Topic: foo_title, new version for 0.9 (Read 284240 times) previous topic - next topic
Reply #325
Weird. But possible  Isn't it caused by some interference with other installed components? Can you try it on a clean foobar installation? Does this error appear every single time you click a button?
I have these two installs for some months: it was supposed to be a transition to port to foobar 1.x all my favourites behaviours, but some are harder to port than expected. Anyway, it has been working with no issue.
The issue with foo_title only arrived with foobar 1.1 and latest foo_title quickfix version. I did not update any other component since upgrade to 1.1.
It's hard to find the pattern. But when the error comes, it appears everytime i push a button (prev, next, stop, close, but not with the play/pause button!). I have to stop/restart foobar. Or start the old foobar install with foo_title also, same script, to get rid of the error. weird indeed.
The error message says : trying to read or write protected memory.
Reply #326
These bugs are hard to track down. We need to find some pattern that could provide a lead or make it happen on my computer as well. Maybe if you tried it in a fresh installation of foobar2000 1.1...
Reply #327
ok. For the last days, the error did not show up again... if its a conflict in rare conditions, it may indeed be very hard to identify. If it comes back again, I will try to find a pattern.
Reply #328
I would just like to say, foo_title along with many of the great skins available on the foo_title skins thread is absolutely amazing. It's one of those great additions to Foobar2000 that make it a killer audio program.
Reply #329
personally, it greatly benefits from foo_title to implement visual effects without CAD. i just wonder one more feature that how can i apply clear-type font face? it seems zigzag when i use "Segoe UI" (win7), it should be better be smooth and some more effects like text-shadow.
Reply #330
ClearType is explicitly disabled because I couldn't get it to work correctly on the transparent and colorful skins. I even tried it now on Win7, not better  But I guess it might be OK for some white non-transparent skins. I'll try to add a configuration option for this some time.
Reply #331
I have the same message on startup like alkasar. Furthermore foobar2000 (clean install - just official components) crashes on shutdown.
Here the crash log i already have sended:
Address: 013F48C5h (foobar2000+C48C5h)
Address: 01480EC1h (foobar2000+150EC1h)
Address: 0135E737h (foobar2000+2E737h)
Address: 014D13BCh (foobar2000+1A13BCh)
Address: 01478B69h (foobar2000+148B69h)
Address: 0139DE49h (foobar2000+6DE49h)
Address: 014D475Ch (foobar2000+1A475Ch)
Address: 014AB144h (foobar2000+17B144h)
Address: 014992E0h (foobar2000+1692E0h)
Address: 014AB128h (foobar2000+17B128h)
Address: 773503DDh (ntdll+703DDh), symbol: "WinSqmSetIfMaxDWORD" (+31h)
Address: 7730E1CCh (ntdll+2E1CCh), symbol: "RtlInitUnicodeString" (+164h)
Address: 7730DF32h (ntdll+2DF32h), symbol: "RtlAllocateHeap" (+ACh)
Address: 1002C515h (guard32+2C515h), symbol: "Exported" (+565h)
Address: 01466AEBh (foobar2000+136AEBh)
