Topic: Running Foobar in Linux (Read 658688 times) previous topic - next topic
Re: Running Foobar in Linux
Reply #500
Thanks for trying to help out! I didn't have time to search for this myself, but maybe you could direct me closer to a solution with the following details you asked:
The sound card is an onboard card (I guess) on the motherboard of a Sony Vaio laptop.
The Wine cfg shows winealsa.drv as the selected driver.
KDE indeed shows Phonon VLC as the backend.
VLC, in turn, has chosen PulseAudio sound server as the output device (I attach screenshots of VLC, so that I won't confuse you):
Any help/brainstorming would be welcome, though you have already helped quite a lot.:)
Reply #501
I think that means WINE should be choosing a PulseAudio driver, not the ALSA one.  Not sure why it chose the wrong driver, or how to force it to use another.   It used to be a selection in winecfg, but no longer, unless you have a really old version of WINE.  Afraid I can't help much with that problem.
Reply #502
No, no, you really helped me a lot to narrow it down, thank you for giving me some of your time.
I will post again here when I find a proper solution about the PulseAudio in Wine problem. For now, I tried different versions of Wine (1.62 (from the Neon repositories), 2.05 and 3.0) and none let me choose the "Selected driver". I read in a few places that Wine has (/had?) a notoriously bad relationship with Pulseaudio. That's all I got so far.
This problem needs some real digging and I hardly have any time left for this these days.
Reply #503
You can use winetrick to chance from alsa to pulseaudio.
Just run the following:
sudo apt-get install cabextract
wget https://raw.githubusercontent.com/Winetricks/winetricks/master/src/winetricks
chmod +x winetricks
sh winetricks sound=pulse
Reply #504
Thank you for this suggestion! I had a long session yesterday, finally, and I concluded that I am probably blocking myself on this, but I don't know how.
So, first I tried winetricks, and it didn't allow me to switch to pulse. Then I realized that even if it did, it would have switched it in only the default Wine configuration, while I needed to do this to the configuration ("prefix"?) made by Playonlinux for Foobar (note: I opted for Playonlinux on top of Wine to avoid having to configure Wine myself everytime something changes with compatibility and whatnot for Foobar in the future). I tried changing the driver manually with regedit, in both configurations, but no luck. The default one seemed to change, but the audio behavior remained the same: only one audio stream at a time.
Then I deleted everything and started over, only with Wine, no Playonlinux. Again it defaulted to the Alsa driver. (at that point I didn't try adding Winetricks; I should have tried that then). Removed everything again, started with Playonlinux this time, same thing: alsa.
I did a circle that took me like 3-4 hours, and I got frustrated. This problem will just have to wait for someone who has dealt with exactly this problem, and either posts here, or I find it somewhere on the internet...
Reply #505
That is very strange.
In a new profile with any new version of wine the default driver is always pulse.
Even forcing alsa in wine the pulseaudio daemon takes control of the stream and system pulseaudio see it like "ALSA plugin [wine-preloader]" and of course can be mixed with any other stream.
You can try to start over.
Uninstall all wine software with synaptic (playonlinux too), add the wine-hq repo
sudo dpkg --add-architecture i386
wget -nc https://dl.winehq.org/wine-builds/Release.key
sudo apt-key add Release.key
sudo apt-add-repository https://dl.winehq.org/wine-builds/ubuntu/
sudo apt-get update
sudo apt-get install --install-recommends winehq-devel
Now delete the wine profiles of your home and edit .bashrc with the following as the last line of code:
export WINEARCH=win32
Open a new terminal and run:
winecfg
to create a fresh .wine profile in your home.
If you want to create multiples profiles you can use
WINEPREFIX=~/.mywineprofile winecfg
to make new profiles and:
WINEPREFIX=~/.mywineprofile winetricks
to launch winetricks in any profile.
I personally run away from playonlinux as far as I can  ;)
If doesn't work maybe the problem is in the system audio configuration and not in wine.
