Topic: [Not my release] foo_uie_panel_splitter (Read 413705 times) previous topic - next topic
Reply #625
Stupid question but do the Filters not work with this plugin? or am i doing something wrong ?
Reply #626
First... What are you trying to do?
Because I can't think any situation where PSS could interfere with the filter's work.
<insert signature here>
Reply #627
They just dont work, I have Artist/Album/Genre filters(in that order) but when i click a Artist it doesn't change the Album/Genre filters..
Reply #628
they don't work if you put them directly in a PSS.
To make them work (linked each other), put a Horizontal or Vertical splitter in the PSS and then put them in this Horizontal/Vertical Splitter
in the CUI layout editor, you should have something like this:
Panel Stack Splitter
.....Horizontal Splitter
..........Filter
..........Filter
..........Filter
HTH.
Reply #629
Falstaff solved my problem
Very helpful, learn something new with foobar everyday!
Thanks alot guys..
Reply #631
adding this on your TODO list would be nice
humm?
I can't figure out the reason 'no cache feature' is needed.
Could you explain in more detail?
Reply #632
hi -
  a couple of quick questions....  i'm trying to use a shpeck visualization panel as a background for my pss layout - can't seem to get it to work the way i want.  when i place the shpeck panel in the splitter, it puts it on top of whatever script i have (i can of course resize it using the forced layout,) but what i really want is to have the script written over the shpeck panel...  is this possible, or am i dreaming?
  in the meantime, i've tried to use a button to activate the shpeck panel, and for some reason it doesn't work....  the script looks like this:
$imagebutton($add($get(tth),192),$add($get(ttv),18),,,
images\stanton\vis.png,images\stanton\hot.png,
COMMAND: View/Visualisations/Shpeck - Start 'MilkDrop 2.1 / MilkDrop 2.1')
i've got a bunch of other buttons in the pss that work just fine, and if i change the command line to:
...COMMAND: View/Visualisations/Spectrum)
      it works...  i've made sure i've written the Shpeck command exactly as it appears in the menu dropdown, and then fiddled with it in a hundred different ways, but no dice...  any ideas why?
  thanks -
      j
i'er heights
Reply #633
Activation doesn't work this way. I had the same problem a while ago, but nobody cared. The solution I found is not to put Shpeck into a PSS but a Columns UI Panel and either have it running permanently (you can hide its parent PSS on demand but it will still run invisibly and consume resources) or use a more or less ugly workaround with a Columns UI Tab Stack. With a Tab Stack, one can make proper use of Shpeck's feature to automatically turn off while hidden.
It led to this (see picture's upper left corner): http://www.hydrogenaudio.org/forums/index....st&p=642203
Reply #634
@durch -
  thanks for the reply...  seems like this would be a common idea, but it doesn't look like there's an easy solution.  i'll play around with the panel tabs, and see what i can come up with -
i'er heights
Reply #635
I'd like a section of my foobar2k to automatically show the last 5 albums added to the media library.. any way to do that?
I know I can do that with foo_playcount, but they appear in an autoplaylist. I just want the album covers to show on a small section of foobar. Then, when I click on one of the cover, the album/tracks appears in the playlist.
Reply #636
I'd like to know if anyone knows a method of making a text button's text underlined on mouse hover. Maybe this is not really a PSS related question, but I don't know of native title formatting methods.
Reply #637
@durch-
  you could always 'fake' a text button, by using an image button that is only text over a transparent background - then as the hover image, use the same text, but underlined...
i'er heights
Reply #638
That's not a bad idea in general, but I'd like to use underlining for text like %artist% and %title%. These are not predictable.
Reply #639
WIth the biography panel we get a tag for each song with similar artists.
I was wondering if anyone saw a way to separate those artists in the string and create a text button which would point the artist lastfm page?
My problem with that is that i think we cant do for loops with panel splitter. Am i wrong?
Reply #640
you can use WSH panel Mod to separate artists and to create link button to last.fm ...
Reply #641
it maybe be possible if you used $drawtextex to write the details. then use a text button on top and have the hover text as something like...
$repeat(_,$len(%aritst%))
Reply #642
I have no idea on how to code that in Wsh Panel Mod. COuld you help me a bit?
Reply #643
about the $getsyscolour()...
is there a list or something that defines which number is which colour?
for example, i want something in my config to have the same color as window border... which number is that?
or how should i find out without having to try and check the colors one by one?
Reply #644
If the colours are the same as in the Windows SDK, this may help.  This is the help info for the Windows SDK GetSysColor():
COLOR_3DDKSHADOW
21
Dark shadow for three-dimensional display elements.
