com.apple.CoreVideo 1.6.0 (43.1) <1FB01BE0-B013-AE86-A063-481BB547D2F5> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x97aee000 - 0x97b7ffe7  com.apple.print.framework.PrintCore 6.1 (312.3) <6D4322AF-703C-CC19-77B4-53E6D3BB18D4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x97b80000 - 0x97bfafef  com.apple.audio.CoreAudio 3.2.2 (3.2.2) <1F97B48A-327B-89CC-7C01-3865179716E0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x97bfb000 - 0x97bfcff7  com.apple.audio.units.AudioUnit 1.6.1 (1.6.1) <3A08510C-07F7-1A09-D6ED-1A488203ACCC> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x97cd0000 - 0x97cf2fef  com.apple.DirectoryService.Framework 3.6 (621.1) <3ED4949F-9604-C109-6586-5CE5F421182B> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x97cf3000 - 0x97dacfe7  libsqlite3.dylib ??? (???) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
0x97dad000 - 0x97db6ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x97db7000 - 0x981cdff7  libBLAS.dylib ??? (???) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x981f7000 - 0x9825bffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x9839b000 - 0x98694ff3  com.apple.RawCamera.bundle 2.3.0 (505) <1C7CEA30-FFE2-B4DE-98CE-D6518DF1E54B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x98a33000 - 0x98adafe7  com.apple.CFNetwork 454.5 (454.5) <A7E78E62-0C59-CE57-73D2-C4E60527781C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x98adb000 - 0x98ae5ff7  com.apple.HelpData 2.0.4 (34) <9128FFEB-0F6C-B273-FCF4-D87A20227345> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x98b9e000 - 0x98c51fff  libFontParser.dylib ??? (???) <FAD5E96D-CF93-CC86-6B30-A6594B930772> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x98c52000 - 0x98c5cffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x98c5d000 - 0x98c5fff7  com.apple.securityhi 4.0 (36638) <962C66FB-5BE9-634E-0810-036CB340C059> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x98c60000 - 0x98cadfeb  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x98cae000 - 0x9958cff7  com.apple.AppKit 6.6.3 (1038.25) <72A9AA47-8DCB-DB07-64F5-F837E98C62D8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x9958d000 - 0x9959eff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <7A3862F7-3730-8F6E-A5DE-8E2CCEA979EF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9959f000 - 0x995a3ff7  libGFXShared.dylib ??? (???) <79F4F60E-0A6D-CE9C-282E-FA85825449E3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x995a4000 - 0x995b8fe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <D45B91B2-2B4C-AAC0-8096-1FC48B7E9672> /usr/lib/libSystem.B.dylib
Model: MacBook4,1, BootROM MB41.00C1.B00, 2 processors, Intel Core 2 Duo, 2.4 GHz, 4 GB, SMC 1.31f0
Graphics: Intel GMA X3100, GMA X3100, Built-In, 144 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x88), Broadcom BCM43xx 1.0 (5.10.91.26)
Bluetooth: Version 2.2.4f3, 2 service, 1 devices, 1 incoming serial ports
Network Service: FireWire, FireWire, fw0
Network Service: AirPort, AirPort, en1
Serial ATA Device: ST9500325AS, 465.76 GB
Parallel ATA Device: MATSHITADVD-R  UJ-867, 606.6 MB
USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8501, 0xfd400000
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac  (Apple Inc.), 0x0229, 0x5d200000
USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0x5d100000
USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8205, 0x1a100000
Reply #59
I tried the same with 11/29/2009 version of XLD and it worked fine.
Reply #60
thx for the hint. what is the process name for cdparanoia? is there a way to manually quit it via terminal/activity monitor?
would there be any way to have some sort or progress bar or status report of cdparanoia?
Reply #61
Yes, cdparanoia will hang the same way in MAX. The problem with XLD is the disappearing disk drive after quitting during a hung up rip.
I just tried again, and opening up Rip (iTunes doesn't work) will allow you to eject the disk with it's eject button. Quite a bit more convenient than restarting the computer.
Reply #62
thx for the tip. at least rip gives me the following error message when trying to eject disl: " Operation could not be completed. (Mach error 49168 - (os/unix) mount device busy)"
any unix-ji-jutsu that would fix this without restart?!
Reply #63
Is that even after quitting XLD?
I get that message when XLD is open, but after quitting XLD, Rip will eject the disk for me without a restart. Reinsert the disk, and everything is back to normal.
Reply #64
You could have started Disk Utility (/Applications/Utilities/Disk Utility.app) instead.
Reply #65
yes! the xld icon will also stay in the task switcher bar.
disk utility will not start until I reboot the system.
Reply #66
I've been trying to get a secure rip of a couple of cds with XLD in OS X (10.5.8) and there seems to be a problem with this one disk.
It will recognise the disk and all, but when I eventually hit "encode" I get blank progress box, and then the app just hangs. iTunes recognises and rips the disk no problem, and it isn't scratched.
To figure out what the problem is, I installed and set up EAC on a windows PC, and ripped the album. It was the UK special edition of Queens of the Stone Age's Songs for the Deaf. Unbeknownst to me, there is a hidden track on this album located in the pre-gap of track 1. The only way to hear this track on a regular CD player is to start track one playing, and then rewind. iTunes doesn't detect pregaps (?), so it doesn't have a problem. I checked "exclude pregap in output" in XLD, and low and behold, the track rips. However, it isn't possible to get a secure rip this way.
So, I'm thinking that since EAC has the ability to detect these kinds of tracks, and XLD doesn't (?), then this is probably what is causing the issue. The only thing to do is hope that the bug is fixed in later versions of XLD. For now, the only solution I have is to use EAC on a windows PC.
Below is the log from the rip of Track 1 that excluded the pregap:
XLD Version 20100117 (115.3)
Macbook 1.83Ghz Intel core2duo running OS X 10.5.8
Memory: 2 GB 667 Mhz DDR2 SDRAM
X Lossless Decoder version 20100117 (115.3)
XLD extraction logfile from 2010-01-22 16:07:22 +0000
Queens Of The Stone Age / Songs For The Deaf [UK]
Used drive : MATSHITA DVD-R  UJ-857E (revision ZA0E)
Use cdparanoia mode    : YES (CDParanoia III 10.2 engine)
Disable audio cache    : OK for the drive with cache less than 2750KB
Make use of C2 pointers : NO
Read offset correction  : 102
Max retry count        : 100
TOC of the extracted CD
    Track |  Start  |  Length  | Start sector | End sector
        1  | 01:32:61 | 03:12:37 |      6961    |    21397
        2  | 04:45:23 | 04:38:56 |    21398    |    42303
        3  | 09:24:04 | 03:18:29 |    42304    |    57182
        4  | 12:42:33 | 05:52:34 |    57183    |    83616
        5  | 18:34:67 | 06:15:58 |    83617    |  111799
        6  | 24:50:50 | 01:19:32 |    111800    |  117756
        7  | 26:10:07 | 03:06:19 |    117757    |  131725
        8  | 29:16:26 | 03:07:11 |    131726    |  145761
        9  | 32:23:37 | 02:50:15 |    145762    |  158526
      10  | 35:13:52 | 04:04:66 |    158527    |  176892
      11  | 39:18:43 | 06:04:68 |    176893    |  204260
      12  | 45:23:36 | 03:16:14 |    204261    |  218974
      13  | 48:39:50 | 06:42:36 |    218975    |  249160
      14  | 55:22:11 | 05:37:71 |    249161    |  274506
      15  | 61:00:07 | 03:38:00 |    274507    |  290856
      16  | 64:38:07 | 02:35:46 |    290857    |  302527
Track 01
    Filename : /Users/David/Desktop/01 Queens Of The Stone Age - You Think I Ain't Worth A Dollar But I Feel Like A Millionaire.m4a
    Pre-gap length : 01:34:61
    CRC32 hash (test run)  : E918529B
    CRC32 hash            : E918529B
    CRC32 hash (skip zero) : 80E71ED3
    Statistics
        Read error                          : 0
        Skipped (treated as error)          : 0
        Edge jitter error (maybe fixed)      : 0
        Atom jitter error (maybe fixed)      : 0
        Drift error (maybe fixed)            : 0
        Dropped bytes error (maybe fixed)    : 0
        Duplicated bytes error (maybe fixed) : 0
        Inconsistency in error sectors      : 0
No errors occurred
End of status report
Reply #67
I noticed there were three instances of problems with UJ-835E drives, which is what I have. Same problems over here, using offset of 0 just like every other instance I saw here. Using 102 (which all almost all Panasonic DVD drives use and certainly all UJ-8* series) everything works fine and dandy. Happy ripping!
