Topic: foo_vis_shpeck (Read 744488 times) previous topic - next topic
foo_vis_shpeck
Reply #125
Uhmhuh... Shpeck v0.1.3:
<obsolete links removed, see the first post in this thread for information about the latest version>
Changelog:
  • Handling of "embedded windows" changed again (saving the position when only moved around, occasional strange behaviour).
  • Fixed random preset toggling. (Thanks, WWNSX, that was one of the things I forgot I had changed and didn't tested it properly.)
  • Fixed and added commands (seeking backwards, non-standard previous song command, repeat, shuffle).
  • Fixed fake Winamp window title for compatibility (e.g. GeekAmp).
Edit - Known issues:
  • MilkDrop 1.04 closes itself when attempted to enter the "fake fullscreen" mode. Uncheck "Integrate with Winamp skin" in its configuration to rectify temporarily.
one bug i noticed in  Shpeck v0.1.1 and v0.1.2 is that if I hit P to bring up the playlist in Milkdrop that i can no longer hit enter to start a different song once i've selected it using the up and down arrow keys.
The problem is that this works fine for me. I launch it, press P, choose a song, press Enter and it starts playing. I choose another, press Enter and it plays the other one. Any ideas how can I break it? (Are you running Shpeck inside a CUI panel?)
Looks like you've been hard at work because I noticed the dll file drooped from 248kb in Shpeck 0.1.1 to 160kb in Shpeck 0.1.2
Meh, I only switched to dynamically linked CRT, no work on my part there.
foo_vis_shpeck
Reply #126
Thanks. Commands and title everything works great! ^^
foo_vis_shpeck
Reply #128
If CUI means columns UI no I'm not using that. I'm using Cepiperez's Dark config 1.5c http://www.hydrogenaudio.org/forums/index....showtopic=53703
which means i'm using Panels UI 14.9 beta. I'm not good on coding my own configs etc yet so Shpeck pops up in it's own window then i either leave it like that or make it full screen.
Okay never mind after changing some global keys and trying to figure it out. I changed Cursor follows Playback to Playback Follows Cursor and it works fine now but whats more weird is that i can have both of those selected at the same time and it works anyway but i'm sure that's not a Shpeck bug.
I'm happy to report that Scroll lock works now too
I don't have 1.04 installed but I know you can get 1.04d from the milkdrop uk site but I'm pretty sure the last version of milkdrop 1 was 1.04e which was included with winamp 5.35. i have 1.04e as a separate archive so maybe I'll try tomorrow if no one else has by then. I might anyway just to look at something regrading FPS difference between 1.04e and the new milkdrop2
foo_vis_shpeck
Reply #129
Well, I believe it is. I tested it now and it is not possible to start any other track when "Playback Follows Cursor" is not checked. I'll see why, it should be made so that is does not depend on this setting, like when you double-click on a normal playlist entry.
foo_vis_shpeck
Reply #130
Okay. I noticed another bug with MilkDrop 1.04e besides the playlist. When I start it in window mode and then try to Go Fullscreen it crashes. The only way to get there is to select Start Fullscreen in its configuration. Then evrything works fine....
Here it is:
http://www.flyupload.com/?fid=9601462
EDIT: It works alright with shpeck 0.1.2 or whatever the last 248KB version was....
foo_vis_shpeck
Reply #131
There is a known bug in v0.1.3 - as I added to the original release post: "MilkDrop 1.04 closes itself when attempted to enter the "fake fullscreen" mode. Uncheck "Integrate with Winamp skin" in its configuration to rectify temporarily.".
Is it the same problem, i.e. are both "Integrate with Winamp" and "Use Fake fullscreen mode" boxes checked? I wasn't able to replicate this using other options.
foo_vis_shpeck
Reply #132
My bad it was "Integrate with winamp" option...
foo_vis_shpeck
Reply #133
Never mind.
Btw, the "Integrate with Winamp" option is not so useful for MilkDrop 1, because it can run inside a window it creates itself pretty well. But most other/never plugins use that way (to use the skinned windows, originally) and I don't know what else has been broken, so I'm going to fix it anyway soon. I'm just waiting for more bugs (or improvements) to surface before the next release.
foo_vis_shpeck
Reply #134
Sweet, thanks for the updates!
foo_vis_shpeck
Reply #136
Hm... Does anyone else have problems with visualizations pausing every few seconds? It seems to happen with mine, regardless of resolution.
So this doesn't happen to anyone else?
I had that problem a long time ago, and it was probably with Winamp.
Do you have a Promise controller ? or a JMicron ?
