Topic: Discussion of "Default UI Gallery" (Read 388610 times) previous topic - next topic
Reply #300
What font are you using with DUI ? I am right now using Avantgrade LT Medium (7pts size) and I am getting bored to it. Corbel was the one I used before this but got bored to it.
Reply #301
Mostly using Segoe because it looks so clean, but using Sruti on my "Lists" so that it can display unicode characters.. also looks pretty cool
Reply #302
I am looking for a font which looks good, not sharp and yet easy to look. Something like Avantgarde LT Medium, but different looking  I have used Segoe also, but got bored with it :s
Reply #303
Is there a way to get the album art veiwer that comes with foobar2000 to display the album art of the track that is playing and not selected?
Reply #306
The lyrics are not a default UI element, it's some Columns UI panel running in foo_dockable_panels.
I don't know what specifically you like about the second image, again floating dockable lyrics on the left, the layout can be modified using Layout Editing Mode as always, other parts tuned in Preferences > Display > Default User Interface > Colors and Fonts, the overall look still depends on global Windows theme/style.
Reply #307
The lyrics thing looks like foo_uie_lyrics. To get it into DUI you need foo_dockable_panels, but it will be a floating window and not integrated into the layout.
If you don't need synced karaoke lyrics you can use foo_texttools instead to display the lyrics. This component is fully compatible with DUI and can be integrated in the layout.
edit: way too slow
Reply #310
Add a custom column with formatting like $repeat(★,%rating%).
Reply #311
Ok, thanks.  One more, is there any alternate spectrum-like visualization that show both speakers but not both speakers combined into one? I don't like the current spectrum.
Reply #313
Oh, thank you, I thought Shpeck need Winamp.
Reply #314
After screwing around a lot with CUI, I decided I liked the default UI better and facets is just too good and I like the information it provides a lot better than CUI filters.
Love it, can you share your config file?
Guinness for strength!
Reply #316
It is, and I wish you would have asked two weeks ago, I'm on 7 now and can't remember.
Edit: found it
elevatorladylevitateme
Reply #317
Cool thanks
Reply #318
Components Needed:
foo_facets.dll (2009-09-16 22:53:37)
    Facets 2008-02-25
foo_lyricsgrabber.dll (2008-12-11 12:27:07) - if you choose to want to display lyrics as I have, you'll need this component to grab the lyrics
    Lyrics Grabber 0.2.6.2 Beta
foo_playlist_manager.dll (2007-01-22 12:05:12)
    Playlist Manager 1.0.2
foo_run.dll (2009-06-07 14:15:18)
    Run services 0.3.7
foo_textdisplay.dll (2008-07-08 18:45:26)
    Text Display UI Element 1.0 RC 3
foo_upnp.dll (2009-10-05 12:49:17) - I have a UPnP controller, you can delete the UPnP panel in the config and you won't receive the error message if you use my config without this component.
    An UPnP/DLNA Media Renderer, Media Server and Control Point 0.99.14
Fonts Needed:
Corbel - I believe it's included with Vista and up and Office 2007, but if you don't have it, it can be downloaded free of charge from Microsoft as part of their Powerpoint 2007 Viewer and Office Compatibility Pack.  See wikipedia: http://en.wikipedia.org/wiki/Corbel_%28typeface%29
Icons Needed:
Download at http://public.me.com/papatel
Unzip into icons folder in foobar directory.  If there isn't one, create it.
Theme file:
Let me know if you encounter any problems or if you have suggestions.
Reply #319
How did you add colour to the ratings column? Can you share the code for that please?
~edit~
Never mind, I figured it out. Needed to grab the beta to get it working... Nice feature!
Reply #320
@garbanzo.bean : can you please share your config ?
thanks
Reply #321
thanks
i would like to, but i don't know how! it has so many elements to it, it would be difficult to share them all...
just try to reproduce it yourself. PM me if you need help
Reply #324
thanks..