Reply #68
I'm having a problem where XLD fails to rip the pregap for track one of a cd, regardless of whether I have "Include pre-gap for all tracks" or "Include pre-gap except for HTOA" set. The CD in question has a pre-gap of 00:02:00 for track one. XLD does not show this pregap on the main interface, it doesn't rip it, and it doesn't appear in the cue files. It does, however, appear correctly detected in the log file.
How do I make XLD rip the track one pregap and include it on the cue sheet properly? Is there a bug here or might I be doing something wrong?
I've attached the log, truncated after track one. You can compare the TOC given in the log to the TOC as reported by musicbrainz here: http://musicbrainz.org/show/cdtoc/?cdtocid=404037 . XLD seems to be just ignoring the 150 sectors of the pregap entirely and starting the numbering from _after_ that, even though later it shows that it knows there is pregap there.
X Lossless Decoder version 20100711 (120.5)
XLD extraction logfile from 2010-08-02 16:51:42 -0400
Big Little Dipper Dipper / Hockey Star
Used drive : MATSHITA DVD-R  UJ-868 (revision KB19)
Gap status              : Analyzed, Appended
        1  | 00:00:00 | 03:32:71 |        0    |    15970
        2  | 03:32:71 | 02:30:19 |    15971    |    27239
        3  | 06:03:15 | 02:43:59 |    27240    |    39523
        4  | 08:46:74 | 01:33:52 |    39524    |    46550
        5  | 10:20:51 | 03:42:27 |    46551    |    63227
        6  | 14:03:03 | 01:42:24 |    63228    |    70901
        7  | 15:45:27 | 02:22:53 |    70902    |    81604
        8  | 18:08:05 | 02:14:62 |    81605    |    91716
        9  | 20:22:67 | 04:12:43 |    91717    |  110659
      10  | 24:35:35 | 01:40:70 |    110660    |  118229
      11  | 26:16:30 | 03:56:30 |    118230    |  135959
      12  | 30:12:60 | 02:03:69 |    135960    |  145253
      13  | 32:16:54 | 11:10:54 |    145254    |  195557
Track 01
    Filename : 01 Big Little Dipper Dipper - Hockey Star.flac
    Pre-gap length : 00:02:00
    CRC32 hash (test run)  : 36092D05
    CRC32 hash            : 36092D05
    CRC32 hash (skip zero) : DE11151C
    AccurateRip signature  : 6D5821E8
        ->Track not present in AccurateRip database.
    Statistics
        Read error                          : 0
{snip}
No errors occurred
Reply #70
I have a problem with the "format of filename" when ripping a CD to FLAC (single file + cue).
When I transcode from FLAC to AAC I use  %A/%y - %T/%n %t  with no problems.
When I rip a CD I use  %A/%y - %T/%A - %T  and it doesn't work. The  %y - %T  creates a folder named "Unknown Year" - Album Title (this part works). I make sure the year tag is filled before I rip so there seems to be a problem.
Reply #71
Preference choice isn't saved until XLD is restarted.
I had the "Delete original files after successful conversion" checked and the "Warn before deleting" sub-option also checked. I turned off the "Warn before deleting" sub-option and closed the preference pane, but XLD still gave me file deletion warnings until I restarted XLD.
If this is normal functionality (and I don't think so - most Mac programs save preferences as soon as they're changed), then an Apply button needs to be added to make the preference changes permanent without having to restart XLD.
Reply #72
Bug (crash)
I selected 3 multi-part FLACs with the "Edit tags before convert" option checked. When I invoked XLD, I got the metadata dialog of the embedded tracks (I was hitting Next and Prev; all the embedded tracks seem to be there). When I hit OK, XLD crashed, deleting the first source FLAC (I had the delete option on). The deleted source file was nowhere to be found; not even in the trash.
The crash report:
Process:		 XLD [27955]
Path: /Volumes/iMac Clone 1/Applications/XLD.app/Contents/MacOS/XLD
Version: 20101128 (126.0)
Parent Process:  launchd [266]
Date/Time:   2010-12-07 13:00:38.303 -0500
OS Version:   Mac OS X 10.6.5 (10H574)
Report Version:  6
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000038
0  libSystem.B.dylib 0x97842acf flockfile + 22
1  libSystem.B.dylib 0x97842e6b fread + 64
2  jp.tmkk.XLDFlacDecoder 0x004f93c2 -[XLDFlacDecoder openFile:] + 107
3  jp.tmkk.XLD   0x00037203 -[XLDConverterTask beginConvert] + 307
4  jp.tmkk.XLD   0x00032d5a -[XLDQueue convertFinished:] + 554
5  com.apple.Foundation   0x902e4e80 __NSThreadPerformPerform + 705
6  com.apple.CoreFoundation   0x914874cb __CFRunLoopDoSources0 + 1563
7  com.apple.CoreFoundation   0x91484f8f __CFRunLoopRun + 1071
8  com.apple.CoreFoundation   0x91484464 CFRunLoopRunSpecific + 452
9  com.apple.CoreFoundation   0x91484291 CFRunLoopRunInMode + 97
10  com.apple.HIToolbox   0x96287f58 RunCurrentEventLoopInMode + 392
11  com.apple.HIToolbox   0x96287d0f ReceiveNextEventCommon + 354
12  com.apple.HIToolbox   0x96287b94 BlockUntilNextEventMatchingListInMode + 81
13  com.apple.AppKit   0x90a4178d _DPSNextEvent + 847
14  com.apple.AppKit   0x90a40fce -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
15  com.apple.AppKit   0x90a03247 -[NSApplication run] + 821
16  com.apple.AppKit   0x909fb2d9 NSApplicationMain + 574
17  jp.tmkk.XLD   0x00003036 _start + 216
18  jp.tmkk.XLD   0x00002f5d start + 41
0  libSystem.B.dylib 0x97834982 kevent + 10
1  libSystem.B.dylib 0x9783509c _dispatch_mgr_invoke + 215
2  libSystem.B.dylib 0x97834559 _dispatch_queue_invoke + 163
3  libSystem.B.dylib 0x978342fe _dispatch_worker_thread2 + 240
4  libSystem.B.dylib 0x97833d81 _pthread_wqthread + 390
5  libSystem.B.dylib 0x97833bc6 start_wqthread + 30
Thread 2:
0  libSystem.B.dylib 0x9780e442 close + 10
1  libSystem.B.dylib 0x97839031 fclose + 133
2  jp.tmkk.XLDAlacOutput 0x0072db68 -[XLDAlacOutputTask optimizeAtoms] + 4298
3  jp.tmkk.XLDAlacOutput 0x0072f0f6 -[XLDAlacOutputTask finalize] + 5375
4  jp.tmkk.XLD   0x000365f6 -[XLDConverterTask convert] + 4966
5  com.apple.Foundation   0x902cebf0 -[NSThread main] + 45
6  com.apple.Foundation   0x902ceba0 __NSThread__main__ + 1499
7  libSystem.B.dylib 0x9783b85d _pthread_start + 345
8  libSystem.B.dylib 0x9783b6e2 thread_start + 34
Thread 3:
0  jp.tmkk.XLDAlacOutput 0x0072ca0d -[XLDAlacOutputTask writeBuffer:frames:] + 129
