Topic: MP3Trim Pro (Read 2707 times) previous topic - next topic
MP3Trim Pro
i just downloaded an album, every track of it had a last bad frame. so i decided to let mp3trim pro try to repair it, encspot doesn't show bad last frames any more. I did this also wirh other MP3s, which had no last bad frames, but also there MP3Trim cut off some kbytes of all mp3s... s o what does it do exactly?
Greets
MP3Trim Pro
It removes digital silence from the start and end of MP3s
"You have the right to remain silent. Anything you say will be misquoted, then used against you."
MP3Trim Pro
It actually can do more than that depending on how you have configured it. I don't know what the default settings are exactly but it can also:
- remove bad first (and last) frames
- remove frames with bad frame headers*
- remove ID 3 tags (don't think this is default)
- fix a number of smaller errors which I don't remember...
The first three reduces the file size, but I don't think the laste one does.
* I have actually turned this off because I think it introduces more artifacts, when listening to the file with Winamps internal decoder. I guess the best way is to mute such frames, which I think that Winamps decoder does.
