Topic: Chronflow (Read 478794 times) previous topic - next topic
Chronflow
Reply #150
Here: "Realease of DC and RC failed" then "release device context failed" then "could not release hWnd" and nothing appears.
But I'm keeping on testing
It was bubblegum plugin interfering, sorry.
Edit Is it designed to show the red X and couldn't load image if the directory has no image?
That's correct both plugin are interferring but there's a simple solution:
Chronial, could you prefix your OpenGl code with wglMakeCurrent(hdc, hglrc), so you're sure you're in the good OpenGL context ? My code do it alerady so several panel instances can be running without messing each other.
Either that easy solution, or each plugin should restore the previous GL context if any, after GL commands.
Where do I configure your panel, I want to try it  ?
You're correct I'm doing my own panel mostly for learning, because it's fun, a bit challenging to get it right, and it's been some 3 years I've not done some OpenGL so it's the occasion . Otherwise my foobar config is anti eye-candy and looks more like a database than anthing . I can give you a skeleton code for the preference dialog if you wish, adapted from foo_uie_album_art. It can save you some time, because doing those nasty config dialog win32 style is no fun...
Chronflow
Reply #151
The configuration is in the main preferences->Display->Chronflow.
Fixing the rendering context bug.
Chronflow
Reply #152
So, here we go - fixed version:
http://chron.visiondesigns.de/foobar2000/f...flow_v0.1.1.zip
Should now peacefully coexists with bubbleguuum's component (I would nevertheless strongly recommend not to use them at the same time for various reasons).
I also fixed the error messages that appear when shutting down. (They where caused by that fact that nasty panels_ui destroys my windows before closing my panel. It shouldn't do that)
Chronflow
Reply #153
I can't get anything to show up in the panel still :/
Chronflow
Reply #154
Do you have your database set up?
Could you post a screenshot of you Chronflow config?
Chronflow
Reply #155
How so? I have never used "Autoplaylist", so I have no clue as to what to enter in the "Database Filter".
Thank you for creating the plugin.
Surf's Up!
"Columnated Ruins Domino"
Chronflow
Reply #156
Thanx Chronial, work fine now
but, is it making some more than just a display of cover for now ? Maybe i have miss something .. shortcuts ?
thanx
Chronflow
Reply #157
No, it doesn't do anything else - but the code is ready for the implementation. I just wanted you to test the plugin on other systems, before I continue implementation.
The next steps are:
- doubleclick / [enter] user-defined actions.
- Playlist mode (generate album list from playlist, not db)
- "Album follows playback" - mode (this will especially look cool in DB-Mode)
- Title display
- Display Settings:
  - costumise cover flow type (this will be hot)
  - bg-color settings etc.
Chronflow
Reply #158
what about a spectrum running in the background of the covers.. now that would be freaking cool
Chronflow
Reply #159
Hehe, you'r right - but that would increase CPU usage a lot. I don't render the panel while it is not moving.
So no can do.
Chronflow
Reply #160
So no can do.
Conceivably, couldn't you make the coverflow slightly transparent, and position it directly over a spectrum?
    - M.
Chronflow
Reply #161
Finally i could play with it, and it's very nice. I'm glad to see both plugin won't be exactly similar or function the same. The threading for loading images works great, I'll have to work on it for animation
Good work!
Chronflow
Reply #163
Good work!
Chronial Coverflow is most a vertical panel and Bubbleguuum Coverflow is for horizontal use  ... what else
Chronflow
Reply #164
Can some nice soul please post what is supposed to go in the Database Filter? I can't get the actual coverart to show up. I just see the spiral squares. I'm assuming this issue has to do with the Database Filter? Thanks!
Surf's Up!
Chronflow
Reply #165
just put 1
Chronflow
Reply #166
Make sure your cover art path is correct. I have the following settings and it works for me:
Chronflow
Reply #167
My set up is just like yours, but my "Sources" is: $replace(%path%,%filename_ext%,)Front.jpg
This works with bubbleguuum's coverflow, so I know it is correct.
So, now I get the spiral with white and gray squares, but no coverart.
Surf's Up!
Chronflow
Reply #168
Thanks for this component.