1  jp.tmkk.XLD   0x00035512 -[XLDConverterTask convert] + 642
2  com.apple.Foundation   0x902cebf0 -[NSThread main] + 45
3  com.apple.Foundation   0x902ceba0 __NSThread__main__ + 1499
4  libSystem.B.dylib 0x9783b85d _pthread_start + 345
5  libSystem.B.dylib 0x9783b6e2 thread_start + 34
Thread 4:
0  libSystem.B.dylib 0x9786c3aa pwrite$UNIX2003 + 10
1  ....audio.toolbox.AudioToolbox 0x94f69090 UnixFile_DataSource::WriteBytes(unsigned short, long long, unsigned long, void const*, unsigned long*) + 176
2  ....audio.toolbox.AudioToolbox 0x94f695ae Cached_DataSource::WriteBytes(unsigned short, long long, unsigned long, void const*, unsigned long*) + 450
3  ....audio.toolbox.AudioToolbox 0x94fbabcc MP4AudioFile::WritePackets(unsigned char, unsigned long, AudioStreamPacketDescription const*, long long, unsigned long*, void const*) + 620
4  ....audio.toolbox.AudioToolbox 0x94f65c94 AudioFileWritePackets + 187
5  ....audio.toolbox.AudioToolbox 0x94f76167 ExtAudioFile::WritePacketsFromCallback(long (*)(OpaqueAudioConverter*, unsigned long*, AudioBufferList*, AudioStreamPacketDescription**, void*), void*) + 297
6  ....audio.toolbox.AudioToolbox 0x94f76f2d ExtAudioFile::Write(unsigned long, AudioBufferList const*) + 225
7  ....audio.toolbox.AudioToolbox 0x94f6f3c5 ExtAudioFileWrite + 71
8  jp.tmkk.XLDAlacOutput 0x0072ca92 -[XLDAlacOutputTask writeBuffer:frames:] + 262
9  jp.tmkk.XLD   0x00035512 -[XLDConverterTask convert] + 642
10  com.apple.Foundation   0x902cebf0 -[NSThread main] + 45
11  com.apple.Foundation   0x902ceba0 __NSThread__main__ + 1499
12  libSystem.B.dylib 0x9783b85d _pthread_start + 345
13  libSystem.B.dylib 0x9783b6e2 thread_start + 34
Thread 5:
Thread 6:
0  libSystem.B.dylib 0x9783c0a6 __semwait_signal + 10
1  libSystem.B.dylib 0x97867ee5 nanosleep$UNIX2003 + 188
2  libSystem.B.dylib 0x97867e23 usleep$UNIX2003 + 61
3  com.apple.AppKit   0x90baafe1 -[NSUIHeartBeat _heartBeatThread:] + 2039
4  com.apple.Foundation   0x902cebf0 -[NSThread main] + 45
5  com.apple.Foundation   0x902ceba0 __NSThread__main__ + 1499
6  libSystem.B.dylib 0x9783b85d _pthread_start + 345
7  libSystem.B.dylib 0x9783b6e2 thread_start + 34
Thread 7:
0  libSystem.B.dylib 0x97833ba8 start_wqthread + 0
Thread 8:
0  libSystem.B.dylib 0x97833a12 __workq_kernreturn + 10
1  libSystem.B.dylib 0x97833fa8 _pthread_wqthread + 941
2  libSystem.B.dylib 0x97833bc6 start_wqthread + 30
Thread 9:
  eax: 0xa0a66540  ebx: 0xa0a66540  ecx: 0x97814482  edx: 0xa0a5c50c
  edi: 0x00000001  esi: 0x00000000  ebp: 0xbfffe478  esp: 0xbfffe460
  ss: 0x0000001f  efl: 0x00210286  eip: 0x97842acf  cs: 0x00000017
  cr2: 0x00000038
Binary Images:
0x1000 - 0x6dfe3 +jp.tmkk.XLD 20101128 (126.0) <6E24A7EA-FE2C-2C79-1A1E-8092C133A29A> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/MacOS/XLD
  0x8f000 - 0x9afff +CDDB ??? (???) /Volumes/iMac Clone 1/Applications/XLD.app/Contents/Frameworks/CDDB.framework/Versions/A/CDDB
  0xa2000 -  0x103fcf +Musicbrainz ??? (???) /Volumes/iMac Clone 1/Applications/XLD.app/Contents/Frameworks/Musicbrainz.framework/Versions/A/Musicbrainz
  0x161000 -  0x1bdfe7 +Sndfile ??? (???) <4F69600F-C387-4869-89C8-FAA1A7616FB8> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/Frameworks/Sndfile.framework/Versions/A/Sndfile
  0x1d3000 -  0x288fe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <AACC86C0-86B4-B1A7-003F-2A0AF68973A2> /usr/lib/libcrypto.0.9.7.dylib
  0x42a000 -  0x436ff7 +com.rogueamoeba.audio_hijack_server.hermes 2.2.6 (2.2.6) <E99CDC13-114A-DADD-658C-809B8BB59757> /usr/local/hermes/modules/Instant Hijack Server.hermesmodule/Contents/MacOS/Instant Hijack Server
  0x4a4000 -  0x4aeff7 +com.unsanity.smartcrashreports Smart Crash Reports version 1.5 (1.5) /Library/InputManagers/Smart Crash Reports/Smart Crash Reports.bundle/Contents/MacOS/Smart Crash Reports
  0x4bc000 -  0x4befff +net.culater.SIMBL 0.8.2 (8) /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL
  0x4c4000 -  0x4c5ffd +com.1passwd.InputManager 2.7.1 (7144) <7B962658-403D-9E08-21F7-EC4DD292E780> /Library/InputManagers/1PasswdIM/1PasswdIM.bundle/Contents/MacOS/1PasswdIM
  0x4f6000 -  0x4f9ff7 +jp.tmkk.XLDFlacDecoder ??? (1.0) <5FCE7C45-3C14-4345-B339-A27F8F3A8F67> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDFlacDecoder.bundle/Contents/MacOS/XLDFlacDecoder
  0x700000 -  0x707ff7 +jp.tmkk.XLDAacOutput ??? (1.0) <6468D5F6-2AB6-FF35-C559-174BDAC361B8> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDAacOutput.bundle/Contents/MacOS/XLDAacOutput
  0x70d000 -  0x719ff7 +jp.tmkk.XLDAacOutput2 ??? (1.0) <59982F6D-1F3D-DD46-7BDF-718415CCC402> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDAacOutput2.bundle/Contents/MacOS/XLDAacOutput2
  0x71f000 -  0x724ff7 +jp.tmkk.XLDAlacDecoder ??? (1.0) <FA1EBE57-8264-1DE8-83EC-ABD5FD6BD064> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDAlacDecoder.bundle/Contents/MacOS/XLDAlacDecoder
  0x72a000 -  0x733ff7 +jp.tmkk.XLDAlacOutput ??? (1.0) <7C436CAD-08CF-9FC8-D56E-1A1C7C9AE674> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDAlacOutput.bundle/Contents/MacOS/XLDAlacOutput
  0x739000 -  0x75bffa +jp.tmkk.XLDApeDecoder ??? (1.0) /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDApeDecoder.bundle/Contents/MacOS/XLDApeDecoder
  0x76c000 -  0x7b3fd7 +FLAC ??? (???) /Volumes/iMac Clone 1/Applications/XLD.app/Contents/Frameworks/FLAC.framework/Versions/A/FLAC
  0x7c4000 -  0x7c6ff7 +Ogg ??? (???) <AC76D238-F8FC-CC14-8FBF-CC36626850D2> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/Frameworks/Ogg.framework/Versions/A/Ogg
  0x7c9000 -  0x7cdff7 +jp.tmkk.XLDFlacOutput ??? (1.0) <BF79E52E-7C4A-C6A5-8F96-9E61837BBC8A> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDFlacOutput.bundle/Contents/MacOS/XLDFlacOutput
  0x7d3000 -  0x7d8ff7 +jp.tmkk.XLDHEAACOutput ??? (1.0) <7DAAEB64-13F1-1988-2434-947ABABACDF0> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDHEAACOutput.bundle/Contents/MacOS/XLDHEAACOutput
  0x7de000 -  0x7dfffb +jp.tmkk.XLDLibsndfileDecoder ??? (1.0) <D0584CB5-71CB-4F56-BCE5-EA78569BA91D> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDLibsndfileDecoder.bundle/Contents/MacOS/XLDLibsndfileDecoder
