Topic: foo_scheduler (Read 453478 times) previous topic - next topic
foo_scheduler
Reply #300
Thank you!
foo_scheduler
Reply #301
Hello Andrew,
and thank you for the new version.  I have one comment on it:  The old version used to have a "Playback end" event, while the new version has a "Playback stop" event.  The difference is that the old version didn't react to stopping the player manually.  The event was only triggered when playback has ended.
I find the old behaviour much more useful.  I often set foobar2000 to hibernate the computer when playback ends.  Occasionally I stop the playback manually (to change the music, or for some other reason).  In the new version manually stopping the music triggers hibernation too, which is not desirable.
Would it be possible to add an old-style "Playback end" event in addition to the "Playback stop" event?
foo_scheduler
Reply #302
Hello Andrew,
Yep, my mistake. Wait a few minutes, will upload an updated build (version won't be changed)!
* Build updated, playback stop works now like in previous version *
foo_scheduler
Reply #304
Remember position in (each) playlist, which was stopped/paused last time. Track number... or even track time.
foo_playlist_attributes can do that. Ofcourse it does not handle stopping but it has bookmarks per playlist. That's soo nice.
foo_scheduler
Reply #305
Hello,
This is great component. I have discovered some small accessibility issues:
1) It is not possible to open the context menu for the list view and treeview in the preferences page using keyboard only. Applications key should popup that menu by default. I think you need to implement wm_context message rather than reacting to right click specifically.
2) Could you please improve resource definition so all the static text are placed in the correct azorder? Generally a static text labelling an interactive control should be placed before that control. For people relying on assistive technologies it is not enough just to arrange it visually.
#1 is higher priority of course.
foo_scheduler
Reply #306
As for hibernate, it's possible to wake up computer from this mode. The only thing you need is a motherboard that supports this feature. It seems that yours doesn't.
Hmm, probably... I'll take a look at the BIOS and manual of my notebook.
Vittorio, notebooks will usually not wake up when running from battery (imagine if it just turned on in your backpack!).  Is it possible that yours was running from battery power when you tried this?
foo_scheduler
Reply #307
Great job.  I really like the new version: Everything the last one had plus more
foo_scheduler
Reply #308
andrew_smolko, thank you for the scheduler update, I appreciate the new pause/unpause function and the status window very much. Two annotations:
1)
The current version 4.0 deletes date/time events (Event list) after their carrying out. So to perform an existing action again, this steps are neccessary now:
  • Adding/creating a new date/time event,
  • giving it a title,
  • reassigning it to an action list event.
In former scheduler versions however it was possible to keep such date/time events ("disable after done") and an editing of the date/time was enough to perform an action again. Could this behaviour come back, please?
2)
Could foobar's function [Playback / Volume] mute/unmute be added to the available action events? Would be superb.
Scheduler 4.0, f2k 1.0.1
foo_scheduler
Reply #309
Version 4 doesn’t seem to be able to fadeout, I have set up a 10 seconds fadeout, but playback stops quite abrupt.
(foobar2000 1.0.1, Scheduler 4.0, DirectSound, X-Fi Titanium, XP)
Also, I’d like to have a "pause" action so I can continue playback at the last position without the risk that foobar2000 unpauses a paused session at high volume late at night or when I’m not at my computer :-)
FLAC.
foo_scheduler
Reply #310
Thanks for report, the bugfix will be in the next release.
There is "Pause/unpause playback" action.
foo_scheduler
Reply #311
New version 4.01 has been released!
foo_scheduler
Reply #313
Changelog 4.01:
  • Final action combo-box has been returned in date/time event.
  • New "Mute/unmute" action.
[/li][/list]
Brilliant, thank you very much, Andrew!
Robertina.
foo_scheduler
Reply #314
I added a Player event ("On playback stop", Final action: "Disable event") and assigned it to an action which I named "f2k exit" (action: Exit foobar2000).
In this environment foobar closes only, if [menu: Playback ->] 'Stop after Current' is ticked, otherwise it stays open. Scheduler's status window remains empty.
Has this something to do with what has been discussed here [a href="index.php?act=findpost&pid=693193"][{POST_SNAPBACK}][/a]? That way/at the moment I can play back only one single track if I want to close f2k automatically afterwards and I am using the newest scheduler version. Or is something wrong with my settings?
foo_scheduler
Reply #315
I would like to add that there are two situations in which my playback stops (and scheduler fails to close foobar), although 'Stop after current' is unticked:
  • The last track in a playlist has been played, playback order = default
  • The last track from foobar's playback queue has been played, with Stop after Queue activated.
Sorry for my English.