Give us more detail about your hardware, drivers & software setups.
foo_vis_shpeck
Reply #137
Thanks for this plugin. Works like a charm.
foo_vis_shpeck
Reply #138
I've heard some laptops have problems with visualizations because of how mobile processors work...?
foo_vis_shpeck
Reply #139
Hi Yirkha,
I tried the new version, but still can't get Classic Spectr to work. It still pumps foobar into 99% cpu usage and I have to ctrl+alt+del it. Could it be because I am still on foobar 0.9.4.3?
foo_vis_shpeck
Reply #140
Actually, I'm fairly certain this isn't a cpu or graphics card problem. I downloaded ProjectM and there are absolutely no slow down problems... Is there some strange setting that's causing these problems with Shpeck?
EDIT: I have now tested the visualization plugins in winamp itself, and they run seamlessly. Hm...
foo_vis_shpeck
Reply #142
No, I just didn't tested those weird nonstandard GUIs much lately. But try the new version, should finally work fine even in panel.
Well, I updated to foobar 0.9.5 tonight, and it pretty much solved whatever problem I had. I don't know what was wrong, but I don't really care anymore, haha.
Good to hear that - it could be any weird misbehaving component in the old installation.
Shpeck v0.2.0
Changelog:
  • Optimalized processing of multichannel audio & spectrum data.
  • More acurate waveform data are now passed to the plugins.
  • The command "Next" goes to random entry if random playlist order is selected. (edit: Haha, see below.)
  • Fixed: Milkdrop 1.04 fake fullscreen option results in close.
  • Fixed: Closing AVS window does not stop it completely, it has to be closed again by "Shpeck/Stop" command afterwards.
  • Fixed: Position of the fake Winamp's window is illegal. (Now uses v2.4 skin window size @ 0,0.)
  • Panel integration improvements:
  • - Rewritten panel embedding interface for better compatibility.
  • - Fixed: Context menu of some plugins is not accessible because it's being overriden by the Column UI's default one.
  • - Fixed: MilkDrop2 in panel cannot be run twice ("Can't register window class.").
  • - Fixed: MilkDrop2/AVS in panel creates multiple windows when switching to/from fullscreen mode.
Not so important notice:
Foo_vis_shpeck is not based on any code from foo_bacon, foo_winamp_spam or other emulators. Actually, I have found out that Bacon's source code has been available after creating most of the stuff (when I was searching for a way how to disable foo_osd when in fullscreen mode, only to see that it's not possible to use that method any more) and I was happy that I did it all my way.
Enjoy the new version and report the bugs!
foo_vis_shpeck
Reply #143
I found a little problem on this version:
  in milkdrop 1.04 or 2.0 the "B" key (which means going to play next song) doe not work, but with 0.1.1 it works fine. a little weird
thanks for your great work!
Moderation: Removed unnecessary full-quote of the preceding post.
foo_vis_shpeck
Reply #144
Yeah, a little weird indeed . That's what you get for implementing what does not need to be implemented using obsolete API without testing. There is only one thing in the world worse than that - unnecessary full-quoting.
Shpeck v0.2.1
Changelog:
  • Revert of the 0.2.0 "feature" #3.
foo_vis_shpeck
Reply #145
it works well now!
foo_vis_shpeck
Reply #146
had 0.2.0 and updated to 0.2.1 and CRASH
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 025B3A89h
Access violation, operation: read, address: 02087000h
Call path not available.