Reply #506
Thank you! I'll try this when I find some time to deal with this again carefully and focused. Last night's session left me disheartened. I will get back with the results when I do.
Reply #507
Clear the mind is always a good idea when we find a problem.
Good luck.
Reply #508
This time it was successful, big heartfelt thanks paregistrase!
Can I ask what the line export WINEARCH=win32 in .bashrc is for? Also, now that I found you :), would you also know what to do about the stuttering when a new file starts playing (this forum has outdated info on this)?
Conclusions: it does seem to make sense to get Wine from their own repositories. KDE Neon (Ubuntu-based) are still using 1.62, which, as I read somewhere, is before the Wine people changed something to make the audio driver default to pulse.
Having also used new versions of Wine, but installed through Playonlinux on top of v1.62 [edit: woopsy, I may have been ignorant enough not to switch versions from the default one,  :-[ ], I too would recommend getting just Wine without Playonlinux, if you can't really navigate yourself in what each one does to which configuration. For some reason, alsa was stuck as the driver even for the new Wine versions.
Reply #509
You're welcome.
the line in .bashrc is for ensure that when you launch wine or winetrick from command line always get this variable without having to type it every time. If you remenber to type it every time that want to launch a wine32 application and make sure that your .desktop files have it too you can get rid of it without major problem.
About stuttering I don't know what to say you, I don't have this issue. Maybe any plugin automatic action when the song start to play?  I have seen small interruption in playing if I write tags in large files or perform intensive actions like calculate replaygain while playing. I try to avoid any automatic writing like write the stadistic or the lyrics in the file while playing and the "little pauses" never happen again.
About the version is always good idea to take the newest version and even better if it is from the original source
Reply #510
Thank you for explaining this too and for the tips!
btw, I realized I must have changed wine versions through Playonlinux for Foobar, so my quasi-theory above could be kind of true. Anyway, it doesn't matter.
Reply #511
Yes, playonlinux let you change the wine version of any profile that create but the playonlinux version not always performs the same that the build from wine-hq and his winetricks version is a little "special" too.
But you don't need playonlinux to have diferent version of wine in your system.
There is a package that create links in the path for the wine version, it's called winehq-(stable, devel or staging). If you don't install it you can have the 3 version instaled. The only downside is that you need to type every time the complete path to the wine executable that you want to run.
The diferent versions installs in /opt/wine-(stable, devel or staging)
so you can install all and call it with the complete path /opt/wine-staging/bin/wine yourprogram.exe.
Or install only one of the winehq-(stable, devel or staging) to create simlink in the path to call it just typing wine and call the rest for the complete path.
Or make yourself links to the diferent executables and put them in any path (/usr/bin,~/.local/bin/,etc) folder...
And combine it with diferent profiles and wine32 or 64 as you want
Wine is very versatile
Reply #512
fb and wine usually work quite well together, but looking at the new mac port of foobar2000 makes me feel confident that a native linux version is not utopic anymore ;)
Reply #513
hopefully.
Reply #514
If you install wine staging (I use Lutris) and enable gtk3 integration it looks so much better (columns ui).:
Reply #515
Doing ReplayGain scans, updating tags and performing other disk-intensive operations has caused choppy/skipping/stuttering audio here since Wine version 1.0 came out.  It looks like Wine 5.0 finally fixes this issue.
I also found a fairly simple way to output each track at its native sample rate under ALSA by skipping dmix:
I put the following commands in a script file (I called it foobar.sh):
mv ~/.bsoundrc ~/.asoundrc
wine "c:\Program Files\foobar2000\foobar2000.exe"
mv ~/.asoundrc ~/.bsoundrc
and this is what goes in a file initially named .bsoundrc, which gets moved back and forth by the script between .bsoundrc and .asoundrc in the home directory
pcm.!default{
type hw
card 1
device 0
(your card and device numbers may be different, and can be determined by the output of the command "aplay -l", without quotes)
When running this script, no sound will come from other apps. It is sometimes necessary to close the other apps and re-open them either before or after running the script.  foobar2000 can be run normally (sharing ALSA with other apps) by not starting foobar2000 with the script, i.e. starting it the way you always have in the past.