foo_scheduler
Reply #316
Hi there, I'm getting a foobar crash every time I have an alarm go off (oddly enough, the entire song still plays through, but the error message shows up right away, every morning):
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="foobar2000.exe" FILTER="GRABMI_FILTER_PRIVACY">
<MATCHING_FILE NAME="7z.dll" SIZE="726016" CHECKSUM="0x5F6491DE" BIN_FILE_VERSION="4.65.0.0" BIN_PRODUCT_VERSION="4.65.0.0" PRODUCT_VERSION="4.65" FILE_DESCRIPTION="7z Standalone Plugin" COMPANY_NAME="Igor Pavlov" PRODUCT_NAME="7-Zip" FILE_VERSION="4.65" ORIGINAL_FILENAME="7za.dll" INTERNAL_NAME="7za" LEGAL_COPYRIGHT="Copyright © 1999-2009 Igor Pavlov" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.65.0.0" UPTO_BIN_PRODUCT_VERSION="4.65.0.0" LINK_DATE="02/03/2009 07:21:03" UPTO_LINK_DATE="02/03/2009 07:21:03" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="7z.exe" SIZE="150016" CHECKSUM="0xF435BEAE" BIN_FILE_VERSION="4.65.0.0" BIN_PRODUCT_VERSION="4.65.0.0" PRODUCT_VERSION="4.65" FILE_DESCRIPTION="7-Zip Console" COMPANY_NAME="Igor Pavlov" PRODUCT_NAME="7-Zip" FILE_VERSION="4.65" ORIGINAL_FILENAME="7z.exe" INTERNAL_NAME="7z" LEGAL_COPYRIGHT="Copyright © 1999-2009 Igor Pavlov" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.65.0.0" UPTO_BIN_PRODUCT_VERSION="4.65.0.0" LINK_DATE="02/03/2009 07:09:39" UPTO_LINK_DATE="02/03/2009 07:09:39" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="foobar2000 Shell Associations Updater.exe" SIZE="82944" CHECKSUM="0x83E77B18" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="0.9.6.0" PRODUCT_VERSION="0, 9, 6, 0" FILE_DESCRIPTION="foobar2000 Shell Associations Updater" PRODUCT_NAME="foobar2000" FILE_VERSION="1, 0, 0, 0" ORIGINAL_FILENAME="foobar2000 Shell Associations Updater.exe" INTERNAL_NAME="FileType" LEGAL_COPYRIGHT="Copyright © 2008 Peter Pawlowski" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1B63B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="0.9.6.0" LINK_DATE="01/09/2010 11:43:00" UPTO_LINK_DATE="01/09/2010 11:43:00" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="foobar2000.exe" SIZE="1777664" CHECKSUM="0x52778675" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1, 0, 0, 0" FILE_DESCRIPTION="foobar2000" PRODUCT_NAME="foobar2000 Application" FILE_VERSION="1, 0, 0, 0" ORIGINAL_FILENAME="foobar2000.exe" INTERNAL_NAME="foobar2000" LEGAL_COPYRIGHT="Copyright © 2001-2009 Peter Pawlowski" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1B30D6" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="01/09/2010 11:46:59" UPTO_LINK_DATE="01/09/2010 11:46:59" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="lame.exe" SIZE="187392" CHECKSUM="0xAC5D41FE" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="12/22/2005 10:29:33" UPTO_LINK_DATE="12/22/2005 10:29:33" />
<MATCHING_FILE NAME="libcurl.dll" SIZE="319488" CHECKSUM="0x3F48D406" MODULE_TYPE="WIN32" PE_CHECKSUM="0x4F319" LINKER_VERSION="0x0" LINK_DATE="03/19/2006 21:05:12" UPTO_LINK_DATE="03/19/2006 21:05:12" />
<MATCHING_FILE NAME="libexpatw.dll" SIZE="151552" CHECKSUM="0x6AD92D54" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2C083" LINKER_VERSION="0x0" LINK_DATE="06/05/2007 19:23:40" UPTO_LINK_DATE="06/05/2007 19:23:40" />
<MATCHING_FILE NAME="libmmd.dll" SIZE="2814044" CHECKSUM="0x38345C3E" BIN_FILE_VERSION="9.1.9.2" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="9.1" FILE_DESCRIPTION="Math Library for Intel® Compilers (thread-safe)" COMPANY_NAME="Intel Corporation" PRODUCT_NAME="Intel® C Compiler, Intel® C++ Compiler, Intel® Fortran Compiler" FILE_VERSION="9.1.9.2" ORIGINAL_FILENAME="libmmd.dll" INTERNAL_NAME="libmmd.dll" LEGAL_COPYRIGHT="Copyright © 1985-2005 Intel Corporation" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x0" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="9.1.9.2" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="02/16/2007 14:29:27" UPTO_LINK_DATE="02/16/2007 14:29:27" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="libmzgc360_000.dll" SIZE="237568" CHECKSUM="0x22EC6684" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3F515" LINKER_VERSION="0x0" LINK_DATE="11/20/2006 10:53:50" UPTO_LINK_DATE="11/20/2006 10:53:50" />
<MATCHING_FILE NAME="libmzsch360_000.dll" SIZE="1757184" CHECKSUM="0xFB9B4D23" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1AD82B" LINKER_VERSION="0x0" LINK_DATE="11/20/2006 10:54:53" UPTO_LINK_DATE="11/20/2006 10:54:53" />
<MATCHING_FILE NAME="libpng13.dll" SIZE="114688" CHECKSUM="0x82473E79" BIN_FILE_VERSION="1.2.8.0" BIN_PRODUCT_VERSION="1.2.8.0" PRODUCT_VERSION="1" FILE_DESCRIPTION="PNG image compression library" PRODUCT_NAME="LibPNG" FILE_VERSION="1.2.8" ORIGINAL_FILENAME="LIBPNG13.DLL" INTERNAL_NAME="LIBPNG13 (Windows 32 bit)" LEGAL_COPYRIGHT="© 1998-2004 Glenn Randers-Pehrson et al." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.2.8.0" UPTO_BIN_PRODUCT_VERSION="1.2.8.0" LINK_DATE="12/23/2004 15:37:07" UPTO_LINK_DATE="12/23/2004 15:37:07" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="NeroAACWrapper.exe" SIZE="106496" CHECKSUM="0x54456F6E" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1E36C" LINKER_VERSION="0x0" LINK_DATE="04/22/2006 21:55:28" UPTO_LINK_DATE="04/22/2006 21:55:28" />