  0x7e4000 -  0x7e5ff7 +jp.tmkk.XLDMP3Decoder ??? (1.0) <AB512F41-0982-4B4A-9050-87DCD4EF9AF7> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDMP3Decoder.bundle/Contents/MacOS/XLDMP3Decoder
  0x7ea000 -  0x7f1fef +jp.tmkk.XLDShortenDecoder ??? (1.0) /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDShortenDecoder.bundle/Contents/MacOS/XLDShortenDecoder
  0x7f9000 -  0x7f9ff7 +jp.tmkk.XLDSparkleUpdater ??? (1.0) <A5BB9D62-1F1D-46FA-8C5F-28FA538A8967> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDSparkleUpdater.bundle/Contents/MacOS/XLDSparkleUpdater
0x13083000 - 0x130bdfff +jp.tmkk.XLDLameOutput ??? (1.0) /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDLameOutput.bundle/Contents/MacOS/XLDLameOutput
0x130da000 - 0x130edfff +org.andymatuschak.Sparkle 1.5 Beta (bzr) (1.5) <C1C2F3B9-7EC8-116D-B7C6-4900BAAF3197> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDSparkleUpdater.bundle/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
0x130fb000 - 0x130fdfff +jp.tmkk.XLDTakDecoder ??? (1.0) /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDTakDecoder.bundle/Contents/MacOS/XLDTakDecoder
0x13102000 - 0x13105ff3 +jp.tmkk.XLDTtaDecoder ??? (1.0) /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDTtaDecoder.bundle/Contents/MacOS/XLDTtaDecoder
0x1310a000 - 0x1310dff7 +jp.tmkk.XLDVorbisOutput ??? (1.0) <551B8822-EA7A-84CF-E819-95FDBC48343C> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDVorbisOutput.bundle/Contents/MacOS/XLDVorbisOutput
0x13113000 - 0x13137ff7 +Vorbis ??? (???) <EA3859B9-05F9-20AD-6A02-A43E1E1827DA> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/Frameworks/Vorbis.framework/Versions/A/Vorbis
0x13265000 - 0x13267ff3 +jp.tmkk.XLDWavpackDecoder ??? (1.0) <3FCE2546-9E80-4919-8A24-24D45C5E81B4> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDWavpackDecoder.bundle/Contents/MacOS/XLDWavpackDecoder
0x1326c000 - 0x13295fe3 +WavPack ??? (???) <E660876F-9079-45BD-B12D-4391A2294158> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/Frameworks/WavPack.framework/Versions/A/WavPack
0x1329d000 - 0x132a0ff7 +jp.tmkk.XLDWavpackOutput ??? (1.0) <975A7869-AE94-DDB4-E478-1DA35B51D390> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDWavpackOutput.bundle/Contents/MacOS/XLDWavpackOutput
0x14b9f000 - 0x14ba3ff3 +com.stclairsoft.DefaultFolderX.osax Default Folder X Addition version 1.0 (4.3.10) <AE13AC3A-2A5F-DE8A-DAA4-D4B5AA82F3F0> /Users/michaelferrari/Library/ScriptingAdditions/Default Folder X Addition.osax/Contents/MacOS/Default Folder X Addition
0x14ba8000 - 0x14bc9fef +com.stclairsoft.DefaultFolderX.CarbonPatcher kBundleVersion (kBundleVersion) <E15B9B22-664E-6D25-CD6A-99786FBDDF79> /Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Carbon Patcher.bundle/Contents/MacOS/Carbon Patcher
0x14bd4000 - 0x14bf4fff +Cocoa Patcher ??? (???) <FBEBB8D4-4961-2AB7-D021-FF7072717B5D> /Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Cocoa Patcher.bundle/Contents/MacOS/Cocoa Patcher
0x14c87000 - 0x14c89ff3  com.apple.LiveType.component 2.1.4 (2.1.4) <D60E2537-3B47-EA99-0077-6CE394378D07> /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x14c8f000 - 0x14cf3fe2  com.apple.LiveType.framework 2.1.4 (2.1.4) <7AABA687-4323-E5B9-BA04-8F61C217E6FD> /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
0x14d13000 - 0x14d59ffb  com.apple.motion.component 1.0 (729) <494487C6-EA30-43DD-39E4-BED23C5A5B1C> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0x14d5f000 - 0x14d61ff7  Motion 729.0.0 (compatibility 1.0.0) <051B60E9-B39F-EBB2-5B96-F088D147E78C> /Library/Frameworks/Motion.framework/Versions/A/Motion
0x14d67000 - 0x14e04ff8  com.apple.procore.framework 4.0.2 (757) <D3146F1E-F86D-F2A2-509B-E3F9640CBE40> /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
0x14e44000 - 0x15038ff7 +com.elgato.mpegsupport EyeTV MPEG Support 1.2 (build 50) (1.2) <0A9DC100-CA59-9826-49DB-14FFD9245C97> /Library/QuickTime/EyeTV MPEG Support.component/Contents/MacOS/EyeTV MPEG Support
0x15a2b000 - 0x15c09ff3  com.apple.audio.codecs.Components 2.0.2 (2.0.2) <8B43D24A-277D-5F42-8741-FC8736C44162> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <39AC3185-E633-68AA-7CD6-1230E7F1CEF4> /usr/lib/dyld
0x90042000 - 0x9007bff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <D6F24434-8217-DF72-2126-1953080680D7> /usr/lib/libcups.2.dylib
0x9007c000 - 0x90157feb  com.apple.DesktopServices 1.5.9 (1.5.9) <CED00AC1-924B-0E45-7D5E-1CEA8929F5BE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x90158000 - 0x9024cff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <061ABF36-8BA9-79C1-6CE7-EC69A4998F51> /usr/lib/libiconv.2.dylib
0x90286000 - 0x90291ff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <CB2510BD-A5B3-9D90-5917-C73F6ECAC913> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x902b8000 - 0x9052bfe7  com.apple.Foundation 6.6.4 (751.42) <ACC0BAEB-C590-7052-3AB2-86C207C3D6D4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9052c000 - 0x905e2ff7  libFontParser.dylib ??? (???) <33F62EE1-E457-C6FD-369E-E86745B94A4B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x905e3000 - 0x90903ff3  com.apple.CoreServices.CarbonCore 861.23 (861.23) <B08756E4-32C5-CC33-0268-7C00A5ED7537> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90905000 - 0x909cffef  com.apple.CoreServices.OSServices 357 (357) <3A26F553-722D-3536-EEDE-FB41FCDAA7FD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x909d0000 - 0x909f8ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
