Higher than 320kbps?
Reply #15 – 2006-09-15 18:48:30
As SebastianG said if you're out for best quality and allow for 400-500 kbps you're probably best off using wavPack lossy which you can use with your iPod if you switch to free Rockbox firmware. With this you can be pretty sure there will be no audible difference from the original. And you can allow for lower bitrate: wavPack @ ~ 350kbps is sufficient IMO even for extreme quality demands. I did similar considerations concerning mp3 once and wanted to use 320 kbps. But I realized using ~250 kbps yields practically the same quality. Perfectness is not achievable with mp3 but a a very very good quality is. As for VBR I share your considerations. In the very high bitrate range it doesn't offer advantages but provides for a certain danger that it makes things worse (though this is rare). To me Lame's ABR is the best way to go in the very high bitrate range (though there's nothing wrong using cbr 256). As for the encoder in the very high bitrate range I prefer old Lame 3.90.3 up to now because of it's quality robustness. I'm with the other contributors who say transparent quality is usually achieved with something like -V4. Unfortunately this is not valid for the universe of music. harpsichord for example requires a higher bitrate for very good quality (abr 224 or better IMO). But with a good encoder in the 250 kbps range you're pretty safe (with the exception of perhaps pre-echo issues in case you're sensitive towards that which you can check with samples like castanets).