<MATCHING_FILE NAME="shared.dll" SIZE="148480" CHECKSUM="0x304F3BA9" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2DBEB" LINKER_VERSION="0x0" LINK_DATE="01/09/2010 11:42:56" UPTO_LINK_DATE="01/09/2010 11:42:56" />
<MATCHING_FILE NAME="ShellExt32.dll" SIZE="108544" CHECKSUM="0x51195F19" BIN_FILE_VERSION="1.0.0.7" BIN_PRODUCT_VERSION="0.9.7.0" PRODUCT_VERSION="0.9.7" FILE_DESCRIPTION="foobar2000 shell extension" COMPANY_NAME="Peter Pawlowski" PRODUCT_NAME="foobar2000" FILE_VERSION="1.0.0.7" ORIGINAL_FILENAME="Fb2kShellExt.dll" INTERNAL_NAME="Fb2kShellExt.dll" LEGAL_COPYRIGHT="© Peter Pawlowski.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x24139" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.7" UPTO_BIN_PRODUCT_VERSION="0.9.7.0" LINK_DATE="05/27/2009 16:24:16" UPTO_LINK_DATE="05/27/2009 16:24:16" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uninst-audioscrobbler.exe" SIZE="47163" CHECKSUM="0x4BB19EFE" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="11/17/2007 14:35:28" UPTO_LINK_DATE="11/17/2007 14:35:28" />
<MATCHING_FILE NAME="uninstall.exe" SIZE="147371" CHECKSUM="0x2A89D326" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0" FILE_DESCRIPTION="foobar2000 Installer" COMPANY_NAME="foobar2000.org" PRODUCT_NAME="foobar2000" FILE_VERSION="1.0" ORIGINAL_FILENAME="foobar2000_v1.0.exe" LEGAL_COPYRIGHT="� Peter Pawlowski. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x60001" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="09/09/2009 13:23:23" UPTO_LINK_DATE="09/09/2009 13:23:23" VER_LANGUAGE="Language Neutral [0x0]" />
<MATCHING_FILE NAME="zlib1.dll" SIZE="73728" CHECKSUM="0x244B6C4A" BIN_FILE_VERSION="1.2.2.0" BIN_PRODUCT_VERSION="1.2.2.0" PRODUCT_VERSION="1.2.2" FILE_DESCRIPTION="zlib data compression library" PRODUCT_NAME="zlib" FILE_VERSION="1.2.2" ORIGINAL_FILENAME="zlib1.dll" INTERNAL_NAME="zlib1.dll" LEGAL_COPYRIGHT="© 1995-2004 Jean-loup Gailly &amp; Mark Adler" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x10004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.2.2.0" UPTO_BIN_PRODUCT_VERSION="1.2.2.0" LINK_DATE="12/23/2004 15:36:24" UPTO_LINK_DATE="12/23/2004 15:36:24" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="components\albumart.exe" SIZE="225280" CHECKSUM="0x4A23993F" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION="Cover Art Downloader" COMPANY_NAME="Damage, Inc." PRODUCT_NAME="Cover Art Downloader" FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="albumart.exe" INTERNAL_NAME="albumart.exe" LEGAL_COPYRIGHT="Copyright © Damage, Inc. 2005" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="09/22/2006 23:58:53" UPTO_LINK_DATE="09/22/2006 23:58:53" VER_LANGUAGE="Language Neutral [0x0]" />
<MATCHING_FILE NAME="components\Boo.Lang.Compiler.dll" SIZE="552960" CHECKSUM="0x22FF572F" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION="boo - an extensible programming language for the CLI" PRODUCT_NAME="boo - an extensible programming language for the CLI" FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="Boo.Lang.Compiler.dll" INTERNAL_NAME="Boo.Lang.Compiler.dll" LEGAL_COPYRIGHT="© 2003-2005 Rodrigo Barreto de Oliveira" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x95D58" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="04/24/2006 16:08:52" UPTO_LINK_DATE="04/24/2006 16:08:52" VER_LANGUAGE="Language Neutral [0x0]" />
<MATCHING_FILE NAME="components\Boo.Lang.dll" SIZE="69632" CHECKSUM="0xE9C8F42C" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION="boo - an extensible programming language for the CLI" PRODUCT_NAME="boo - an extensible programming language for the CLI" FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="Boo.Lang.dll" INTERNAL_NAME="Boo.Lang.dll" LEGAL_COPYRIGHT="© 2003-2005 Rodrigo Barreto de Oliveira" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1B48F" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="04/24/2006 16:08:46" UPTO_LINK_DATE="04/24/2006 16:08:46" VER_LANGUAGE="Language Neutral [0x0]" />
<MATCHING_FILE NAME="components\Boo.Lang.Parser.dll" SIZE="405504" CHECKSUM="0x2D6F1A82" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION="boo antlr based parser" PRODUCT_NAME="boo - an extensible programming language for the CLI" FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="Boo.Lang.Parser.dll" INTERNAL_NAME="Boo.Lang.Parser.dll" LEGAL_COPYRIGHT="© 2003-2005 Rodrigo Barreto de Oliveira" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x6D415" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="04/24/2006 16:09:01" UPTO_LINK_DATE="04/24/2006 16:09:01" VER_LANGUAGE="Language Neutral [0x0]" />
<MATCHING_FILE NAME="components\Foobar2000DeskbandControls.dll" SIZE="32256" CHECKSUM="0x976DD48" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA1AE" LINKER_VERSION="0x0" LINK_DATE="02/10/2010 20:54:10" UPTO_LINK_DATE="02/10/2010 20:54:10" />
<MATCHING_FILE NAME="components\foo_abx.dll" SIZE="181760" CHECKSUM="0x97BCDB7E" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3A147" LINKER_VERSION="0x0" LINK_DATE="06/07/2009 12:25:26" UPTO_LINK_DATE="06/07/2009 12:25:26" />
<MATCHING_FILE NAME="components\foo_ac3.dll" SIZE="169472" CHECKSUM="0x2BA1DD62" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2DD9C" LINKER_VERSION="0x0" LINK_DATE="01/11/2010 19:18:38" UPTO_LINK_DATE="01/11/2010 19:18:38" />