I get the following error when trying to open a Chronflow panel:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00000000h
Access violation, operation: read, address: 00000000h
Call path:
entry=>app_mainloop
Stack (0012C3C8h):
0012C3A8h:  0012C780 0012C758 00000000 B1DE6898
0012C3B8h:  B1DE656C B1DE6898 B1DE662C 804E2490
0012C3C8h:  00B89DD7 3F800000 00BA1678 0AD43FD8
0012C3D8h:  0012C518 000506B0 00000001 BF800000
0012C3E8h:  40000000 40000000 FFFFFFF6 00000000
0012C3F8h:  FFFFFFF6 00000000 00000000 04C857D8
0012C408h:  00B8A092 0AD31510 00B71B9F 0AD31510
0012C418h:  0012C58C 00B71EF0 00000000 00000000
0012C428h:  00000000 08686D80 0012C4FC 082E7608
0012C438h:  0012C468 7C917D47 00000003 7C917DA3
0012C448h:  082E75F8 00000002 003C0000 00000028
0012C458h:  00000008 003C0190 00000000 0112C644
0012C468h:  0012C654 7C917C0C 003C0000 00000001
0012C478h:  7C917BF5 003C0608 7C917BB0 00000008
0012C488h:  00000020 082E7600 00000020 082E7328
0012C498h:  7C9105C8 086882F8 0012C56C 7C910551
0012C4A8h:  003C0718 7C91056D 086BCEA0 00000000
0012C4B8h:  086BCEA8 086882D8 0012C58C 00000008
0012C4C8h:  003C0748 7C91056D 00000000 086882E0
0012C4D8h:  086882E0 00000008 00000000 082E7608
Registers:
EAX: 0B02FE01, EBX: 04C857D8, ECX: 0B02FE69, EDX: 00B94C00
ESI: 0AD60870, EDI: 5ED02D70, EBP: 7FFFFFF5, ESP: 0012C3C8
Crash location: "foobar2000", loaded at 00400000h - 0051E000h
Loaded modules:
foobar2000                      loaded at 00400000h - 0051E000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F5000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F02000h
Secur32                          loaded at 77FE0000h - 77FF1000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 7E410000h - 7E4A0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D7000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 1002A000h
COMDLG32                        loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
LPK                              loaded at 629C0000h - 629C9000h
USP10                            loaded at 74D90000h - 74DFB000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
MSCTF                            loaded at 74720000h - 7476B000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_albumlist                    loaded at 00A90000h - 00AF5000h
foo_cdda                        loaded at 00B10000h - 00B45000h
foo_chronflow                    loaded at 00B70000h - 00BAB000h
WINMM                            loaded at 76B40000h - 76B6D000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
OPENGL32                        loaded at 5ED00000h - 5EDCC000h
GLU32                            loaded at 68B20000h - 68B40000h
DDRAW                            loaded at 73760000h - 737A9000h
DCIMAN32                        loaded at 73BC0000h - 73BC6000h
SSMSFltr                        loaded at 00C40000h - 00C58000h
foo_comserver2                  loaded at 04C90000h - 04CE6000h
OLEAUT32                        loaded at 77120000h - 771AB000h
foo_converter                    loaded at 04D10000h - 04D75000h
foo_cwbowron                    loaded at 04DA0000h - 04DCA000h
foo_cwb_hooks                    loaded at 04DF0000h - 04E3A000h
foo_dsp_std                      loaded at 04E60000h - 04EA7000h
foo_fileops                      loaded at 04ED0000h - 04F17000h
foo_freedb2                      loaded at 04F40000h - 04F81000h
foo_highlightplaying            loaded at 04FB0000h - 04FD1000h
foo_infobox                      loaded at 05000000h - 05040000h
foo_input_alac                  loaded at 05060000h - 0507D000h
foo_input_monkey                loaded at 050A0000h - 050EA000h
foo_input_shorten                loaded at 05110000h - 0513E000h
foo_input_std                    loaded at 05160000h - 05282000h
foo_navigator                    loaded at 052B0000h - 052E4000h
foo_playlistclear                loaded at 05310000h - 05332000h
foo_playlist_manager            loaded at 05350000h - 05396000h
foo_playlist_tree                loaded at 053C0000h - 05435000h
libmzsch360_000                  loaded at 10400000h - 105D0000h
WSOCK32                          loaded at 71AD0000h - 71AD9000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
libmzgc360_000                  loaded at 05460000h - 05504000h
foo_rgscan                      loaded at 05550000h - 055A0000h
foo_uie_albumart                loaded at 055C0000h - 055FD000h
foo_uie_albumlist                loaded at 05620000h - 05663000h
foo_uie_explorer                loaded at 05690000h - 056CC000h
foo_uie_powerpanels              loaded at 056F0000h - 05713000h
foo_uie_queuemanager            loaded at 05740000h - 05779000h
mscoree                          loaded at 79000000h - 79045000h
MSVCR80                          loaded at 78130000h - 781CB000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3D1000h
mscorlib.ni                      loaded at 790C0000h - 79BA6000h
mscorjit                        loaded at 79060000h - 790B3000h
rsaenh                          loaded at 0FFD0000h - 0FFF8000h
System.ni                        loaded at 7A440000h - 7ABFE000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF74000h
foo_uie_quicksearch              loaded at 07DD0000h - 07E16000h
