Topic: What AAC profile should I use? (Read 13220 times) previous topic - next topic
I'm going to use Nero AAC to encode audio from several films. So I have a question, what AAC profile should I use to achieve the best quality in different cases?
1) 5.1 sound, 256kbits/sec;
2) 5.1 sound, 192kbits/sec;
3) stereo sound, 128kbits/sec;
4) stereo sound, 96kbits/sec;
My own opinion, based on the information that I have read on forums, is that the answers are:
1) LC-AAC;
2) HE-AAC;
3) LC-AAC;
4) LC-AAC;
Am I right?
P.S. Time of coding does not matter, the quality is at the first place.
I guess you're gonna go for average bitrates instead of constant ones, since this is very recommendable in a movie soundtrack's case. For this kind of use even the ~192 kbit/s should be sufficient for being encoded to LC-AAC. Lots of opportunities for the codec to drastically vary its bitrates are offered here, while the specified average can still be maintained. Large parts of movies consist just of someone talking, a little noise or even complete silence, being very simple to encode. This allows the codec to encode actual music playback at bitrates far above the 192 kbit/s average one, resulting in high quality. Of course, you should stick to 2-pass encoding in order for AAC to be able to make the best possible use of its bitrate allocation.
I'd probably use LC on all of those.
Thanks for replies, I'll follow yours advices.
My advise to movies with NeroDigital+ Audio encoder:
STEREO: 80kbps HE-AAC
5.1: 192kbps HE-AAC
Below this the quality is very annoying.
5.1: 192kbps HE-AAC
Again: HE is not HiFi.
Use LC for movies - unless you are planning to watch them on your mobile!!!
Please elaborate...
In my opinion the choice totally depends on the bitrate. In my tests, 256kbits has mostly been enough for LC-AAC 5.1. If you want to go lower, then HE-AAC is probably better. The best thing to do would be to test and see how they sound. For some people SBR is annoying.
Those of you who are saying "LC for all", at what bitrate would you transition over to HE (especially on 5.1 encodes)?
Everything below an average of around 192 kbit/s would mean using HE-AAC in my case. This bitrate is my personal threshold for the switch between the AAC profiles.
Edit:
Stereo: I view HE-AAC as being useful below 80 kbit/s, though I still abstain from encoding to this format. That's due to low bitrates only being of interest for portable devices in my case, but these suffer from HE-AAC heavily eating batteries. In addition to this SBR isn't supported by aacgain, which is a very handy application to process content that's gonna be played back by portables. This leaves streaming as the only reasonable domain for HE-AAC to show its full potential.
I'm using what the Nero Digtal CLI defaults to. I think this is the best choice regarding quality. However, I'd like to know what is chosen at what bitrate. Is there any info about that (v.1.1.34.2)?
