Topic: foo_uie_single_column_playlist (Read 743473 times) previous topic - next topic
Reply #575
So, I've downloaded 0.9.4 and I can't seem to get this mod working.  I've downloaded and extracted it into the components folder, and when I go to Preferences and try to change the interface, only default user interface is there to be chosen.  Am I missing something?
You need to have Columns UI installed.  That is the user interface.  Single column playlist is a panel for columns UI, it does not replace it.
Thats funny because I have Columns UI installed, but it won't let me select that as a UI either.  Something isn't right...
EDIT:  I got it figured out. thanks for the help
Reply #576
Here's an idea I'd like to throw out there, I think it would consolidate several feature requests:
I would like to request a simple $image() function for displaying an image without absolute positioning. I would also like to see this function work with $calcwidth() and $calcheight() to return the width or height of the image. This could be very useful in developing code to compensate for images with different aspect ratios. It would be even more amazing if $calcwidth($image(image.jpg)) would return a 0 if image.jpg does not exist, allowing for better development of "no-cover" code.
Reply #577
is there any way I could make it display the first image it found on the designated location ? (without specifying file name e.g. folder.jpg/png)
I tried this  $imageabs2(84,84,,,,,5,3,$replace(%path%,%filename_ext%,*),)
just doesn't work
Reply #578
This component does not currently support wildcard matches for filenames.
Reply #579
a recent version added keyboard shortcuts. Make sure you have the latest one
Thats strange, I'm usually quite anal about updating my components. Updating it fixed the problem. Thanks.
Reply #580
I dont really understand because i updated it yesterday and still no keyboard shortcuts for me. I ll try again tonight.
Yet i think it would be really cool if we could have a option to activate the middle mouse button delete feature.
Reply #581
Er, why do you want group rows to be 0? If you simply do not want a header, use !noheader! (I believe that is the syntax)
I use %_itemcount% to display (or not) my album covers.
Just out of interest, does item count work just like %totaltracks% (for correctly tagged albums of course), and give just the number of tracks per album, or is it per group? Sorry, I would test this in fb, but I'm at work atm.
Reply #582
It gives the number of items per group.
Reply #583
Is the artwork display wildcard(*.jpg) planned for future releases?
Reply #585
I hope so... I would like to see this feature very much, too!
fb2k on OSX: flac q8 > rockboxed Sansa e280v1: Vorbis q5.0
Reply #586
Can I specify the maximum width in pixels that a string can display, before it cuts and ends with "..."? (i guess there's a better terminology for this)
Reply #587
also searching for such a function since $cut only cuts of characters and is very general.
For example:
Ten characters of M are not as long as 10 characters of I
MMMMMMMMMM
IIIIIIIIII
Reply #588
For example:
MMMMMMMMMM
IIIIIIIIII
tornthomson: At the moment, I would just use a font that has the same width for every character. I know Lucida Console is one such font.
joule: At the moment, it does not truncate the string, but carries it over to the next line.
Reply #589
Can I limit the width of the text in any way? I guess I could draw a right aligned rectangle over the text where i don't want the text to be displayed, but maybe there's a better way.
Reply #590
I use this in foo_uie_trackinfo_mod :
$ifgreater($calcwidth(%artist% - %title%),750,
$rgb(32,64,128)$cut(%artist%$rgb() - $rgb(255,128,0)%title%,55)'...'
$rgb(32,64,128)%artist%$rgb() - $rgb(255,128,0)%title%
or without colors :
$cut(%artist% - %title%,55)'...'
%artist% - %title%
It should work in foo_uie_single_column_playlist. Change the values and see how it reacts.
Reply #591
Use alignabs and make the text box the width you want and the height the height of text. This will show the last whole word that fits.
Reply #592
Thanks! That was what alignabs was for.. I'll settle with that easy solution even though it doesn't provide the three dots after truncation.
Reply #593
Just wondering, is there a way to use alignabs but instead of having it cut off whole words, just have the text get cut off wherever it is. Maybe there could be an option to cut off the last letter instead of word. I need this so I can have a very thin playlist where long words in titles won't just disappear (instead just part of them would be shown).
Reply #594
Will not work with useing alignabs, must use $cut if you wish to take of characters and not whole words.
Reply #595
Alright. I can't think of any good way to have the playlist not completely cut off long words in the playlist using cut, though. The only way I could think to do it would be to use a font that has a consistent character width and base the amount cut off on the width of the panel.
Reply #596
Yeah, that seems to be the best way at the moment.
Reply #597
I think I decided to replace my columns ui playlist by this one.
Two questions:
a) can I use columns_ui global variables? After a first test it doesn't seem so.
b) how can I easily convert a $hsl output to r-g-b syntax? (I admit I'm lazy)
c) How can I dynamically (via code) change the background color of unselected tracks?
Thanks in advance.
Reply #598
I thought it was added to this plugin, but the $get_global() function isn't working for me either.  It is working for me in the trackinfo_mod, however
I use something similar to this, but without the $not() surrounding the %_selected% function.  I think that this should work.
$if($and($not(%_selected%),$not(%_isplaying%)),...)
Reply #599
okay from now on ill post in the relative thread, but how do i set up the relative path for the imageabs2?
i have my music set up differently, all my music is in one folder, and i have all my album art in a separate folder. And my art is saved in the format %artist%.jpg
C:\Documents and Settings\xxxx\My Documents\My Music\Album Art\%artist%.jpg
that is where my album art lies, how do i put that in a relative format? where do i need to put my art so that i can use relative paths?