Code bytes (025B3A89h):
025B3A49h:  20 02 0F 85 FC 00 00 00 8B 75 88 8B C1 D1 E8 89
025B3A59h:  45 D8 DB 45 D8 85 C0 7D 06 DC 05 D0 8B 5C 02 DC
025B3A69h:  3D E8 8B 5C 02 D9 5D E4 D9 EE D9 55 D4 D9 5D D8
025B3A79h:  33 C0 85 C9 76 18 90 8B D0 83 E2 01 8D 54 95 D4
025B3A89h:  D9 04 86 D8 02 D9 1A 83 C0 01 3B C1 72 E9 D9 45
025B3A99h:  D4 D8 4D E4 D9 5D DC D9 45 DC DB 5D E8 8B 43 14
025B3AA9h:  8A 4D E8 88 8C 07 A4 04 00 00 D9 45 D8 D8 4D E4
025B3AB9h:  D9 5D DC D9 45 DC DB 5D E0 8B 53 14 8A 45 E0 88
Stack (02E5FEE0h):
02E5FEC0h:  00000000 00000051 002569A0 02D1F780
02E5FED0h:  69770000 706D616E 47736956 65487465
02E5FEE0h:  02085810 008F6C6E 7E41928B 025C8028
02E5FEF0h:  02086768 00000084 00000084 0000AC44
02E5FF00h:  00000002 00000003 00000042 025C8028
02E5FF10h:  00000000 00000000 00000000 0000AC44
02E5FF20h:  00000001 00000004 00000000 93F52210
02E5FF30h:  3F979D5C FAC3C6D1 3F8CB35A 00000000
02E5FF40h:  00000000 00000000 00000000 42FE0000
02E5FF50h:  00000000 02E5FFB4 02E5FEE0 02E5FFA8
02E5FF60h:  025C58A8 00000000 02E5FFB4 025B4033
02E5FF70h:  00000000 0012F9EC 02085810 0004063C
02E5FF80h:  00000113 00000001 00000000 008F6BC2
02E5FF90h:  00000461 000002D3 00000000 0000014C
02E5FFA0h:  00000000 02E5FF70 02E5FFDC 025C5FC4
02E5FFB0h:  FFFFFFFF 02E5FFEC 7C80B6A3 008F6C6E
02E5FFC0h:  00000000 0012F9EC 02085810 7FFDC000
02E5FFD0h:  C0000005 02E5FFC0 02E5FB04 FFFFFFFF
02E5FFE0h:  7C839A30 7C80B6B0 00000000 00000000
02E5FFF0h:  00000000 025B3ED0 02085810 00000000
Registers:
EAX: 00000000, EBX: 02085810, ECX: 00000002, EDX: 02E5FF3C
ESI: 02087000, EDI: 00000113, EBP: 02E5FF68, ESP: 02E5FEE0
Crash location: "foo_vis_shpeck", loaded at 025B0000h - 025D9000h
Loaded modules:
foobar2000                      loaded at 00400000h - 00523000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F5000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 7E410000h - 7E4A1000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D7000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 1002A000h
COMDLG32                        loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
guard32                          loaded at 00390000h - 003B2000h
fltLib                          loaded at 4FFE0000h - 4FFE8000h
winsta                          loaded at 76360000h - 76370000h
NETAPI32                        loaded at 5B860000h - 5B8B5000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
ADvdDiscHlp                      loaded at 00A70000h - 00A89000h
MSCTF                            loaded at 74720000h - 7476C000h
AM30131                          loaded at 00AF0000h - 00AFB000h
ws2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_abx                          loaded at 00B70000h - 00BA3000h
foo_albumlist                    loaded at 00BD0000h - 00C37000h
foo_bubble_coverflow            loaded at 00C60000h - 00CE0000h
OPENGL32                        loaded at 5ED00000h - 5EDCC000h
GLU32                            loaded at 68B20000h - 68B40000h
DDRAW                            loaded at 73760000h - 737A9000h
DCIMAN32                        loaded at 73BC0000h - 73BC6000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
foo_burninate                    loaded at 00D10000h - 00D47000h
VERSION                          loaded at 77C00000h - 77C08000h
foo_cdda                        loaded at 00D70000h - 00DA5000h
foo_converter                    loaded at 00DD0000h - 00E39000h
foo_convolve                    loaded at 00E60000h - 00EB1000h
foo_cwbowron                    loaded at 00EE0000h - 00F0A000h
foo_cwb_hooks                    loaded at 00F30000h - 00F7C000h
foo_discogs                      loaded at 00FA0000h - 01041000h
WINMM                            loaded at 76B40000h - 76B6D000h
foo_dockable_panels              loaded at 010E0000h - 01113000h
foo_dsp_crossfader              loaded at 01140000h - 01170000h
foo_dsp_std                      loaded at 01190000h - 011D8000h
foo_dts                          loaded at 01200000h - 0124E000h
foo_facets                      loaded at 01270000h - 012F1000h
OLEAUT32                        loaded at 77120000h - 771AB000h
MSIMG32                          loaded at 76380000h - 76385000h
foo_fileops                      loaded at 01320000h - 01366000h