foo_uie_wmpvis                  loaded at 07F50000h - 07F8B000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
foo_ui_columns                  loaded at 07F90000h - 08027000h
foo_ui_panels                    loaded at 08050000h - 08117000h
foo_ui_std                      loaded at 08140000h - 081F3000h
MSIMG32                          loaded at 76380000h - 76385000h
foo_utils                        loaded at 08220000h - 08299000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
VERSION                          loaded at 77C00000h - 77C08000h
xpsp2res                        loaded at 20000000h - 202C5000h
SXS                              loaded at 75E90000h - 75F40000h
vlmshlp                          loaded at 094B0000h - 094B7000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC56000h
appHelp                          loaded at 77B40000h - 77B62000h
cscui                            loaded at 77A20000h - 77A74000h
CSCDLL                          loaded at 76600000h - 7661D000h
DSOUND                          loaded at 73F10000h - 73F6C000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
wdmaud                          loaded at 72D20000h - 72D29000h
msacm32                          loaded at 72D10000h - 72D18000h
MSACM32                          loaded at 77BE0000h - 77BF5000h
midimap                          loaded at 77BD0000h - 77BD7000h
KsUser                          loaded at 73EE0000h - 73EE4000h
atioglxx                        loaded at 69000000h - 69651000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 00B89DD7h, location: "foo_chronflow", loaded at 00B70000h - 00BAB000h
Address: 00BA1678h, location: "foo_chronflow", loaded at 00B70000h - 00BAB000h
Address: 00B8A092h, location: "foo_chronflow", loaded at 00B70000h - 00BAB000h
Address: 00B71B9Fh, location: "foo_chronflow", loaded at 00B70000h - 00BAB000h
Address: 00B71EF0h, location: "foo_chronflow", loaded at 00B70000h - 00BAB000h
Address: 7C917D47h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+0000034Ah)
Address: 7C917DA3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000003A6h)
Address: 7C917C0Ch, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+0000020Fh)
Address: 7C917BF5h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001F8h)
Address: 7C917BB0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C910551h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 00B71F16h, location: "foo_chronflow", loaded at 00B70000h - 00BAB000h
Address: 7E418734h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E418816h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+0000014Fh)
Address: 7E440457h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E418830h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+00000169h)
Address: 7E41C63Fh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "IsWindowUnicode" (+000000A1h)
Address: 7E41C665h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "CallWindowProcW" (+0000001Bh)
Address: 5ED2699Bh, location: "OPENGL32", loaded at 5ED00000h - 5EDCC000h
Symbol: "wglSwapBuffers" (+000002F7h)
Address: 5ED26780h, location: "OPENGL32", loaded at 5ED00000h - 5EDCC000h
Symbol: "wglSwapBuffers" (+000000DCh)
Address: 6940E21Ah, location: "atioglxx", loaded at 69000000h - 69651000h
Symbol: "DrvSetContext" (+00012E0Ah)
Address: 7E41B4C0h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 7E41B4D0h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 7E41B50Ch, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 7E41B473h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 7E41D83Fh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "UpdateWindow" (+00000046h)
Address: 7E41D82Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "UpdateWindow" (+00000031h)
Address: 08060DFBh, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Address: 004EAF18h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 080E8058h, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Address: 080DE0F3h, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Address: 0808D9C5h, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Address: 0808CB03h, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 00498C51h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0045D8D6h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042E7B3h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 080C273Fh, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Address: 080C275Eh, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Address: 080CB0A0h, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Address: 080A033Fh, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Symbol: "foobar2000_get_interface" (+0000D86Fh)
Address: 0808A1ABh, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Address: 0808A1EDh, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C9106ABh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C9105D4h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 080C277Ch, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Address: 763A3C2Ch, location: "IMM32", loaded at 76390000h - 763AD000h
Symbol: "CtfImmIsTextFrameServiceDisabled" (+0000036Bh)
Address: 7C80261Ah, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "WaitForSingleObjectEx" (+000000DAh)