<MATCHING_FILE NAME="components\foo_audioscrobbler.dll" SIZE="187904" CHECKSUM="0x8D9F1EC" BIN_FILE_VERSION="1.4.6.0" BIN_PRODUCT_VERSION="1.4.6.0" PRODUCT_VERSION="1, 4, 6, 0" FILE_DESCRIPTION="foo_audioscrobbler" PRODUCT_NAME=" foo_audioscrobbler" FILE_VERSION="1, 4, 6, 0" ORIGINAL_FILENAME="foo_audioscrobbler.dll" INTERNAL_NAME="foo_audioscrobbler" LEGAL_COPYRIGHT="© 2006-2010 Florian Heidenreich" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3914B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.4.6.0" UPTO_BIN_PRODUCT_VERSION="1.4.6.0" LINK_DATE="02/07/2010 14:16:46" UPTO_LINK_DATE="02/07/2010 14:16:46" VER_LANGUAGE="English (United Kingdom) [0x809]" />
<MATCHING_FILE NAME="components\foo_cdda.dll" SIZE="294400" CHECKSUM="0x755E6D6E" MODULE_TYPE="WIN32" PE_CHECKSUM="0x535E4" LINKER_VERSION="0x0" LINK_DATE="01/09/2010 11:44:41" UPTO_LINK_DATE="01/09/2010 11:44:41" />
<MATCHING_FILE NAME="components\foo_component_manager.dll" SIZE="356352" CHECKSUM="0xA2CEBA27" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5E299" LINKER_VERSION="0x0" LINK_DATE="03/02/2010 14:17:37" UPTO_LINK_DATE="03/02/2010 14:17:37" />
<MATCHING_FILE NAME="components\foo_converter.dll" SIZE="438784" CHECKSUM="0xDAD673EE" MODULE_TYPE="WIN32" PE_CHECKSUM="0x713AE" LINKER_VERSION="0x0" LINK_DATE="01/09/2010 11:44:32" UPTO_LINK_DATE="01/09/2010 11:44:32" />
<MATCHING_FILE NAME="components\foo_deskband_controls.dll" SIZE="26624" CHECKSUM="0xCF835478" MODULE_TYPE="WIN32" PE_CHECKSUM="0x8167" LINKER_VERSION="0x0" LINK_DATE="02/08/2010 19:20:30" UPTO_LINK_DATE="02/08/2010 19:20:30" />
<MATCHING_FILE NAME="components\foo_dockable_panels.dll" SIZE="200704" CHECKSUM="0x4B0AE564" MODULE_TYPE="WIN32" PE_CHECKSUM="0x403E4" LINKER_VERSION="0x0" LINK_DATE="03/28/2007 13:19:00" UPTO_LINK_DATE="03/28/2007 13:19:00" />
<MATCHING_FILE NAME="components\foo_dop.dll" SIZE="1691648" CHECKSUM="0x48DA7DF2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1A91F7" LINKER_VERSION="0x0" LINK_DATE="02/20/2010 19:51:11" UPTO_LINK_DATE="02/20/2010 19:51:11" />
<MATCHING_FILE NAME="components\foo_dsp_continuator.dll" SIZE="94208" CHECKSUM="0xE58C57A9" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1CA53" LINKER_VERSION="0x0" LINK_DATE="01/04/2008 19:13:13" UPTO_LINK_DATE="01/04/2008 19:13:13" />
<MATCHING_FILE NAME="components\foo_dsp_crossfader.dll" SIZE="190464" CHECKSUM="0xAF9AB932" MODULE_TYPE="WIN32" PE_CHECKSUM="0x39F07" LINKER_VERSION="0x0" LINK_DATE="01/13/2010 13:46:08" UPTO_LINK_DATE="01/13/2010 13:46:08" />
<MATCHING_FILE NAME="components\foo_dsp_silence.dll" SIZE="164352" CHECKSUM="0x3C8546CC" MODULE_TYPE="WIN32" PE_CHECKSUM="0x321B6" LINKER_VERSION="0x0" LINK_DATE="08/09/2009 23:32:53" UPTO_LINK_DATE="08/09/2009 23:32:53" />
<MATCHING_FILE NAME="components\foo_dsp_std.dll" SIZE="280576" CHECKSUM="0x5B70DB19" MODULE_TYPE="WIN32" PE_CHECKSUM="0x49AAA" LINKER_VERSION="0x0" LINK_DATE="01/09/2010 11:44:47" UPTO_LINK_DATE="01/09/2010 11:44:47" />
<MATCHING_FILE NAME="components\foo_facets.dll" SIZE="520192" CHECKSUM="0xB853ED4B" MODULE_TYPE="WIN32" PE_CHECKSUM="0x834A9" LINKER_VERSION="0x0" LINK_DATE="02/26/2008 00:56:40" UPTO_LINK_DATE="02/26/2008 00:56:40" />
<MATCHING_FILE NAME="components\foo_filedate.dll" SIZE="131072" CHECKSUM="0xF8198C64" MODULE_TYPE="WIN32" PE_CHECKSUM="0x217AC" LINKER_VERSION="0x0" LINK_DATE="09/19/2007 11:07:14" UPTO_LINK_DATE="09/19/2007 11:07:14" />
<MATCHING_FILE NAME="components\foo_fileops.dll" SIZE="276992" CHECKSUM="0xE44563EF" MODULE_TYPE="WIN32" PE_CHECKSUM="0x456E0" LINKER_VERSION="0x0" LINK_DATE="01/09/2010 11:43:30" UPTO_LINK_DATE="01/09/2010 11:43:30" />
<MATCHING_FILE NAME="components\foo_freedb2.dll" SIZE="246272" CHECKSUM="0xB9476654" MODULE_TYPE="WIN32" PE_CHECKSUM="0x469E0" LINKER_VERSION="0x0" LINK_DATE="01/09/2010 11:43:34" UPTO_LINK_DATE="01/09/2010 11:43:34" />
<MATCHING_FILE NAME="components\foo_input_monkey.dll" SIZE="272896" CHECKSUM="0xD461678B" MODULE_TYPE="WIN32" PE_CHECKSUM="0x4C9D6" LINKER_VERSION="0x0" LINK_DATE="05/01/2009 12:40:53" UPTO_LINK_DATE="05/01/2009 12:40:53" />
<MATCHING_FILE NAME="components\foo_input_std.dll" SIZE="1337344" CHECKSUM="0x2336FBB0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x152DEB" LINKER_VERSION="0x0" LINK_DATE="01/09/2010 11:44:22" UPTO_LINK_DATE="01/09/2010 11:44:22" />
<MATCHING_FILE NAME="components\foo_jesus.dll" SIZE="138752" CHECKSUM="0x658DE157" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2A467" LINKER_VERSION="0x0" LINK_DATE="01/03/2010 12:41:16" UPTO_LINK_DATE="01/03/2010 12:41:16" />
<MATCHING_FILE NAME="components\foo_masstag.dll" SIZE="327680" CHECKSUM="0x9DEFC9F9" MODULE_TYPE="WIN32" PE_CHECKSUM="0x55187" LINKER_VERSION="0x0" LINK_DATE="09/18/2009 08:01:36" UPTO_LINK_DATE="09/18/2009 08:01:36" />
<MATCHING_FILE NAME="components\foo_mouse_gesture.dll" SIZE="166912" CHECKSUM="0x46DF2FA8" BIN_FILE_VERSION="0.1.0.0" BIN_PRODUCT_VERSION="0.1.0.0" PRODUCT_VERSION="0, 1, 0, 0" FILE_VERSION="0, 1, 0, 0" ORIGINAL_FILENAME="foo_uie_panel_splitter.dll" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2C4AA" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.1.0.0" UPTO_BIN_PRODUCT_VERSION="0.1.0.0" LINK_DATE="01/18/2010 12:20:00" UPTO_LINK_DATE="01/18/2010 12:20:00" VER_LANGUAGE="Japanese [0x411]" />