0x909f9000 - 0x912d9ff7  com.apple.AppKit 6.6.7 (1038.35) <ABC7783C-E4D5-B848-BED6-99451D94D120> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x912da000 - 0x9138aff3  com.apple.ColorSync 4.6.3 (4.6.3) <0354B408-665F-8B3F-87FF-64E6322276F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9138b000 - 0x913e8ff7  com.apple.framework.IOKit 2.0 (???) <A769737F-E0D6-FB06-29B4-915CF4F43420> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x91448000 - 0x915c3fe7  com.apple.CoreFoundation 6.6.4 (550.42) <C78D5079-663E-9734-7AFA-6CE79A0539F1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x91604000 - 0x91623ff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x91660000 - 0x91a76ff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x91a77000 - 0x91b1fffb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91b20000 - 0x91b23ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <B624AACE-991B-0FFA-2482-E69970576CE1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x91c1b000 - 0x91c41ffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x91c42000 - 0x91c43ff7  com.apple.audio.units.AudioUnit 1.6.5 (1.6.5) <BE4C2495-B758-AD22-DCC0-56A6791E948E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x91c44000 - 0x91dfdfeb  com.apple.ImageIO.framework 3.0.4 (3.0.4) <C145139E-24C4-5A3D-B17C-809D528354B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91dfe000 - 0x91e68fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x91e69000 - 0x91e69ff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x91e6a000 - 0x921d5ff7  com.apple.QuartzCore 1.6.3 (227.34) <CC1C1631-D8D1-D416-171E-A1683274E479> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x921d6000 - 0x92284ff3  com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92285000 - 0x92289ff7  IOSurface ??? (???) <D849E1A5-6B0C-2A05-2765-850EC39BA2FF> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x922aa000 - 0x926dfff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x926e0000 - 0x926e6fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92722000 - 0x92786ffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x92787000 - 0x927baff7  com.apple.AE 496.4 (496.4) <C73D124C-C722-41D8-3465-4CE0D0BA9307> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x927bb000 - 0x927c6ff7  libGL.dylib ??? (???) <48405993-0AE9-292B-6705-C3525528682A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x929d8000 - 0x92dbeffb  com.apple.RawCamera.bundle 3.4.1 (546) <557C094F-BF8D-B298-E502-C4EE78914C55> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x92dbf000 - 0x92e02ff7  libGLU.dylib ??? (???) <F8580594-0B38-F3ED-A715-CB3776B747A0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92e03000 - 0x92e95fe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x92ede000 - 0x92eefff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x93008000 - 0x9302afef  com.apple.DirectoryService.Framework 3.6 (621.9) <F2EEE9D7-D4FB-14F3-E647-ABD32754F557> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x9302b000 - 0x930e4fe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
0x930e5000 - 0x93267fe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <35DB7644-0780-D2AB-F6A9-45F28D2D434A> /usr/lib/libicucore.A.dylib
0x93268000 - 0x93cb3ff7  com.apple.WebCore 6533.19 (6533.19.4) <DFCF1BC1-8BF3-E13E-F11B-C98CB36560FD> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x93d5e000 - 0x93d5eff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x93e7f000 - 0x93eeeff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x93f0b000 - 0x93fb5fe7  com.apple.CFNetwork 454.11.5 (454.11.5) <D8963574-285A-3BD6-6B25-07D39C6F67A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x93fb6000 - 0x93ffffe7  libTIFF.dylib ??? (???) <AC1FC806-F7F4-174B-375F-FE5D6008666C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x94000000 - 0x94009ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x9404b000 - 0x94063ff7  com.apple.CFOpenDirectory 10.6 (10.6) <F9AFC571-3539-6B46-ABF9-46DA2B608819> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x94295000 - 0x942d6ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <16DAE1A5-937A-1CA2-D98F-2AF958B62993> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x942d7000 - 0x94359ffb  SecurityFoundation ??? (???) <A8D248DE-8670-970D-39E3-A9738CFDBEE1> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x94437000 - 0x94444ff7  com.apple.NetFS 3.2.1 (3.2.1) <94A52A6D-F071-09D7-E80F-F633F17233FE> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x94445000 - 0x94477fe3  libTrueTypeScaler.dylib ??? (???) <6E9D1A50-330E-F1F4-F93D-9ECC8A61B21A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x94478000 - 0x94478ff7  com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x94479000 - 0x944b4feb  libFontRegistry.dylib ??? (???) <4FB144ED-8AF9-27CF-B315-DCE5575D5231> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x944d4000 - 0x94525ff7  com.apple.HIServices 1.8.1 (???) <51BDD848-32A5-2425-BE07-BD037A89630A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x9456f000 - 0x94570ff7  com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x94571000 - 0x94573ff7  com.apple.securityhi 4.0 (36638) <E7D83480-77BB-72F9-72F3-AEE198CE589F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x94630000 - 0x9470dff7  com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x9476d000 - 0x947bdff7  com.apple.framework.familycontrols 2.0.1 (2010) <41DD36DE-1A3C-7D2E-CF02-520091C2B71A> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x947be000 - 0x947caff7  libkxld.dylib ??? (???) <F0E915AD-6B32-0D5E-D24B-B188447FDD23> /usr/lib/system/libkxld.dylib
0x9493b000 - 0x94978ff7  com.apple.SystemConfiguration 1.10.5 (1.10.2) <362DF639-6E5F-9371-9B99-81C581A8EE41> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x94e33000 - 0x94e79ff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
0x94f10000 - 0x9503ffe3  com.apple.audio.toolbox.AudioToolbox 1.6.5 (1.6.5) <0A0F68E5-4806-DB51-764B-D97554B801AD> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9508b000 - 0x950cdff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x950ce000 - 0x950e3fff  com.apple.ImageCapture 6.0.1 (6.0.1) <E7ED2AC1-834C-A44E-531E-EC05F0496DBF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x950e4000 - 0x951f3fe7  com.apple.WebKit 6533.19 (6533.19.4) <A942073C-83DF-33ED-3D01-A24DE8AEAB3D> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x951ff000 - 0x951ffff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x95200000 - 0x95304fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <BDEFA030-5E75-7C47-2904-85AB16937F45> /usr/lib/libcrypto.0.9.8.dylib
