Topic: [crashware] foo_input_mslive (Read 276555 times) previous topic - next topic
Reply #275
Hey, as I reinstalled my computer and updated to WinXP Sp3 and WMP 11, i also updated my foobar and components to the latest versions.
Now I have a problem with foo_input_mslive.dll.
I use for example this file:
<asx version="3.0">
<entry>
<ref href="http://players.creacast.com/creacast/klassik/playlist.asx"/>
<title>KlassikRadio</title>
</entry>
</asx>
The first time I try to play this stream, it works just fine. But the second time I try to open it, foobar freezes.
This also happens with other locations like:
http://lsd.newmedia.nacamar.net/bb/redirec.../livestream.wma
I am not really sure what is needed for the component in the meantime, I copied wmvcore.dll to c:\program files\foobar2000
Is there anything else I need to copy? Or am I doing anything else wrong?
Reply #276
This plugin plays MMS very nicely—thanks for your work! However, I've run into a problem with the stream at rtsp://211.89.225.1/encoder/cnr3, which Windows Media Player and Media Player Classic open successfully; when I use File > mslive streams > Add stream url > rtsp://211.89.225.1/encoder/cnr3 (Detect), foobar2000's console reports:
could not enumerate tracks (cannot connect to any of the referenced urls) on:
mslive://|rtsp://211.89.225.1/encoder/cnr3|/
I'm using version 0.4.7 of foo_input_mslive.dll with version 0.9.5.6 of foobar2000.
I would really appreciate it if you could explain and remedy this!
Reply #277
You should visit his blog and ask there.
Acropolis
Member Group: Banned
Reply #278
Ah, thank you, Squeller! Had you not said that, I would've waited for a long time.
Reply #279
I've just discovered this component. It works very well, thanks a lot!
could someone help me find out the url of this stream? :
edit: nevermind, I found it, but the url is dynamic, it changes every minute or so! >.<
I guess there's no way around this, right?
Reply #280
As Acropolis' site is down, does anyone have a copy of the most recent foo_input_mslive (0.4.9 I believe)?  Thanks!
Reply #283
It is 0.4.8. I must have misstyped in megaupload.