<MATCHING_FILE NAME="components\foo_musicbrainz.dll" SIZE="360448" CHECKSUM="0x81116E97" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5CC00" LINKER_VERSION="0x0" LINK_DATE="04/10/2009 20:27:27" UPTO_LINK_DATE="04/10/2009 20:27:27" />
<MATCHING_FILE NAME="components\foo_navigator.dll" SIZE="195584" CHECKSUM="0xC6B29036" MODULE_TYPE="WIN32" PE_CHECKSUM="0x39165" LINKER_VERSION="0x0" LINK_DATE="02/20/2010 01:13:12" UPTO_LINK_DATE="02/20/2010 01:13:12" />
<MATCHING_FILE NAME="components\foo_new_file_stamper_mod (2).dll" SIZE="145920" CHECKSUM="0x6F79E111" MODULE_TYPE="WIN32" PE_CHECKSUM="0x29563" LINKER_VERSION="0x0" LINK_DATE="12/21/2008 00:05:19" UPTO_LINK_DATE="12/21/2008 00:05:19" />
<MATCHING_FILE NAME="components\foo_playlist_attributes.dll" SIZE="256000" CHECKSUM="0x9E462237" MODULE_TYPE="WIN32" PE_CHECKSUM="0x468F6" LINKER_VERSION="0x0" LINK_DATE="11/16/2009 19:33:44" UPTO_LINK_DATE="11/16/2009 19:33:44" />
<MATCHING_FILE NAME="components\foo_prettypop.dll" SIZE="286208" CHECKSUM="0x4ED2D498" BIN_FILE_VERSION="1.2.5.0" BIN_PRODUCT_VERSION="1.2.5.0" PRODUCT_VERSION="1, 2, 5, 0" FILE_DESCRIPTION="Pretty Popup Plugin" PRODUCT_NAME="Pretty Popup" FILE_VERSION="1, 2, 5, 0" ORIGINAL_FILENAME="foo_prettypop.dll" INTERNAL_NAME="foo_prettypop.dll" LEGAL_COPYRIGHT="© 2005-9 Matt Witherspoon" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x49F3F" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.2.5.0" UPTO_BIN_PRODUCT_VERSION="1.2.5.0" LINK_DATE="12/06/2009 03:31:07" UPTO_LINK_DATE="12/06/2009 03:31:07" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="components\foo_preview.dll" SIZE="118784" CHECKSUM="0x9FFCD1AB" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="12/22/2008 20:41:11" UPTO_LINK_DATE="12/22/2008 20:41:11" />
<MATCHING_FILE NAME="components\foo_random_pools.dll" SIZE="207360" CHECKSUM="0x7DE55311" MODULE_TYPE="WIN32" PE_CHECKSUM="0x40D74" LINKER_VERSION="0x0" LINK_DATE="12/27/2009 17:22:55" UPTO_LINK_DATE="12/27/2009 17:22:55" />
<MATCHING_FILE NAME="components\foo_rgscan.dll" SIZE="298496" CHECKSUM="0x93DCD198" MODULE_TYPE="WIN32" PE_CHECKSUM="0x56CAC" LINKER_VERSION="0x0" LINK_DATE="01/09/2010 11:44:24" UPTO_LINK_DATE="01/09/2010 11:44:24" />
<MATCHING_FILE NAME="components\foo_run.dll" SIZE="369152" CHECKSUM="0x1F65BA37" BIN_FILE_VERSION="0.3.7.0" BIN_PRODUCT_VERSION="0.3.7.0" PRODUCT_VERSION="0, 3, 7, 0" FILE_DESCRIPTION="foo_run foobar2000 component" PRODUCT_NAME="foo_run foobar2000 component" FILE_VERSION="0, 3, 7, 0" ORIGINAL_FILENAME="foo_run.dll" INTERNAL_NAME="foo_run" LEGAL_COPYRIGHT="Copyright © 2006-2009 Florian Heidenreich" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x6199A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.3.7.0" UPTO_BIN_PRODUCT_VERSION="0.3.7.0" LINK_DATE="06/07/2009 13:15:14" UPTO_LINK_DATE="06/07/2009 13:15:14" VER_LANGUAGE="German (Germany) [0x407]" />
<MATCHING_FILE NAME="components\foo_scheduler.dll" SIZE="258560" CHECKSUM="0x2803A33E" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="03/18/2010 08:09:09" UPTO_LINK_DATE="03/18/2010 08:09:09" />
<MATCHING_FILE NAME="components\foo_softplaylists.dll" SIZE="315904" CHECKSUM="0x8B8415CC" MODULE_TYPE="WIN32" PE_CHECKSUM="0x4E225" LINKER_VERSION="0x0" LINK_DATE="12/30/2009 19:29:49" UPTO_LINK_DATE="12/30/2009 19:29:49" />
<MATCHING_FILE NAME="components\foo_stopaftercuralbum.dll" SIZE="122880" CHECKSUM="0xAA991A40" MODULE_TYPE="WIN32" PE_CHECKSUM="0x22AA6" LINKER_VERSION="0x0" LINK_DATE="06/01/2009 08:50:40" UPTO_LINK_DATE="06/01/2009 08:50:40" />
<MATCHING_FILE NAME="components\foo_textdisplay.dll" SIZE="240128" CHECKSUM="0x4DE184A1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x43811" LINKER_VERSION="0x0" LINK_DATE="07/08/2008 17:45:15" UPTO_LINK_DATE="07/08/2008 17:45:15" />
<MATCHING_FILE NAME="components\foo_texttools.dll" SIZE="197120" CHECKSUM="0xB16B12BF" MODULE_TYPE="WIN32" PE_CHECKSUM="0x37F02" LINKER_VERSION="0x0" LINK_DATE="12/23/2009 20:00:20" UPTO_LINK_DATE="12/23/2009 20:00:20" />
<MATCHING_FILE NAME="components\foo_uie_biography.dll" SIZE="315392" CHECKSUM="0x62338E9D" BIN_FILE_VERSION="0.1.0.0" BIN_PRODUCT_VERSION="0.1.0.0" PRODUCT_VERSION="0, 1, 0, 0" FILE_VERSION="0, 1, 0, 0" ORIGINAL_FILENAME="foo_uie_panel_splitter.dll" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x550CE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.1.0.0" UPTO_BIN_PRODUCT_VERSION="0.1.0.0" LINK_DATE="03/17/2010 12:17:57" UPTO_LINK_DATE="03/17/2010 12:17:57" VER_LANGUAGE="Japanese [0x411]" />
<MATCHING_FILE NAME="components\foo_uie_esplaylist.dll" SIZE="257024" CHECKSUM="0xB3C10205" BIN_FILE_VERSION="0.1.0.0" BIN_PRODUCT_VERSION="0.1.0.0" PRODUCT_VERSION="0, 1, 0, 0" FILE_VERSION="0, 1, 0, 0" ORIGINAL_FILENAME="foo_uie_panel_splitter.dll" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x445EB" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.1.0.0" UPTO_BIN_PRODUCT_VERSION="0.1.0.0" LINK_DATE="03/22/2010 06:38:01" UPTO_LINK_DATE="03/22/2010 06:38:01" VER_LANGUAGE="Japanese [0x411]" />
