Topic: Peakmeter Spectrum component (Read 230030 times) previous topic - next topic
Reply #125
Is it possible for a plugin like this to toggle between being placed before or after the DSP chain?  Currently it goes into affect after all DSPs have been applied.
Reply #126
I'm a bit late to this party and judging by the absence of the component creator and the (lack of) responses to the last few fellas, I don't fancy my chances at a solution being provided here. However, is there a way to add the Peakmeter Spectrum so that it's available in the View -> Visualisations menu, such that I can open it in its own window as I can with the default Spectrum Analyser?
Reply #129
I confirm that current version: 0.2.0.0 beta is incompatible with newer GPUs. I'm using Radeon HD7750 and Peakmeter spectrum is very laggy. Peakmeter spectrum raises GPU usage to 99% (as shown in AMD Catalyst Control Center)
Once you minimize foobar2000 or close the Peakmeter spectrum plugin, GPU usage lowers to normal.
It's nice that we have Musical Spectrum plugin as a great alternative:
Musical Spectrum
Reply #130
Oh, really? I'm very sorry!
I'm only using the HD 7700.
Reply #131
Microsoft released a batch of patches at the end of October - beginning of November 2015. One of these - I do not know which - broke this plugin on 2 of my PCs - Windows 7 - 64 bit - SP1 ;-(
The symptom is a complete foobar2000 crash when using the plugin - whether a file is playing or not!
Luckily, there is a workaround for this. The crash occurs when, and only when as far as I can see, you set the following:
Right Click panel > Preferences > Spectrum Analyzer > Options > Main Bar > Size > 4
The default for Size is 8. Once the crash has occurred - there is no way to display the plugin to fix this.
Workaround:
- Download the 0102 older version of the DLL
- Replace the 0200 version of the DLL with the old one in ..\user-components\foo_uie_vis_peakmeter_spectrum
- Next time you launch foobar2000, the display will default to Size = 8
- Customise the display to how you had it before EXCEPT make Size = 5 - not Size = 4 ;-)
- Replace the 0102 version of the DLL with the 0200 version of the DLL
I hope this works for you.
Mike
PS My video card is a AMD Radeon HD 7570 - this card does not have any GPU problems as reported my another user.
Reply #132
Are you ever going to release the source since you do not seem to work on it anymore.. I would love to add 16k FFT and co.
Re: Peakmeter Spectrum component
Reply #133
I'm new to foobar2000 and installed DarkOne V4 and everything works fine except this component.  It shows up but when I play a sound nothing happens.  The db meter for both channels never moves.  Can anyone point me in the right direction to get this working correctly?  I've searched google and gone through every setting I can think of but nothing seems to fix it.
Reply #134
The download link is down :c
Reply #137
The download is not available anymore. Can you please update? Thanks!
Reply #138
Reply #139
According to the troubleshooter, the peakmeter plugin may cause crashes and is outdated. You may want to try "Musical Spectrum". I consider it a good alternative.
Reply #140
Reply #141
seems doesnt download, any help
Reply #143
i guess no x64-version will be released, any recommended alternatives? :-)
Reply #144
i would even take a stab at updating the plugin to the v2.0 SDK and x64 if the sources were to be released...
let's hope @foo_pm‍ reads this ad decides to dig up and release the source O:)
Reply #145
pqyt has attempted an x64 re-write but has put it on the back burner for now: https://hydrogenaud.io/index.php/topic,123394.msg1019902.html#msg1019902 .
Also, the code has been backported and posted but for use in another player: https://github.com/cboxdoerfer/ddb_musical_spectrum .
Reply #146
Because the existing download links to this resource are no longer working, I decided to offer it via one of my cloud spaces. The archive holds the most recent version, a few presets as samples of how you can set it up, and copies of the original website and the website describing its function in PDF & HTML, size ~2MB.
In case the following link will get defunct, you can drop me a PM, and I'll re-upload it after taking notice.
I can not tell, how long it will be online, because I'm serious ill, but maybe internxt won't delete my account when I'm going silent, or one of you downloading it step in and hold it accessible.
So, have fun:
https://drive.internxt.com/sh/file/b60542e5-2993-4f1d-89b9-5c133be4de1c/78d594c92326465f8907548f54fb110b387f81b8aa891e6423a03b3849aee471
Michelist
Reply #147
Thank you, Michelist; this one of my favorite components.
...and I hope you feel better soon!
Reply #149
It's part of 0.7.5.0-beta2.
Hmmm, very interesting. I'm using 18 of those in my skin.
Would it be possible to configure this component to mimic the attached screenshots?
Left side is an instance with number of channels vertical bars and right side is a peakmeter with number of channels horizontal bars.
EDIT: I have flavors for up to 2ch, up to 6ch, and 7+ch that use the 8ch display.