Address: 7C8025F0h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "WaitForSingleObjectEx" (+000000B0h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C8025F8h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "WaitForSingleObjectEx" (+000000B8h)
Address: 7C802532h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "WaitForSingleObject" (+00000012h)
Address: 7C90E2F1h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "NtReleaseMutant" (+0000000Ch)
Address: 7C8024B7h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "ReleaseMutex" (+00000010h)
Address: 74754C96h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_RunInputCPL" (+000045E7h)
Address: 747553E3h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_GetThreadFlags" (+000003F2h)
Address: 7475E548h, location: "MSCTF", loaded at 74720000h - 7476B000h
Address: 747553E8h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_GetThreadFlags" (+000003F7h)
Address: 7473EF6Fh, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_CreateCicLoadMutex" (+0000850Ch)
Address: 7473EFFFh, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_CreateCicLoadMutex" (+0000859Ch)
Address: 77F198EBh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectExW" (+00000084h)
Address: 77F198C6h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectExW" (+0000005Fh)
Address: 77F188B4h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "SetBrushOrgEx" (+000001D0h)
Address: 77F189DBh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "SetBrushOrgEx" (+000002F7h)
Address: 7C9137ABh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlUnlockHeap" (+00000020h)
Address: 7C9137C7h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlUnlockHeap" (+0000003Ch)
Address: 74DE0524h, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 74DE05B4h, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 74DE0470h, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 7472FCD5h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_DllDetachInOther" (+00000EA5h)
Address: 74DC4700h, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 74DA31BDh, location: "USP10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptTextOut" (+00000178h)
Address: 74DE0384h, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 74DE0260h, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 74DAE11Dh, location: "USP10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptApplyDigitSubstitution" (+0000949Bh)
Address: 74DE049Ch, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 77F16A48h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GdiGetCodePage" (+00000068h)
Address: 77F16A53h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GdiGetCodePage" (+00000073h)
Address: 74755F57h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_IsInMarshaling" (+00000A36h)
Address: 7472E6D0h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_CreateCategoryMgr" (+00005DB2h)
Address: 77F53020h, location: "GDI32", loaded at 77F10000h - 77F57000h
Address: 74DAB762h, location: "USP10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptApplyDigitSubstitution" (+00006AE0h)
Address: 74DAB91Eh, location: "USP10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptApplyDigitSubstitution" (+00006C9Ch)
Address: 74DE037Ch, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 74DA3E48h, location: "USP10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptCacheGetHeight" (+00000023h)
Address: 74DAC7A4h, location: "USP10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptApplyDigitSubstitution" (+00007B22h)
Address: 74DA428Ah, location: "USP10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptStringAnalyse" (+00000237h)
Address: 629C48F2h, location: "LPK", loaded at 629C0000h - 629C9000h
Symbol: "LpkTabbedTextOut" (+00000A9Fh)
Address: 629C464Bh, location: "LPK", loaded at 629C0000h - 629C9000h
Symbol: "LpkTabbedTextOut" (+000007F8h)
Address: 74DAE501h, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 74DD5030h, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 74DA42F8h, location: "USP10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptStringFree" (+00000035h)
Address: 629C4680h, location: "LPK", loaded at 629C0000h - 629C9000h
Symbol: "LpkTabbedTextOut" (+0000082Dh)
Address: 629C4741h, location: "LPK", loaded at 629C0000h - 629C9000h
Symbol: "LpkTabbedTextOut" (+000008EEh)
Address: 5AD72BFBh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "GetThemeAppProperties" (+000009E0h)
Address: 5AD72BACh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "GetThemeAppProperties" (+00000991h)
Address: 5AD72B54h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "GetThemeAppProperties" (+00000939h)
Address: 5AD72B92h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "GetThemeAppProperties" (+00000977h)
Address: 629C1269h, location: "LPK", loaded at 629C0000h - 629C9000h
Symbol: "LpkDrawTextEx" (+00000034h)
Address: 7E44E404h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DeregisterShellHookWindow" (+0000E17Ch)
Address: 7E418B26h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 0809AC10h, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Symbol: "foobar2000_get_interface" (+00008140h)
