Topic: Editing M3U files? (Read 11807 times) previous topic - next topic
Editing M3U files?
Is there a way to edit a M3U playlist file manually? If not, any suggestions on how to edit/change it?
Editing M3U files?
Yeah, open it in Notepad.
Editing M3U files?
Okay I opened up a M3U playlist in notepad and got the layout order. I'm not sure though what to put for the #EXTINF if I add another track manually. If the song used to be part of the original track, would I just create a new line and then use the same #EXTINF or what?
Editing M3U files?
You don't even need those #EXTINF.
Simply pointing to the location such as this will work wonderfully:
MP3s\Some Artist\2007 - Some Album\01-Some_Artist-Some_Track.mp3
MP3s\Some Artist\2007 - Some Album\02-Some_Artist-Some_Track.mp3
Editing M3U files?
But I need #EXTINF because I am using a NAS on my apple TV
Is there any way to get foobar saving an m3u playlist with this extra info?
Currently I save my playlists with foobar, open them in WinAmp and save them again. I would like ti get rid of WinAmp
Re: Editing M3U files?
Hi
Topic is quite old, but I hope in help.
Is there automatic way to remove path from m3u playlist and keep filename only?
C:\music\artist12\albumname-abc\song1.mp3
C:\music\artist98\albumname-xyz\song2.mp3
Delete red and keep green.
I tried notepad++ however I did not find function like this.
Manually editing holds for long time, automatic process would be welcomed.
Thanks in advance
szabi
notepad++ would work. Open the replace dialog, enable regular expressions (under 'search mode', bottom left) and replace this:
with nothing.
You helped me a lot.
Many thanks for this.
szabi