If this doesn't work, pulse or jack may be getting in the way.  I'm not running either one, so I don't know what happens if they're running.
Reply #516
I believe I asked this already at the wrong place but now that I found the Linux thread...
Anyone knows how to Drag & Drop files from foobar2k to the desktop or file manager on Ubuntu 18.04? Is it even possible with wine apps? I'm using this version btw:
https://snapcraft.io/foobar2000
I know that the creator of foobar2000 is busy enough with other ports. But I wish there would be a wine package by peter himself rather than strangers.
Reply #517
hi,
I hope you can help me. This is the only post that I have come across
that even mentions wine config! All others talk about linux terminal
commands. So kudos to you.
Oh a lot of the linux forums seem to be under maintenance at the moment.
very strange.
I have Wine installed on BionicPup64. 8.0
Wine seem to be working as I can run all listed menu items with a wine prefixed.
ie, Eg. there is an entry "Wine File" under Filesystem. This program works. So I am assuming
from this that wine is working as it is meant to.
Now I set the wine config as Xp. (did not even know I could do this until your post)
I download foobar200_v1.5.5.exe and it downloads to the download directory.
then I go to my BionicPup64 6.0 menu and run "Wine Remove Programs" as this
says add/remove programs in the window title and has an install button on it.
I press install which takes me to a file select dialog box. I can see my foobar2000 that I
downloaded earlier. I select it. and press open. Then Nothing. I wait and still nothing.
No errors just nothing.
I also tried setting wine to win7 and win10 thinking that BionicPup being 64bit might be the problem
but this too gave me nothing.
I then ran Wine File under Filesystem and thought I do this in windows so may be it is meant to be run in the wine file manager. this also gave me nothing but curiously something flashed on screen but lasted only a fraction of a sec.
So you see I have tried my best to install it myself but at this point I need some professional help.
Any help would be welcomed.
Be safe
pzaw
Reply #518
I see Puppy has wine 3.15 in its Bionic packages tree. I *think* you'll need at least wine 4.0 to run foobar2000, but I can't be sure.
Reply #519
It makes no sense to run windows software in linux.
Cats dont' bark...
Make a dual boot system and use your win software in windows and your linux sofwtare in linux.
Wine is updated all the time, foobar too so you will have INFINITE problems trying to do this.
Unlesz you want that, go ahead and rape the penguin...Those guys are raped anyway those days...
Foobar2000 - It Really Whips ALL Llamas' Ass!
Reply #520
If source codes will be opened maybe somebody ported foobar2000 to linux/macOS)
Reply #521
Does Boom run under Wine? Perhaps Boom can be ported, there's no issues with dependencies and extensibility.
Yes, evidently Boom does run within Wine just fine according to https://ubuntuforums.org/showthread.php?t=2346487
Reply #522
Try PlayOnLinux (sort of GUI for Wine) or snap https://snapcraft.io/foobar2000 if it's available for your distribution and you're not a dogmtic purist.
That's not true in my experience. I updated Wine from 5.0 to 5.14 and foobar works pretty much the same way.
That's not going to happen so perhaps more realistic course of action would be to politely ask for semi-official support of foobar under wine. Meaning helping with bug reporting and fixing, starting with volume not working when system is set to anything above Win XP.
Reply #523
I have my Wine set to Windows 7, and the volume bar is working since switching Wine to the PulseAudio driver using winetricks script 'sound=pulse'.
Reply #524
I'm pretty sure no output config changes helped but it works now:
- firstly through foo_out_pulse
- and then after upgrade to 1.6.
Overall it's getting better, no sound glitches under load with or without  foo_out_pulse. The biggest problem for me is foo_quicksearch crashing when typing anything in a search toolbar.