0x95401000 - 0x95415ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x95416000 - 0x9541aff7  libGIF.dylib ??? (???) <DA5758A4-71B0-DD6E-7402-B7FB15387569> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x9555f000 - 0x95562ffb  com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x95563000 - 0x955a7ff3  com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x95665000 - 0x95689ff7  libJPEG.dylib ??? (???) <46AF3A0F-2B8D-87B9-62D4-0905678A64DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x9568a000 - 0x958edfef  com.apple.security 6.1.1 (37594) <1949216A-7583-B73A-6112-4D55CA5852E3> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x9594d000 - 0x95961fe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x95c7e000 - 0x95c88fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x95c89000 - 0x95c90ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <C43D8F35-D0DB-37F3-5058-A8308A377303> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x95c91000 - 0x95d3efe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <C8925910-B927-968B-4B71-D83A4CEF8646> /usr/lib/libobjc.A.dylib
0x95d3f000 - 0x95db9fff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <F7C9B01D-45AD-948B-2D26-9736524C1A33> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x95f87000 - 0x960b5fe7  com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x960c6000 - 0x960cdff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x960e1000 - 0x960ebffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x96236000 - 0x96252fe3  com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x96253000 - 0x96577fef  com.apple.HIToolbox 1.6.3 (???) <169FA4B8-0847-D42E-8240-ECC52C0B8DD6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x96578000 - 0x974cafef  com.apple.QuickTimeComponents.component 7.6.6 (1756) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x974cb000 - 0x97563fe7  edu.mit.Kerberos 6.5.10 (6.5.10) <DC19F49B-184E-FD0F-13F8-3A31924A3B66> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x97567000 - 0x97577ff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x97578000 - 0x97578ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x97579000 - 0x97616fe3  com.apple.LaunchServices 362.1 (362.1) <997D57B9-F04E-344E-924D-16D184A21662> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x97636000 - 0x97636ff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x97637000 - 0x97637ff7  com.apple.Carbon 150 (152) <2539A94A-34D9-45CB-8F3E-AD53149E0BD5> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x9773b000 - 0x97788feb  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x97789000 - 0x9778bff7  libRadiance.dylib ??? (???) <10048B4A-2AE8-A4E2-21B8-C6E7A8C5B76F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x9778c000 - 0x9780cfeb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x9780d000 - 0x979b4ff7  libSystem.B.dylib 125.2.1 (compatibility 1.0.0) <62291026-D016-705D-DC1E-FC2B09D47DE5> /usr/lib/libSystem.B.dylib
0x979b5000 - 0x97caefef  com.apple.QuickTime 7.6.6 (1756) <F08B13B6-31D7-BD18-DA87-A0CDFCF13B8F> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x97caf000 - 0x97de6ff7  com.apple.CoreAUC 6.04.04 (6.04.04) <050D9D16-AAE7-3460-4318-8449574F26C7> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x97df5000 - 0x97df5ff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x97ea5000 - 0x98694557  com.apple.CoreGraphics 1.545.0 (???) <1AB39678-00D5-FB88-3B41-93D78348E0DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x98695000 - 0x9869aff7  com.apple.OpenDirectory 10.6 (10.6) <C1B46982-7D3B-3CC4-3BC2-3E4B595F0231> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x98878000 - 0x988a9ff7  libGLImage.dylib ??? (???) <78F59EAB-BBD4-7366-CA84-970547501978> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x988ed000 - 0x989f9ff7  libGLProgrammability.dylib ??? (???) <8B308FAE-843F-EE76-0254-3374CBFFA7B3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x98a15000 - 0x98a36fe7  com.apple.opencl 12.3 (12.3) <DEA600BF-4F54-66B5-DB2F-DC57FD518543> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x98a55000 - 0x98a98ff7  com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x98ab1000 - 0x98ad1fe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <BF7FF2F6-5FD3-D78F-77BC-9E2CB2A5E309> /usr/lib/libresolv.9.dylib
0x98ad2000 - 0x98b6dff7  com.apple.ApplicationServices.ATS 4.4 (???) <ECB16606-4DF8-4AFB-C91D-F7947C26040F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x98ba3000 - 0x98bb5ff7  com.apple.MultitouchSupport.framework 207.10 (207.10) <E1A6F663-570B-CE54-0F8A-BBCCDECE3B42> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x98c78000 - 0x98e75ff7  com.apple.JavaScriptCore 6533.19 (6533.19.1) <85A6BFDD-CBB6-7490-748D-8EA8B9B7FDD8> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x98fd9000 - 0x98fe7fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
0x9902f000 - 0x99032ff7  libCoreVMClient.dylib ??? (???) <1F738E81-BB71-32C5-F1E9-C1302F71021C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x99279000 - 0x99294ff7  libPng.dylib ??? (???) <E14178E0-B92D-94EA-DACB-04F346D7534C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x992cf000 - 0x99330fe7  com.apple.CoreText 3.5.0 (???) <BB50C045-25F5-65B8-B1DB-8CDAEF45EB46> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x9950d000 - 0x9960efe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <ED8E45C6-B078-15E8-938D-99D8FD1EAE64> /usr/lib/libxml2.2.dylib
0x99707000 - 0x9970afe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x9974e000 - 0x9975cff7  com.apple.opengl 1.6.11 (1.6.11) <286D1BC4-4CD8-3CD4-F723-5C196FE15FE0> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x99940000 - 0x99984fe7  com.apple.Metadata 10.6.3 (507.12) <8632684D-ED4C-4CE1-4C53-015DFF10D873> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x99985000 - 0x99989ff7  libGFXShared.dylib ??? (???) <C3A805C4-C0E5-B300-430A-7E811395CB8E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <62291026-D016-705D-DC1E-FC2B09D47DE5> /usr/lib/libSystem.B.dylib
XLD found problems and bug list
Reply #73
Another crash bug:
I was trying to extract a multipart ape using it's cue file. I double-clicked on the cue, and XLD brought up the correct information for the embedded tracks. I hit GO, and after a couple of minutes, XLD crashed. I tried it on this ape/cue file several times, and each time XLD crashes. I think it might have something to do with the length of the output file name, but I'm not sure.