<MATCHING_FILE NAME="components\foo_uie_trackinfo_mod.dll" SIZE="352256" CHECKSUM="0x6B38CA90" MODULE_TYPE="WIN32" PE_CHECKSUM="0x595D9" LINKER_VERSION="0x0" LINK_DATE="01/05/2007 19:36:21" UPTO_LINK_DATE="01/05/2007 19:36:21" />
<MATCHING_FILE NAME="components\foo_uie_wsh_panel_mod.dll" SIZE="689664" CHECKSUM="0xC8DACB76" MODULE_TYPE="WIN32" PE_CHECKSUM="0xB7D12" LINKER_VERSION="0x0" LINK_DATE="02/28/2010 02:59:13" UPTO_LINK_DATE="02/28/2010 02:59:13" />
<MATCHING_FILE NAME="components\foo_ui_columns.dll" SIZE="1492992" CHECKSUM="0xE2103ABC" MODULE_TYPE="WIN32" PE_CHECKSUM="0x171A77" LINKER_VERSION="0x0" LINK_DATE="01/09/2010 14:40:24" UPTO_LINK_DATE="01/09/2010 14:40:24" />
<MATCHING_FILE NAME="components\foo_ui_std.dll" SIZE="1084416" CHECKSUM="0xFCEA4D38" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1188BA" LINKER_VERSION="0x0" LINK_DATE="01/09/2010 11:44:52" UPTO_LINK_DATE="01/09/2010 11:44:52" />
<MATCHING_FILE NAME="components\foo_unpack.dll" SIZE="171520" CHECKSUM="0x3E6A9DF" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2A031" LINKER_VERSION="0x0" LINK_DATE="01/09/2010 11:43:19" UPTO_LINK_DATE="01/09/2010 11:43:19" />
<MATCHING_FILE NAME="components\foo_vis_shpeck-beta.dll" SIZE="172032" CHECKSUM="0xAEB08753" MODULE_TYPE="WIN32" PE_CHECKSUM="0x30BA8" LINKER_VERSION="0x0" LINK_DATE="04/18/2008 22:41:49" UPTO_LINK_DATE="04/18/2008 22:41:49" />
<MATCHING_FILE NAME="components\foo_wlm.dll" SIZE="116224" CHECKSUM="0x3C718148" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2282B" LINKER_VERSION="0x0" LINK_DATE="02/09/2010 09:06:10" UPTO_LINK_DATE="02/09/2010 09:06:10" />
<MATCHING_FILE NAME="components\ICSharpCode.SharpZipLib.dll" SIZE="139264" CHECKSUM="0x5A4FE44F" BIN_FILE_VERSION="0.84.0.0" BIN_PRODUCT_VERSION="0.84.0.0" PRODUCT_VERSION="0.84.0.0" FILE_DESCRIPTION="ICSharpCode.SharpZipLibrary" PRODUCT_NAME="#ZipLibrary" FILE_VERSION="0.84.0.0" ORIGINAL_FILENAME="ICSharpCode.SharpZipLib.dll" INTERNAL_NAME="ICSharpCode.SharpZipLib.dll" LEGAL_COPYRIGHT="Copyright 2001-2005 Mike Krueger" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2A3B5" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.84.0.0" UPTO_BIN_PRODUCT_VERSION="0.84.0.0" LINK_DATE="09/22/2006 08:21:42" UPTO_LINK_DATE="09/22/2006 08:21:42" VER_LANGUAGE="Language Neutral [0x0]" />
<MATCHING_FILE NAME="components\Interop.Foobar2000.dll" SIZE="49152" CHECKSUM="0x968AC15B" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION=" " COMPANY_NAME=" " PRODUCT_NAME="Assembly imported from type library 'Foobar2000'." FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="Interop.Foobar2000.dll" INTERNAL_NAME="Interop.Foobar2000" LEGAL_COPYRIGHT=" " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="09/22/2006 23:58:45" UPTO_LINK_DATE="09/22/2006 23:58:45" VER_LANGUAGE="Invariant Language (Invariant Country) [0x7f]" />
<MATCHING_FILE NAME="components\Interop.Foobar2000Helper.dll" SIZE="7168" CHECKSUM="0xC82886BF" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION=" " COMPANY_NAME=" " PRODUCT_NAME="Assembly imported from type library 'Foobar2000Helper'." FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="Interop.Foobar2000Helper.dll" INTERNAL_NAME="Interop.Foobar2000Helper" LEGAL_COPYRIGHT=" " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="09/22/2006 23:58:45" UPTO_LINK_DATE="09/22/2006 23:58:45" VER_LANGUAGE="Invariant Language (Invariant Country) [0x7f]" />
<MATCHING_FILE NAME="components\scripts\scriptcache.dll" SIZE="9728" CHECKSUM="0xBE8E13A8" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="10/27/2006 05:14:53" UPTO_LINK_DATE="10/27/2006 05:14:53" />
<MATCHING_FILE NAME="scripts\marc2003\v2\art.exe" SIZE="7680" CHECKSUM="0xFBDF4C73" BIN_FILE_VERSION="0.0.1.6" BIN_PRODUCT_VERSION="0.0.1.6" PRODUCT_VERSION="0.0.1.6" FILE_DESCRIPTION="art" PRODUCT_NAME="art" FILE_VERSION="0.0.1.6" ORIGINAL_FILENAME="art.exe" INTERNAL_NAME="art.exe" LEGAL_COPYRIGHT="Copyright ©  2009" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.0.1.6" UPTO_BIN_PRODUCT_VERSION="0.0.1.6" LINK_DATE="01/09/2010 09:39:48" UPTO_LINK_DATE="01/09/2010 09:39:48" VER_LANGUAGE="Language Neutral [0x0]" />
<MATCHING_FILE NAME="tools\libeay32.dll" SIZE="1177600" CHECKSUM="0xADEFC887" BIN_FILE_VERSION="0.9.8.8" BIN_PRODUCT_VERSION="0.9.8.8" PRODUCT_VERSION="0.9.8h" FILE_DESCRIPTION="Libeay32: open Secure Socket Layer protocol" COMPANY_NAME="GnuWin32 &lt;http://gnuwin32.sourceforge.net&gt;" PRODUCT_NAME="OpenSSL" FILE_VERSION="0.9.8h" ORIGINAL_FILENAME="libeay32.dll" INTERNAL_NAME="libeay32" LEGAL_COPYRIGHT="© 2008 OpenSSL &lt;www.openssl.org&gt;" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12417E" LINKER_VERSION="0x10000" UPTO_BIN_FILE_VERSION="0.9.8.8" UPTO_BIN_PRODUCT_VERSION="0.9.8.8" LINK_DATE="09/03/2008 20:49:35" UPTO_LINK_DATE="09/03/2008 20:49:35" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="tools\libiconv2.dll" SIZE="1008128" CHECKSUM="0x63331ED0" BIN_FILE_VERSION="1.12.2872.39125" BIN_PRODUCT_VERSION="1.12.2872.39125" PRODUCT_VERSION="1.12.2872.39125" FILE_DESCRIPTION="Libiconv: convert between character encodings" COMPANY_NAME="GnuWin32 &lt;http://gnuwin32.sourceforge.net&gt;" PRODUCT_NAME="LibIconv" FILE_VERSION="1.12.2872.39125" ORIGINAL_FILENAME="iconv2.dll" INTERNAL_NAME="iconv2" LEGAL_COPYRIGHT="© 2007 Free Software Foundation &lt;www.fsf.org&gt;" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFC3CB" LINKER_VERSION="0x10000" UPTO_BIN_FILE_VERSION="1.12.2872.39125" UPTO_BIN_PRODUCT_VERSION="1.12.2872.39125" LINK_DATE="03/14/2008 22:21:30" UPTO_LINK_DATE="03/14/2008 22:21:30" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="tools\libintl3.dll" SIZE="103424" CHECKSUM="0x8506FBBB" BIN_FILE_VERSION="0.14.4.1952" BIN_PRODUCT_VERSION="0.14.4.1952" PRODUCT_VERSION="0.14.4.1952" FILE_DESCRIPTION="GetText: library and tools for native language support" COMPANY_NAME="GNU &lt;www.gnu.org&gt;" PRODUCT_NAME="GetText" FILE_VERSION="0.14.4.1952" ORIGINAL_FILENAME="libintl3.dll" INTERNAL_NAME="libintl3" LEGAL_COPYRIGHT="© 2005 Free Software Foundation &lt;www.fsf.org&gt;" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1BF7B" LINKER_VERSION="0xE" UPTO_BIN_FILE_VERSION="0.14.4.1952" UPTO_BIN_PRODUCT_VERSION="0.14.4.1952" LINK_DATE="05/06/2005 19:52:42" UPTO_LINK_DATE="05/06/2005 19:52:42" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="tools\libssl32.dll" SIZE="232960" CHECKSUM="0xAACC4C9C" BIN_FILE_VERSION="0.9.8.8" BIN_PRODUCT_VERSION="0.9.8.8" PRODUCT_VERSION="0.9.8h" FILE_DESCRIPTION="Libssl32: open Secure Socket Layer protocol" COMPANY_NAME="GnuWin32 &lt;http://gnuwin32.sourceforge.net&gt;" PRODUCT_NAME="OpenSSL" FILE_VERSION="0.9.8h" ORIGINAL_FILENAME="libssl32.dll" INTERNAL_NAME="libssl32" LEGAL_COPYRIGHT="© 2008 OpenSSL &lt;www.openssl.org&gt;" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3A269" LINKER_VERSION="0x10000" UPTO_BIN_FILE_VERSION="0.9.8.8" UPTO_BIN_PRODUCT_VERSION="0.9.8.8" LINK_DATE="09/03/2008 20:49:36" UPTO_LINK_DATE="09/03/2008 20:49:36" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="tools\wget.exe" SIZE="449024" CHECKSUM="0xE2D614EA" BIN_FILE_VERSION="1.11.4.3287" BIN_PRODUCT_VERSION="1.11.4.3287" PRODUCT_VERSION="1.11.4.3287" FILE_DESCRIPTION="Wget: retrieve files from the WWW" COMPANY_NAME="GnuWin32 &lt;http://gnuwin32.sourceforge.net&gt;" PRODUCT_NAME="Wget" FILE_VERSION="1.11.4.3287" ORIGINAL_FILENAME="wget.exe" INTERNAL_NAME="wget" LEGAL_COPYRIGHT="© 2008 Free Software Foundation &lt;www.fsf.org&gt;" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x729E4" LINKER_VERSION="0x10000" UPTO_BIN_FILE_VERSION="1.11.4.3287" UPTO_BIN_PRODUCT_VERSION="1.11.4.3287" LINK_DATE="12/31/2008 14:03:36" UPTO_LINK_DATE="12/31/2008 14:03:36" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
<EXE NAME="foo_scheduler.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
<MATCHING_FILE NAME="foo_scheduler.dll" SIZE="258560" CHECKSUM="0x2803A33E" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="03/18/2010 08:09:09" UPTO_LINK_DATE="03/18/2010 08:09:09" />
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
<MATCHING_FILE NAME="kernel32.dll" SIZE="986112" CHECKSUM="0x359DA0B2" BIN_FILE_VERSION="5.1.2600.3541" BIN_PRODUCT_VERSION="5.1.2600.3541" PRODUCT_VERSION="5.1.2600.3541" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.3541 (xpsp_sp2_gdr.090321-1320)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFEAFF" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.3541" UPTO_BIN_PRODUCT_VERSION="5.1.2600.3541" LINK_DATE="03/21/2009 14:18:57" UPTO_LINK_DATE="03/21/2009 14:18:57" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
</DATABASE>
And here are my components:
Core (2010-01-09 07:47:00)
foobar2000 core 1.0
foo_abx.dll (2009-06-07 15:25:26)
ABX Comparator 1.3.4
foo_ac3.dll (2010-01-11 12:18:40)
AC3 decoder 0.9.4
foo_audioscrobbler.dll (2010-02-07 16:16:48)
Audioscrobbler 1.4.6
foo_cdda.dll (2010-01-09 07:44:42)
CD Audio Decoder 3.0
foo_component_manager.dll (2010-03-02 10:17:38)
Component Manager 0.1.6.2
foo_converter.dll (2010-01-09 07:44:32)
Converter 1.4
foo_deskband_controls.dll (2010-02-08 22:20:32)
Deskband Controls 0.1
foo_dockable_panels.dll (2007-03-28 10:19:00)
Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48]
foo_dop.dll (2010-02-20 15:51:18)
iPod manager 0.6.6.7
foo_dsp_continuator.dll (2008-03-02 23:41:28)
Continuator 0.6.1
foo_dsp_crossfader.dll (2010-01-13 22:46:10)
Gapless Crossfader 1.3.4.1
foo_dsp_silence.dll (2009-08-10 02:32:54)
Post-track silence 0.0.3
foo_dsp_std.dll (2010-01-09 07:44:48)
Standard DSP Array 1.0
foo_facets.dll (2008-02-26 02:11:07)
Facets 2008-02-25
foo_filedate.dll (2007-09-19 07:07:14)
File date 1.0.4
foo_fileops.dll (2010-01-09 07:43:32)
File Operations 2.1.2
foo_freedb2.dll (2010-01-09 07:43:34)
freedb Tagger 0.6.2
foo_input_monkey.dll (2009-05-01 15:40:52)
Monkey's Audio Decoder 2.1.4
foo_input_std.dll (2010-01-09 07:44:24)
Standard Input Array 1.0
foo_jesus.dll (2010-01-03 14:41:18)
Autosave & Autobackup 8
foo_masstag.dll (2009-09-18 11:01:36)
Masstagger 1.8.4
foo_mouse_gesture.dll (2010-01-18 22:20:04)
Mouse Gesture Host 0.5.2
foo_musicbrainz.dll (2009-04-10 16:27:28)
MusicBrainz Tagger 0.2
foo_navigator.dll (2010-02-19 21:13:12)
Navigator 0.64
foo_new_file_stamper_mod (2).dll (2008-12-20 20:05:19)
New file stamper 1.0.0 [Dec 21 2008 - 01:05:11]
foo_playlist_attributes.dll (2009-11-16 15:33:44)
Playlist Attributes 0.2.2 [Nov 16 2009 - 20:33:31]
foo_prettypop.dll (2009-12-05 23:31:08)
Pretty Popup 1.2.5
foo_preview.dll (2008-12-22 16:41:11)
Preview 1.4
foo_random_pools.dll (2009-12-27 13:22:56)