foo_freedb2                      loaded at 01390000h - 013D1000h
foo_input_alac                  loaded at 01400000h - 0141D000h
foo_input_ds                    loaded at 01440000h - 0146D000h
foo_input_mkx                    loaded at 01490000h - 014C1000h
foo_input_monkey                loaded at 014E0000h - 0152A000h
foo_input_std                    loaded at 01550000h - 01678000h
foo_input_wma                    loaded at 016A0000h - 016CE000h
WMVCore                          loaded at 15110000h - 1536A000h
WMASF                            loaded at 11C70000h - 11CAA000h
foo_lyricsdb                    loaded at 016F0000h - 0171F000h
WININET                          loaded at 42C10000h - 42CDF000h
Normaliz                        loaded at 01730000h - 01739000h
iertutil                        loaded at 42990000h - 429D5000h
foo_menu_addons                  loaded at 01960000h - 019A5000h
foo_misc_addons                  loaded at 019D0000h - 019FD000h
foo_out_asio                    loaded at 01A20000h - 01A57000h
foo_out_ks                      loaded at 01A80000h - 01AAA000h
SETUPAPI                        loaded at 77920000h - 77A13000h
foo_playcount                    loaded at 01AD0000h - 01AF5000h
foo_popupplus                    loaded at 01B20000h - 01BA1000h
RICHED20                        loaded at 74E30000h - 74E9D000h
foo_pqview                      loaded at 01BD0000h - 01BF8000h
foo_rgscan                      loaded at 01C20000h - 01C7A000h
foo_run                          loaded at 01CA0000h - 01CCB000h
foo_uie_albumart                loaded at 01CF0000h - 01D2D000h
foo_uie_albumlist                loaded at 01D50000h - 01D93000h
foo_uie_explorer                loaded at 01DC0000h - 01DFD000h
foo_uie_lyrics                  loaded at 01E20000h - 01E7F000h
foo_uie_playlists_dropdown      loaded at 01EA0000h - 01ED9000h
foo_uie_powerpanels              loaded at 01F00000h - 01F23000h
foo_uie_quicksearch              loaded at 01F50000h - 01F96000h
foo_uie_tabs                    loaded at 01FC0000h - 01FEA000h
foo_uie_trackinfo_mod            loaded at 02010000h - 02066000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_uie_typefind                loaded at 02090000h - 020C0000h
foo_uie_vis_peakmeter_spectrum  loaded at 020E0000h - 0211F000h
foo_uie_wmpvis                  loaded at 02140000h - 02168000h
foo_ui_columns                  loaded at 02190000h - 02298000h
foo_ui_panels                    loaded at 022C0000h - 023A9000h
foo_ui_std                      loaded at 023D0000h - 02491000h
foo_unpack                      loaded at 024C0000h - 024ED000h
foo_utils                        loaded at 02510000h - 02589000h
foo_vis_shpeck                  loaded at 025B0000h - 025D9000h
foo_whatsnew                    loaded at 025F0000h - 02621000h
ctagent                          loaded at 02760000h - 02766000h
vis_avs                          loaded at 02CE0000h - 02D5B000h
MSVFW32                          loaded at 75A70000h - 75A91000h
AVIFIL32                        loaded at 73B50000h - 73B67000h
MSACM32                          loaded at 77BE0000h - 77BF5000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
AddBorder                        loaded at 04030000h - 04036000h
colormap                        loaded at 04040000h - 0404A000h
convolution                      loaded at 04050000h - 04060000h
fyrewurx                        loaded at 04070000h - 04084000h
multifilter                      loaded at 041A0000h - 041A6000h
texer                            loaded at 041B0000h - 041B7000h
texer2                          loaded at 041C0000h - 041CB000h
SHDOCLC                          loaded at 20000000h - 20088000h
Secur32                          loaded at 77FE0000h - 77FF1000h
DSOUND                          loaded at 73F10000h - 73F6C000h
SXS                              loaded at 75E90000h - 75F40000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
wdmaud                          loaded at 72D20000h - 72D29000h
RASAPI32                        loaded at 76EE0000h - 76F1C000h
rasman                          loaded at 76E90000h - 76EA2000h
TAPI32                          loaded at 76EB0000h - 76EDF000h
rtutils                          loaded at 76E80000h - 76E8E000h
msv1_0                          loaded at 77C70000h - 77C93000h