Crash report:
Process:		 XLD [30185]
Path: /Applications/XLD.app/Contents/MacOS/XLD
Identifier:   jp.tmkk.XLD
Code Type:   X86 (Native)
Date/Time:   2010-12-07 15:07:03.414 -0500
Report Version:  6
Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000151f9000
Crashed Thread:  4
Thread 0:  Dispatch queue: com.apple.main-thread
0  libSystem.B.dylib 0x9780e0fa mach_msg_trap + 10
1  libSystem.B.dylib 0x9780e867 mach_msg + 68
2  com.apple.CoreFoundation   0x9148537f __CFRunLoopRun + 2079
3  com.apple.CoreFoundation   0x91484464 CFRunLoopRunSpecific + 452
4  com.apple.CoreFoundation   0x91484291 CFRunLoopRunInMode + 97
5  com.apple.HIToolbox   0x96287f58 RunCurrentEventLoopInMode + 392
6  com.apple.HIToolbox   0x96287d0f ReceiveNextEventCommon + 354
7  com.apple.HIToolbox   0x96287b94 BlockUntilNextEventMatchingListInMode + 81
8  com.apple.AppKit   0x90a4178d _DPSNextEvent + 847
9  com.apple.AppKit   0x90a40fce -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
10  com.apple.AppKit   0x90a03247 -[NSApplication run] + 821
11  com.apple.AppKit   0x909fb2d9 NSApplicationMain + 574
12  jp.tmkk.XLD   0x00003036 _start + 216
13  jp.tmkk.XLD   0x00002f5d start + 41
Thread 1:  Dispatch queue: com.apple.libdispatch-manager
Thread 2:
5  com.apple.Foundation   0x903077d0 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 329
6  com.apple.Foundation   0x902cebf0 -[NSThread main] + 45
7  com.apple.Foundation   0x902ceba0 __NSThread__main__ + 1499
8  libSystem.B.dylib 0x9783b85d _pthread_start + 345
9  libSystem.B.dylib 0x9783b6e2 thread_start + 34
Thread 3:  com.apple.CFSocket.private
0  libSystem.B.dylib 0x9782d0c6 select$DARWIN_EXTSN + 10
1  com.apple.CoreFoundation   0x914c4c83 __CFSocketManager + 1091
Thread 4 Crashed:
0  libSystem.B.dylib 0xffff08a0 __memcpy + 256
1  libSystem.B.dylib 0x97842f69 fread + 318
2  jp.tmkk.XLDAlacOutput 0x0072eb37 -[XLDAlacOutputTask finalize] + 3904
3  jp.tmkk.XLD   0x000365f6 -[XLDConverterTask convert] + 4966
Thread 5:
0  libSystem.B.dylib 0x9782128e write + 10
1  libSystem.B.dylib 0x978211ed _swrite + 124
2  libSystem.B.dylib 0x9781fc80 __sfvwrite + 455
3  libSystem.B.dylib 0x978cd21c fwrite + 112
4  jp.tmkk.XLDAlacOutput 0x0072eb76 -[XLDAlacOutputTask finalize] + 3967
5  jp.tmkk.XLD   0x000365f6 -[XLDConverterTask convert] + 4966
Thread 6:
2  libSystem.B.dylib 0x9782001d __sflush + 65
3  libSystem.B.dylib 0x9781fc5a __sfvwrite + 417
4  libSystem.B.dylib 0x978cd21c fwrite + 112
5  jp.tmkk.XLDAlacOutput 0x0072e30b -[XLDAlacOutputTask finalize] + 1812
6  jp.tmkk.XLD   0x000365f6 -[XLDConverterTask convert] + 4966
7  com.apple.Foundation   0x902cebf0 -[NSThread main] + 45
8  com.apple.Foundation   0x902ceba0 __NSThread__main__ + 1499
9  libSystem.B.dylib 0x9783b85d _pthread_start + 345
10  libSystem.B.dylib 0x9783b6e2 thread_start + 34
Thread 7:
2  com.apple.CoreGraphics 0x97eccb6a _CGSSynchronizeWindowBackingStore + 139
3  com.apple.CoreGraphics 0x97ec5ce0 _CGSLockWindow + 5001
4  com.apple.CoreGraphics 0x97ecc70a CGSDeviceLock + 493
5  libRIP.A.dylib 0x9429d593 ripd_Lock + 62
6  libRIP.A.dylib 0x942a87cd ripl_BltImage + 429
7  libRIP.A.dylib 0x942a8393 ripc_RenderImage + 269
8  libRIP.A.dylib 0x942add30 ripc_EndLayer + 904
9  com.apple.CoreGraphics 0x97f44efd CGContextEndTransparencyLayer + 103
10  com.apple.AppKit   0x90baba52 -[NSProgressIndicator heartBeat:] + 2178
11  com.apple.AppKit   0x90baae23 -[NSUIHeartBeat _heartBeatThread:] + 1593
12  com.apple.Foundation   0x902cebf0 -[NSThread main] + 45
13  com.apple.Foundation   0x902ceba0 __NSThread__main__ + 1499
14  libSystem.B.dylib 0x9783b85d _pthread_start + 345
15  libSystem.B.dylib 0x9783b6e2 thread_start + 34
Thread 8:
Thread 9:
0  jp.tmkk.XLDApeDecoder 0x00749484 CPrepare::Unprepare(int, int, tWAVEFORMATEX const*, unsigned char*, unsigned int*) + 52
1  jp.tmkk.XLDApeDecoder 0x007406d9 CAPEDecompress::DecodeBlocksToFrameBuffer(int) + 1065
2  jp.tmkk.XLDApeDecoder 0x0074088d CAPEDecompress::FillFrameBuffer() + 93
3  jp.tmkk.XLDApeDecoder 0x00741c7b CAPEDecompress::GetData(char*, int, int*) + 123
4  jp.tmkk.XLDApeDecoder 0x0073aa31 -[XLDApeDecoder decodeToBuffer:frames:] + 115
5  jp.tmkk.XLD   0x000354c6 -[XLDConverterTask convert] + 566
Thread 10:
4  jp.tmkk.XLDAlacOutput 0x0072f0b7 -[XLDAlacOutputTask finalize] + 5312
Thread 4 crashed with X86 Thread State (32-bit):
  eax: 0xffff0893  ebx: 0x97842e39  ecx: 0x0000000f  edx: 0xfffff980
  edi: 0x00a41e80  esi: 0x151f9680  ebp: 0xb02209b8  esp: 0xb02209b0
  ss: 0x0000001f  efl: 0x00010216  eip: 0xffff08a0  cs: 0x00000017
  ds: 0x0000001f  es: 0x0000001f  fs: 0x0000001f  gs: 0x00000037
  cr2: 0x151f9000
Binary Images:
0x1000 - 0x6dfe3 +jp.tmkk.XLD 20101128 (126.0) <6E24A7EA-FE2C-2C79-1A1E-8092C133A29A> /Applications/XLD.app/Contents/MacOS/XLD
  0x8f000 - 0x9afff +CDDB ??? (???) /Applications/XLD.app/Contents/Frameworks/CDDB.framework/Versions/A/CDDB
  0xa2000 -  0x103fcf +Musicbrainz ??? (???) /Applications/XLD.app/Contents/Frameworks/Musicbrainz.framework/Versions/A/Musicbrainz
  0x161000 -  0x1bdfe7 +Sndfile ??? (???) <4F69600F-C387-4869-89C8-FAA1A7616FB8> /Applications/XLD.app/Contents/Frameworks/Sndfile.framework/Versions/A/Sndfile
  0x4f6000 -  0x4f9ff7 +jp.tmkk.XLDFlacDecoder ??? (1.0) <5FCE7C45-3C14-4345-B339-A27F8F3A8F67> /Applications/XLD.app/Contents/PlugIns/XLDFlacDecoder.bundle/Contents/MacOS/XLDFlacDecoder
  0x700000 -  0x707ff7 +jp.tmkk.XLDAacOutput ??? (1.0) <6468D5F6-2AB6-FF35-C559-174BDAC361B8> /Applications/XLD.app/Contents/PlugIns/XLDAacOutput.bundle/Contents/MacOS/XLDAacOutput
  0x70d000 -  0x719ff7 +jp.tmkk.XLDAacOutput2 ??? (1.0) <59982F6D-1F3D-DD46-7BDF-718415CCC402> /Applications/XLD.app/Contents/PlugIns/XLDAacOutput2.bundle/Contents/MacOS/XLDAacOutput2
  0x71f000 -  0x724ff7 +jp.tmkk.XLDAlacDecoder ??? (1.0) <FA1EBE57-8264-1DE8-83EC-ABD5FD6BD064> /Applications/XLD.app/Contents/PlugIns/XLDAlacDecoder.bundle/Contents/MacOS/XLDAlacDecoder
  0x72a000 -  0x733ff7 +jp.tmkk.XLDAlacOutput ??? (1.0) <7C436CAD-08CF-9FC8-D56E-1A1C7C9AE674> /Applications/XLD.app/Contents/PlugIns/XLDAlacOutput.bundle/Contents/MacOS/XLDAlacOutput