Random Pools 0.0.1 [Dec 27 2009 - 18:22:23]
foo_rgscan.dll (2010-01-09 07:44:24)
ReplayGain Scanner 2.0.9
foo_run.dll (2009-06-07 16:15:18)
Run services 0.3.7
foo_scheduler.dll (2010-03-18 10:09:14)
Scheduler 4.01
foo_softplaylists.dll (2010-01-13 06:11:42)
Soft Playlists 2009-12-30.2
foo_stopaftercuralbum.dll (2009-06-01 09:50:42)
foo_stopaftercuralbum 0.2
foo_textdisplay.dll (2008-07-08 19:45:26)
Text Display UI Element 1.0 RC 3
foo_texttools.dll (2009-12-23 22:00:22)
Text Tools 1.0.4
foo_ui_columns.dll (2010-01-09 10:40:28)
Columns UI 0.3.8.3
foo_ui_std.dll (2010-01-09 07:44:52)
Default User Interface 0.9.5
foo_uie_biography.dll (2010-03-17 21:18:00)
Biography View 0.4.1.1
foo_uie_esplaylist.dll (2010-03-22 15:38:06)
EsPlaylist 0.0.7.1(prebeta)
foo_uie_trackinfo_mod.dll (2007-01-05 14:36:20)
Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]
foo_uie_wsh_panel_mod.dll (2010-02-27 22:59:14)
WSH Panel Mod 1.3.2
foo_unpack.dll (2010-01-09 07:43:20)
RAR reader 1.3
ZIP/GZIP reader 1.0
foo_vis_shpeck-beta.dll (2008-04-24 00:35:17)
Shpeck - Winamp vis plugins wrapper 0.2.4 beta 2
foo_wlm.dll (2010-02-09 17:06:12)
Windows Live Messenger Notifier 1.1.3
foo_scheduler
Reply #317
Useless information, at least I need foo_scheduler configuration. And stack trace, that's the most desirable. And don't create such large posts, moderators will be angry...
foo_scheduler
Reply #319
How do I get these
Fractal_Mortality,
see here and here how to submit crash reports in general. There has also been a more detailed post (by Yirkha, as far as I remember), but I can not find it anymore.
If Andrew does need your scheduler configuration, you may ask him whether you should send him your \foobar2000\configuration\foo_scheduler.dll.cfg file.
foo_scheduler
Reply #320
nope. it was running on power supply. But I assume that time the wakeup action fired up, my notebook hasn't been put into hibernation, neither any other power-saving mode. Something went wrong and the system was powered on the whole night so the wakeup was no big deal. That's the theory.
Since it happened many times that foo_sheduler did not shut down the system. Maybe because I entererd foobar's settings window after setting the sleep timer or anything else. Until now I did not find out when sheduler is being disabled.
I have some menu icons for specific actions. Let's consider following situation:
I push the corresponding menu button for e.g. sleep after 30 min (which stops playback and shuts down the system) and after say 20 minutes I realize that I want to renew the sleep timer again to 30 min from that time on. So I push the sleep button again. Sometimes (I don't exactly know when) scheduler does nothing then.
foo_scheduler
Reply #321
Scheduler is running all the time, it can't be disabled.
First you must stop an action list in the status window and only then push sleep button again. Otherwise there will be 2 running action lists.
foo_scheduler
Reply #322
Thanks for your investigation! I will see what can be done in these cases.
foo_scheduler
Reply #323
Apologies if I have missed the solution to this in earlier pages.
I use foobar2000 to stream music across the network I use instead of traditional radio.
What I need however is the scheduler to pick up a produced news file from a URL on the hour every hour.
if I enter the URL to play the individual file just as an individual request i know it can be picked up, but I would like to know how to use the scheduler to do this.
I'm sorry but I am only just getting into utilising configuration tools for stuff like this so I am fairly sure that there will be a very simple answer.
if I can get this event to work e.g http://www.internalnetwork.com/news.mp3 on a recurring hourly basis, then I can introduce other content too in a similar vein.
I want the file playing to prioritise over anything else, play, and then revert to either the original playlist or next scheduled event (crossfading).
I have a bit of a mental block on this at the moment because I do not seem to get an uninterrupted couple of hours I could do with to work through the logic for the first time....
Help appreciated
Ian
foo_scheduler
Reply #324
Hi, just to want to thank you for this great script, Andrew!
It's the component I use mostly    I even made a couple of buttons for each event and the configuration page to save time in navigating through the menu.
It's almost perfect, but I'd like to see one more feature, as requested few times before: Some kind of display, status bar or similar to show the remaining time and/or the currently active event.
Until now I mostly use it as a sleep timer when I go to bed, but I'd also like to wake up with my favourite songs...
If it possible ,I request the same feature.
Also I need from some help.I would to know how to check  the status of the current action in the scheduler (inactive or active).
As example: I want to use this function,but with scheduler
function createSACButton() {
   return new Button(ww - 62, 6, 13, 11, fb.StopAfterCurrent ? sac_on : sac_off, function () {fb.RunMainMenuCommand("Playback/Stop After Current");}, fb.StopAfterCurrent ? "Reset stop-after-current" : "Stop-after-current");
. I don't know how to call scheduler fb.xxxxx ?
Thanks in advance!
