Topic: Bands starting with the word THE (Read 8020 times) previous topic - next topic
Was wondering how I can get foobar to arrange my playlist alphabetically by disregarding the word THE when a band name starts with THE, i.e. THE BLACK CROWES, i want that to be in the B's instead of the T's
Here's what I have now:
Moderation: Replaced large screenshot by a thumbnail.
Please do not inline images larger than roughly 800x600 and 80KB.
Instead of
%ALBUM ARTIST%
you could just write
$if($stricmp($left(%ALBUM ARTIST%,4),'The '),$substr(%ALBUM ARTIST%,5,$len(%ALBUM ARTIST%))', The ',%ALBUM ARTIST%)
. This will basically replace "The <artist>" with "<artist>, The" and otherwise leave the name as it is. You can also use it in the Album List.
Instead of
%ALBUM ARTIST%
Is there a way to run that AND one to relocate "A"??
Example:
A New Kind of American Saint
becomes
New Kind of American Saint, A
I don't understand how you can run 2 stings back to back like that.
Also, can these strings be applied in the masstagger component to permanently change the ARTIST field of the ID3 Tags to always ensure a good sort, even if someone else uses them who doesn't use foobar?
I just answered my own question, that string works perfectly in masstagger.
I just renamed every band with "The" to place it on the end, after the title, in one click.
It worked fine in the Album List component as well, but I was looking for something a little more permanent.
Thanks so much.
without rename file you can use this string:
$cwb_ltrim(%artist%,The ,A ,La )$if($longer($replace(%artist%,$cwb_ltrim(%artist%,The ,A ,La ),),0),', '$replace(%artist%,$cwb_ltrim(%artist%,The ,A ,La ),))
becomes
required:  foo_cwb_hooks
Music is my first love.
Another Question:
How to ignore leading "The", etc. when sorting, but without set "The" at the end.
Is this possible?
Another Question:
Is this possible?
It's almost the same:
$if($stricmp($left(%ALBUM ARTIST%,4),'The '),$substr(%ALBUM ARTIST%,5,$len(%ALBUM ARTIST%)),%ALBUM ARTIST%)
thanks
Ok, another question, every time I load a new playlist, it automatically sorts them by album name and I have to go and select  menu > edit > sort > sort by  to get them in the order I would like.  Is there a way to get them to automatically sort the way that I like them to?, which is:
$if($stricmp($left(%ALBUM ARTIST%,4),'The '),$substr(%ALBUM ARTIST%,5,$len(%ALBUM ARTIST%))', The ',%ALBUM ARTIST%) - %DATE% - %ALBUM% - %DISCNUMBER% - %TRACKNUMBER% - %TITLE%
There's an option in foobar2000's preferences. Actually, it's the first one on the "General" page. Not too hard to find
That acutall didn't work for me, but I figured it out anyway.  I just had to right click in the directory frame, and under VIEW > I just selected "by directory structure" instead of "by artist" which was what I had checked before.  Thanks anyway though!  Cheers!
Hmmm well that didn't actually work completey...... maybe album/artist?
Another Question:
Is this possible?
I'd like to sort similarly, but leaving "The " at the beginning. I enjoyed the ability to use a custom sort string in the library in 0.8.3.
Currently, I use Frank Bicking's Facets with the string:
[$if($strcmp($left(%album artist%,2),A ),$right(%album artist%,$sub($len(%album artist%),2))', 'A,%album artist%)]
to take care of the "A " Artists since as it is currently, Facets takes care of "The " artists.
Previously I had used:
$if3($if($strcmp($left(%album artist%,2),A ),$right(%album artist%,$sub($len(%album artist%),2))', 'A),$if($strcmp($left(%album artist%,4),The ),$right(%album artist%,$sub($len(%album artist%),4))', 'The),%album artist%)
Which moved both "A " and "The " to the end of the string name. I might start using CWB Hooks with $cwb_ltrim(%artist%,The ,A ,La ,El ,Los ) if it works with 0.9.5 (I don't know if it does).
That actually didn't work for me, but I figured it out anyway.  I just had to right click in the directory frame, and under VIEW > I just selected "by directory structure" instead of "by artist" which was what I had checked before.  Thanks anyway though!  Cheers!
Hmmm well that didn't actually work completely...... maybe album/artist?
I use directory structure also. However I just renamed the folders. For example: Lord of the Rings, The is a folder, and inside are individual folders for each of the three movie soundtracks. Now, they are alphabetized correctly wherever I look, in Foobar or in Windows Explorer. The tags I left unaltered.