iphlpapi                        loaded at 76D60000h - 76D79000h
USERENV                          loaded at 769C0000h - 76A73000h
sensapi                          loaded at 722B0000h - 722B5000h
mswsock                          loaded at 71A50000h - 71A8F000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
urlmon                          loaded at 42CF0000h - 42E17000h
msacm32                          loaded at 72D10000h - 72D18000h
midimap                          loaded at 77BD0000h - 77BD7000h
DNSAPI                          loaded at 76F20000h - 76F47000h
KsUser                          loaded at 73EE0000h - 73EE4000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 7E41928Bh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "PeekMessageW" (+00000000h)
Address: 025C8028h, location: "foo_vis_shpeck", loaded at 025B0000h - 025D9000h
Address: 025C58A8h, location: "foo_vis_shpeck", loaded at 025B0000h - 025D9000h
Address: 025B4033h, location: "foo_vis_shpeck", loaded at 025B0000h - 025D9000h
Address: 025C5FC4h, location: "foo_vis_shpeck", loaded at 025B0000h - 025D9000h
Address: 7C80B6A3h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C839A30h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C80B6B0h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Address: 025B3ED0h, location: "foo_vis_shpeck", loaded at 025B0000h - 025D9000h
Address: 01000100h, location: "foo_discogs", loaded at 00FA0000h - 01041000h
Version info:
foobar2000 v0.9.5.1 beta 2
UNICODE
Windows 5.1
Additional info:
Album Art Browser 0.0.5 [Jul 23 2007 - 08:27:55]  (foo_cwbowron)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
Matroska input 0.1  (foo_input_mkx)
DirectShow input 0.1  (foo_input_ds)
Standard DSP Array 1.0  (foo_dsp_std)
Kernel Streaming Output 1.2.2  (foo_out_ks)
Lyric Show Panels 0.3.1.1  (foo_uie_lyrics)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
CD Audio Decoder 2.1.2  (foo_cdda)
ABX Comparator 1.3.1  (foo_abx)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Startup Actions 0.0.2 [Jul 23 2007 - 08:27:55]  (foo_cwbowron)
Converter 1.1  (foo_converter)
Columns UI 0.2.1 alpha 11 preview 2 v2  (foo_ui_columns)
Album List 4.2  (foo_albumlist)
Volume Panel 0.1  (foo_uie_powerpanels)
Discogs Tagger 1.12  (foo_discogs)
Menu Addons 0.4 (SSE)  (foo_menu_addons)
Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]  (foo_uie_trackinfo_mod)
Peakmeter Spectrum Visualisation 0.1.0.2 beta  (foo_uie_vis_peakmeter_spectrum)
Seek Panel 0.1  (foo_uie_powerpanels)
foobar2000 core 0.9.5.1 beta 2  (Core)
PopUp Plus 20071228  (foo_popupplus)
freedb Tagger 0.5.2.1  (foo_freedb2)
Audio CD Writer 2.0.1  (foo_burninate)
ALAC Decoder 1.0  (foo_input_alac)
Run services 0.3.2  (foo_run)
Playlist Tools 0.6.2 beta 3  (foo_utils)
Gapless Crossfader 0.3.3.5 (SSE)  (foo_dsp_crossfader)
ZIP/GZIP reader 1.0  (foo_unpack)
Facets 2008-02-25  (foo_facets)
DTS decoder 0.1.1 (SSE)  (foo_dts)
Convolver 0.3  (foo_convolve)
File Operations 2.1  (foo_fileops)
Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48]  (foo_dockable_panels)
Playlists Dropdown 0.6 alpha 4  (foo_uie_playlists_dropdown)
Shpeck - Winamp vis plugins wrapper 0.2.1  (foo_vis_shpeck)
ReplayGain Scanner 2.0.3  (foo_rgscan)
Cover Flow 0.15  (foo_bubble_coverflow)
Album Art Panel 0.2.7.1  (foo_uie_albumart)
Feature Watcher 1.0.4  (foo_whatsnew)
Playback Statistics 2.0  (foo_playcount)
Monkey's Audio decoder 2.1.2  (foo_input_monkey)
Acro WMA decoder 0.1.7.2 (SSE)  (foo_input_wma)
Panels UI 0.13.8 beta [Jun 12 2007 - 12:28:00]  (foo_ui_panels)
Explorer Tree 1.04.6a  (foo_uie_explorer)
Typefind 0.2 beta 2  (foo_uie_typefind)
Default User Interface 0.9.5  (foo_ui_std)
Misc. Addons 0.1.1 (SSE)  (foo_misc_addons)
WMP Visualizations 0.1.3 (SSE)  (foo_uie_wmpvis)
ASIO support 1.2.6  (foo_out_asio)
foo_lyricsdb 0.0.7 beta 5  (foo_lyricsdb)
RAR reader 1.1  (foo_unpack)
Tagger Panel Window 1.0.6 [Jan  2 2008 - 15:50:49]  (foo_cwb_hooks)
cwbowron's title format hooks 1.2.6 [Jan  2 2008 - 15:50:05]  (foo_cwb_hooks)
foo_vis_shpeck
Reply #147
RavenSoft, I'm not the shpeck dev, but have you tried updating to the gold version of 0.9.5.1?  You're still using a beta.  That might be causing the crash.
foo_vis_shpeck
Reply #148
Yirkha thanks! Works great!
