Topic: Default UI Gallery (Read 749817 times) previous topic - next topic
Default UI Gallery
This new beta is really quite nice. This is what I've got so far:
The image link is no longer valid
Default UI Gallery
Refined a bit after I decided that I didn't need the metadata and console tabs.
Default UI Gallery
Here's the 'shrinked' version of my two-window config posted above. I think Lyx asked for more compact configs, so here we go:
-edit-
and two more alternatives with only one window: 'bigOne' and 'compactOne' (animated GIFs)
they can still be quite comfortable depending on your listening behaviour (i.e. if you mainly listen to albums or longer playlists).
frncle
Default UI Gallery
This is mine, pretty much a ripoff from some ideas I got from here. Oh, and tweaked for my needs of coarse:
Default UI Gallery
Bare-bones, Low-on-Resources, Thin, Compact theme.
No AlbumArt or Lyrics.
Uses Facets.
Uses Font: "Photoshop Small" (Installed with Photoshop).
Dimensions: Width=369pixels Height=996pixels.
Visual Style: Windows Classic (with 'Jasmin 3D Colour Changer' mods).
Default UI Gallery
Reply #34
The image link is no longer valid The image link is no longer valid The image link is no longer valid
Uses Font: Frutiger Linotype.
Dimensions: Width=427pixels Height=1024pixels.
Thin, Compact theme. UPDATED!! with options for AlbumArt
and Other Tabs and optimized Space Utilisation.
I would have attached the theme file (if anyone wanted it!)
but Unfortunately am not allowed Attachments as yet by Admin
for being New to the forum!
Default UI Gallery
Reply #35
Here's Mine - With a few Dockable Panels on Display set to show/hide via function keys...
Default UI Gallery
Reply #37
The basic controls are on the keyboard.
Default UI Gallery
Reply #38
When I first stumbled upon foobar2000 a couple weeks ago, I nearly gave up on it after a few minutes of tinkering around.  It was version 9.4.5, and that night, the site that hosts the plug-ins was down.  Then I saw the new beta version and decided to give it a try.  Twenty minutes later, I had downloaded facets and had a pretty nice layout going on.  Haven't looked back to iTunes yet.
http://img99.imageshack.us/img99/6097/35150254nv2.jpg
Default UI Gallery
Reply #39
Moderation: Your image (850 KB) was ten times larger than the maximum size. Replaced by a thumbnail.
Default UI Gallery
Reply #40
Made some small changes on my foobar 0.9.5 setup and cleaned up my custom status bar code and rearranging the replaygain info on the stat bar aswell.
"I never thought I'd see this much candy in one mission!"
Default UI Gallery
Reply #44
Moderation: Please do not inline images larger than roughly 800x600 and 80KB. Please use thumbnails and/or links for large pictures instead.
Default UI Gallery
Reply #49
Finally started using facets and a fullscreen DUI.