COLOR_3DFACE
15
Face color for three-dimensional display elements and for dialog box backgrounds.
COLOR_3DHIGHLIGHT
20
Highlight color for three-dimensional display elements (for edges facing the light source.)
COLOR_3DHILIGHT
20
COLOR_3DLIGHT
22
Light color for three-dimensional display elements (for edges facing the light source.)
COLOR_3DSHADOW
16
Shadow color for three-dimensional display elements (for edges facing away from the light source).
COLOR_ACTIVEBORDER
10
Active window border.
COLOR_ACTIVECAPTION
2
Active window title bar.
Specifies the left side color in the color gradient of an active window's title bar if the gradient effect is enabled.
Windows NT and Windows 95:  This remark does not apply.
COLOR_APPWORKSPACE
12
Background color of multiple document interface (MDI) applications.
COLOR_BACKGROUND
1
Desktop.
COLOR_BTNFACE
15
COLOR_BTNHIGHLIGHT
20
COLOR_BTNHIGHLIGHT
20
COLOR_BTNSHADOW
16
COLOR_BTNTEXT
18
Text on push buttons.
COLOR_CAPTIONTEXT
9
Text in caption, size box, and scroll bar arrow box.
COLOR_DESKTOP
1
Desktop.
COLOR_GRADIENTACTIVECAPTION
27
Right side color in the color gradient of an active window's title bar.
COLOR_ACTIVECAPTION specifies the left side color. Use SPI_GETGRADIENTCAPTIONS with the SystemParametersInfo function to determine whether the gradient effect is enabled.
Windows NT and Windows 95:  This value is not supported.
COLOR_GRADIENTINACTIVECAPTION
28
Right side color in the color gradient of an inactive window's title bar.
COLOR_INACTIVECAPTION specifies the left side color.
COLOR_GRAYTEXT
17
Grayed (disabled) text. This color is set to 0 if the current display driver does not support a solid gray color.
COLOR_HIGHLIGHT
13
Item(s) selected in a control.
COLOR_HIGHLIGHTTEXT
14
Text of item(s) selected in a control.
COLOR_HOTLIGHT
26
Color for a hot-tracked item. Single clicking a hot-tracked item executes the item.
COLOR_INACTIVEBORDER
11
Inactive window border.
3
Inactive window caption.
Specifies the left side color in the color gradient of an inactive window's title bar if the gradient effect is enabled.
COLOR_INACTIVECAPTIONTEXT
19
Color of text in an inactive caption.
COLOR_INFOBK
24
Background color for tooltip controls.
COLOR_INFOTEXT
23
Text color for tooltip controls.
COLOR_MENU
4
Menu background.
COLOR_MENUHILIGHT
29
The color used to highlight menu items when the menu appears as a flat menu (see SystemParametersInfo). The highlighted menu item is outlined with
COLOR_HIGHLIGHT.
Windows 2000/NT and Windows Me/98/95:  This value is not supported.
COLOR_MENUBAR
30
The background color for the menu bar when menus appear as flat menus (see SystemParametersInfo). However,
COLOR_MENU continues to specify the background color of the menu popup.
COLOR_MENUTEXT
7
Text in menus.
COLOR_SCROLLBAR
0
Scroll bar gray area.
COLOR_WINDOW
5
Window background.
COLOR_WINDOWFRAME
6
Window frame.
COLOR_WINDOWTEXT
8
Text in windows.
Reply #645
Hi, how can I add imagebutton to work with selected tracks however not toggle all component to follow cursor titleformat mode?
For example, I need button #Write DiscoGS Tags# which will work only with selected tracks, when titleformat mode of ps is now_playing..
Reply #646
Use command "TFMODE:1" if you want the button to follow cursor.
Reply #647
This command switch everything to follow cursor, not only button I need.
I have album art  and rating images drawed by PSS. When I press the button:
$imagebutton($get(button_left),$get(button_top),,,
%foobar_path%\images\Buttons\discogs1.png,
%foobar_path%\images\Buttons\discogs.png,
TFMODE:1;
CONTEXT: 'Discogs/Write Tags...'
Album art and rating are switching to follow cursor to.. But I want them to keep now_playing mode..
Reply #648
well, nobody can't answer my previous question, so here are the new one:
how can i get context command with quick tagger action? PSS script doesnt see any variables in build-in list of context commands?
Anyone? Please.
Reply #649
for your previous question: you have to make an addintional PSS-panel and set the 'title format on startup: follow cursor' whereas all other buttons stay in a PSS-panel that uses 'now playing'