  0x739000 -  0x75bffa +jp.tmkk.XLDApeDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDApeDecoder.bundle/Contents/MacOS/XLDApeDecoder
  0x76c000 -  0x7b3fd7 +FLAC ??? (???) /Applications/XLD.app/Contents/Frameworks/FLAC.framework/Versions/A/FLAC
  0x7c4000 -  0x7c6ff7 +Ogg ??? (???) <AC76D238-F8FC-CC14-8FBF-CC36626850D2> /Applications/XLD.app/Contents/Frameworks/Ogg.framework/Versions/A/Ogg
  0x7c9000 -  0x7cdff7 +jp.tmkk.XLDFlacOutput ??? (1.0) <BF79E52E-7C4A-C6A5-8F96-9E61837BBC8A> /Applications/XLD.app/Contents/PlugIns/XLDFlacOutput.bundle/Contents/MacOS/XLDFlacOutput
  0x7d3000 -  0x7d8ff7 +jp.tmkk.XLDHEAACOutput ??? (1.0) <7DAAEB64-13F1-1988-2434-947ABABACDF0> /Applications/XLD.app/Contents/PlugIns/XLDHEAACOutput.bundle/Contents/MacOS/XLDHEAACOutput
  0x7de000 -  0x7dfffb +jp.tmkk.XLDLibsndfileDecoder ??? (1.0) <D0584CB5-71CB-4F56-BCE5-EA78569BA91D> /Applications/XLD.app/Contents/PlugIns/XLDLibsndfileDecoder.bundle/Contents/MacOS/XLDLibsndfileDecoder
  0x7e4000 -  0x7e5ff7 +jp.tmkk.XLDMP3Decoder ??? (1.0) <AB512F41-0982-4B4A-9050-87DCD4EF9AF7> /Applications/XLD.app/Contents/PlugIns/XLDMP3Decoder.bundle/Contents/MacOS/XLDMP3Decoder
  0x7ea000 -  0x7f1fef +jp.tmkk.XLDShortenDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDShortenDecoder.bundle/Contents/MacOS/XLDShortenDecoder
  0x7f9000 -  0x7f9ff7 +jp.tmkk.XLDSparkleUpdater ??? (1.0) <A5BB9D62-1F1D-46FA-8C5F-28FA538A8967> /Applications/XLD.app/Contents/PlugIns/XLDSparkleUpdater.bundle/Contents/MacOS/XLDSparkleUpdater
 0x1d5a000 -  0x1d94fff +jp.tmkk.XLDLameOutput ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDLameOutput.bundle/Contents/MacOS/XLDLameOutput
 0x1db1000 -  0x1dc4fff +org.andymatuschak.Sparkle 1.5 Beta (bzr) (1.5) <C1C2F3B9-7EC8-116D-B7C6-4900BAAF3197> /Applications/XLD.app/Contents/PlugIns/XLDSparkleUpdater.bundle/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
 0x1dd2000 -  0x1dd4fff +jp.tmkk.XLDTakDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDTakDecoder.bundle/Contents/MacOS/XLDTakDecoder
 0x1dd9000 -  0x1ddcff3 +jp.tmkk.XLDTtaDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDTtaDecoder.bundle/Contents/MacOS/XLDTtaDecoder
 0x1de1000 -  0x1de4ff7 +jp.tmkk.XLDVorbisOutput ??? (1.0) <551B8822-EA7A-84CF-E819-95FDBC48343C> /Applications/XLD.app/Contents/PlugIns/XLDVorbisOutput.bundle/Contents/MacOS/XLDVorbisOutput
 0x1dea000 -  0x1decff3 +jp.tmkk.XLDWavpackDecoder ??? (1.0) <3FCE2546-9E80-4919-8A24-24D45C5E81B4> /Applications/XLD.app/Contents/PlugIns/XLDWavpackDecoder.bundle/Contents/MacOS/XLDWavpackDecoder
 0x1df1000 -  0x1df4ff7 +jp.tmkk.XLDWavpackOutput ??? (1.0) <975A7869-AE94-DDB4-E478-1DA35B51D390> /Applications/XLD.app/Contents/PlugIns/XLDWavpackOutput.bundle/Contents/MacOS/XLDWavpackOutput
0x13129000 - 0x1314dff7 +Vorbis ??? (???) <EA3859B9-05F9-20AD-6A02-A43E1E1827DA> /Applications/XLD.app/Contents/Frameworks/Vorbis.framework/Versions/A/Vorbis
0x1327b000 - 0x132a4fe3 +WavPack ??? (???) <E660876F-9079-45BD-B12D-4391A2294158> /Applications/XLD.app/Contents/Frameworks/WavPack.framework/Versions/A/WavPack
0x13406000 - 0x1340aff3 +com.stclairsoft.DefaultFolderX.osax Default Folder X Addition version 1.0 (4.3.10) <AE13AC3A-2A5F-DE8A-DAA4-D4B5AA82F3F0> /Users/michaelferrari/Library/ScriptingAdditions/Default Folder X Addition.osax/Contents/MacOS/Default Folder X Addition
0x14bc9000 - 0x14beafef +com.stclairsoft.DefaultFolderX.CarbonPatcher kBundleVersion (kBundleVersion) <E15B9B22-664E-6D25-CD6A-99786FBDDF79> /Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Carbon Patcher.bundle/Contents/MacOS/Carbon Patcher
0x14bf5000 - 0x14c15fff +Cocoa Patcher ??? (???) <FBEBB8D4-4961-2AB7-D021-FF7072717B5D> /Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Cocoa Patcher.bundle/Contents/MacOS/Cocoa Patcher
0x14c8b000 - 0x14c8dff3  com.apple.LiveType.component 2.1.4 (2.1.4) <D60E2537-3B47-EA99-0077-6CE394378D07> /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x14c93000 - 0x14cf7fe2  com.apple.LiveType.framework 2.1.4 (2.1.4) <7AABA687-4323-E5B9-BA04-8F61C217E6FD> /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
0x14d17000 - 0x14d5dffb  com.apple.motion.component 1.0 (729) <494487C6-EA30-43DD-39E4-BED23C5A5B1C> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0x14d63000 - 0x14d65ff7  Motion 729.0.0 (compatibility 1.0.0) <051B60E9-B39F-EBB2-5B96-F088D147E78C> /Library/Frameworks/Motion.framework/Versions/A/Motion
0x14d6b000 - 0x14e08ff8  com.apple.procore.framework 4.0.2 (757) <D3146F1E-F86D-F2A2-509B-E3F9640CBE40> /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
0x14e48000 - 0x1503cff7 +com.elgato.mpegsupport EyeTV MPEG Support 1.2 (build 50) (1.2) <0A9DC100-CA59-9826-49DB-14FFD9245C97> /Library/QuickTime/EyeTV MPEG Support.component/Contents/MacOS/EyeTV MPEG Support
0x16fa0000 - 0x1717eff3  com.apple.audio.codecs.Components 2.0.2 (2.0.2) <8B43D24A-277D-5F42-8741-FC8736C44162> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x99331000 - 0x9950cff3  libType1Scaler.dylib ??? (???) <A7AB841A-3F40-E0B8-ADDD-44014C7287C9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
Reply #74
i tried to test my cd drive with DAEQualitiy from exactaudiocopy. I prepared the test cd and tried to read out this cd with XLD in Burst mode as described in the tutorial. I can reproducible get XLD crashing. It always happens at position about 62%. I tried it with the internal and an external cd drive. It also happens when using XLD Secure Ripping instead of Burst.
Process:        XLD [465]
Version:        20101212 (126.2)
OS Version:      Mac OS X 10.6.6 (10J567)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000032603fb2
Crashed Thread:  4
Thread 4 Crashed:
0  jp.tmkk.XLD                     0x000446d0 -[XLDCDDARipper decodeToBuffer:frames:] + 384
1  jp.tmkk.XLD                     0x00035636 -[XLDConverterTask convert] + 566
2  com.apple.Foundation             0x92a05bf0 -[NSThread main] + 45
3  com.apple.Foundation             0x92a05ba0 __NSThread__main__ + 1499
4  libSystem.B.dylib               0x95ff585d _pthread_start + 345
5  libSystem.B.dylib               0x95ff56e2 thread_start + 34
Can someone help me?
jerry