Address: 7E4188D1h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 7E4188DAh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 080E1300h, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Address: 0809AC57h, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Symbol: "foobar2000_get_interface" (+00008187h)
Address: 7E418BD9h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 7E423794h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+00000301h)
Address: 7E423761h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+000002CEh)
Address: 7E423768h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 7E423591h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 7E4235A2h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+0000010Fh)
Address: 7E42379Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 7E4184FCh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E4185A4h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E4237BCh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 7E41885Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+00000193h)
Address: 7E41882Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+00000163h)
Address: 080ABA30h, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Address: 7E41B89Bh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetParent" (+0000016Ch)
Address: 7E42F3CCh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "SendMessageA" (+00000049h)
Address: 080A4500h, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Symbol: "foobar2000_get_interface" (+00011A30h)
Address: 080AA3C0h, location: "foo_ui_panels", loaded at 08050000h - 08117000h
Address: 7E423745h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Version info:
foobar2000 v0.9.5 beta 8
UNICODE
Windows 5.1
Additional info:
Playlist clear 0.08  (foo_playlistclear)
Navigator 0.63  (foo_navigator)
freedb Tagger 0.5.2.1  (foo_freedb2)
Highlight playing 0.1.0  (foo_highlightplaying)
Startup Actions 0.0.2 [Jul 23 2007 - 08:27:55]  (foo_cwbowron)
Explorer Tree 1.04.6b  (foo_uie_explorer)
File Operations 2.0  (foo_fileops)
Playlist Tree Panel 3.0.BETA_3 [Apr  3 2007 - 11:39:32]  (foo_playlist_tree)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Converter 1.0.2  (foo_converter)
COM Automation server 0.7 alpha 6  (foo_comserver2)
Quick Search Toolbar 2.8k  (foo_uie_quicksearch)
WMP Visualizations 0.1.3 (Intel SSE)  (foo_uie_wmpvis)
cwbowron's title format hooks 1.2.5 [Jun  7 2007 - 10:34:42]  (foo_cwb_hooks)
foobar2000 core 0.9.5 beta 8  (Core)
Coverflow pannel 0.1.0  (foo_chronflow)
Special file info box 2.0.4  (foo_infobox)
Tagger Panel Window 1.0.beta4 [Jun  7 2007 - 10:34:42]  (foo_cwb_hooks)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
Panels UI 0.14.12 beta [Jul 18 2007 - 13:39:30]  (foo_ui_panels)
Seek Panel 0.1  (foo_uie_powerpanels)
ALAC Decoder 1.0  (foo_input_alac)
Album Art Browser 0.0.5 [Jul 23 2007 - 08:27:55]  (foo_cwbowron)
Monkey's Audio decoder 2.1.2  (foo_input_monkey)
Shorten decoder 0.4.2a  (foo_input_shorten)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
Volume Panel 0.1  (foo_uie_powerpanels)
CD Audio Decoder 2.1.2  (foo_cdda)
Album Art Panel 0.2.7  (foo_uie_albumart)
Album List 4.1  (foo_albumlist)
Standard DSP Array 1.0  (foo_dsp_std)
Playlist Tools 0.6.2 beta 3  (foo_utils)
Default User Interface 0.9.5  (foo_ui_std)
Playlist Manager 1.0  (foo_playlist_manager)
Queue manager panel 0.2.3  (foo_uie_queuemanager)
Chronflow
Reply #169
Awesome Chronial. That's amazing! I didn't even think about to test that other component. From the look of it I can tell that it's not of the quality of your work. Take your time, I think most of us here really appreciate the amount of time you put into that thing. Great progress!
Oh. When I close foobar I get that Release of RC and DC message...
Chronflow
Reply #170
I am glad that is working for you, as I can't seem to get the coverart to actually show up in the spiral boxes. As for the quality of work issue, don't judge! For me, that "other component" does as advertises on my machine, where this one does not, at this early stage. Both of these components are in their infancy, and I am sure both will be fine plug-ins as they progress to maturity.
Surf's Up!
Chronflow
Reply #171
@saberrider
Are you running version 0.1.1? - there shouldn't be any error in these.
@Kiteroa
Could you try entering a DB filter that for sure returns nothing (e.g. 1 IS 2)?
@drbeachboy
Do you see the squares with the question mark or with the hourglass?
If it's the question mark there's something wrong with your source filter. Trailing spaces can be a problem.
Chronflow
Reply #172
Yes I've got version 1.1. I use foobar 9.4 and panels_ui 0.13.5...
maybe I should update
edit: ok I updated panels_ui but still the same message when I quit foobar. Actually I don't care about that because I never close my foobar anyway
Chronflow
Reply #173
@Kiteroa
I've done as you suggest: component does not crash - (maybe problem was that there was nothing at all in the query field?).
But, nothing is drawn when 1 IS 2 and even with 1 IS 1 as query!
Chronflow
Reply #174
@drbeachboy
I get neither, just a white square on the center 3 squares, then shades of gray squares throughout the rest of the spiral.
Surf's Up!