Address: 0146D2F1h (foobar2000+13D2F1h)
Address: 0146A970h (foobar2000+13A970h)
Address: 0146B205h (foobar2000+13B205h)
Address: 01487E0Bh (foobar2000+157E0Bh)
Address: 705B27D8h (shared+27D8h), symbol: "uPrintCrashInfo_OnEvent" (+B1h)
Address: 014A1324h (foobar2000+171324h)
Address: 705B281Eh (shared+281Eh), symbol: "uCallStackTracker::uCallStackTracker" (+31h)
Address: 0139DFCDh (foobar2000+6DFCDh)
Address: 01330000h (foobar2000+0h)
Address: 014705C7h (foobar2000+1405C7h)
Address: 014D61E0h (foobar2000+1A61E0h)
Address: 0146A17Ah (foobar2000+13A17Ah)
Address: 01466DBDh (foobar2000+136DBDh)
Address: 01466DB7h (foobar2000+136DB7h)
Address: 01493240h (foobar2000+163240h)
Address: 01493244h (foobar2000+163244h)
Address: 01490A51h (foobar2000+160A51h)
Address: 014883DDh (foobar2000+1583DDh)
Address: 01467FB2h (foobar2000+137FB2h)
Address: 75213677h (kernel32+13677h), symbol: "BaseThreadInitThunk" (+12h)
Address: 77319D42h (ntdll+39D42h), symbol: "RtlInitializeExceptionChain" (+63h)
Address: 75239775h (kernel32+39775h), symbol: "UnhandledExceptionFilter" (+0h)
Address: 77319D15h (ntdll+39D15h), symbol: "RtlInitializeExceptionChain" (+36h)
Address: 01468005h (foobar2000+138005h)
Environment:
App: foobar2000 v1.1.1
OS: Windows 6.1.7600 x64
CPU: AMD Athlon™ II X4 630 Processor, features: 3DNow!ex MMX SSE SSE2 SSE3
Audio: Lautsprecher (Realtek High Definition Audio); Realtek Digital Output (Realtek High Definition Audio)
UI: Default User Interface 0.9.5
Components:
Core (2010-11-05 10:46:52 UTC)
    foobar2000 core 1.1.1
foo_abx.dll (2010-11-18 22:20:23 UTC)
    ABX Comparator 1.3.4
foo_albumlist.dll (2010-11-05 10:45:06 UTC)
    Album List 4.5
foo_benchmark.dll (2010-11-18 22:20:23 UTC)
    Decoding Speed Test 1.1
foo_bitcompare.dll (2010-11-19 21:56:19 UTC)
    Binary Comparator 1.2
foo_burninate.dll (2010-11-18 22:20:23 UTC)
    Audio CD Writer 3.0.2
foo_cdda.dll (2010-11-05 10:44:56 UTC)
    CD Audio Decoder 3.0
foo_converter.dll (2010-11-05 10:44:36 UTC)
    Converter 1.5
foo_convolve.dll (2010-11-18 22:20:23 UTC)
    Convolver 0.3
foo_dsp_std.dll (2010-11-05 10:45:06 UTC)
    Standard DSP Array 1.0
foo_fileops.dll (2010-11-05 10:43:42 UTC)
    File Operations 2.1.3
foo_freedb2.dll (2010-11-05 10:43:42 UTC)
    freedb Tagger 0.6.2
foo_input_alac.dll (2010-11-18 22:20:23 UTC)
    ALAC Decoder 1.0.6
foo_input_monkey.dll (2010-11-18 22:20:23 UTC)
    Monkey's Audio Decoder 2.1.4
foo_input_std.dll (2010-11-05 10:50:28 UTC)
    Standard Input Array 1.0
foo_managedWrapper.dll (2010-08-25 09:12:44 UTC)
    foo_managedWrapper 0.5.1
foo_masstag.dll (2010-11-18 22:20:23 UTC)
    Masstagger 1.8.4
foo_out_wasapi.dll (2010-11-18 22:20:23 UTC)
    WASAPI output support 2.1
foo_playcount.dll (2010-11-18 22:20:23 UTC)
    Playback Statistics 3.0.1
foo_rgscan.dll (2010-11-05 10:44:34 UTC)
    ReplayGain Scanner 2.0.9
foo_texttools.dll (2010-11-18 22:20:23 UTC)
    Text Tools 1.0.5
foo_ui_std.dll (2010-11-05 10:45:14 UTC)
foo_unpack.dll (2010-11-05 10:43:56 UTC)
    ZIP/GZIP/RAR Reader 1.6
foo_verifier.dll (2010-11-18 22:20:23 UTC)
    File Integrity Verifier 1.1
Recent events:
Watching: D:\Eigene Musik
Album List refreshed in: 0:00.175551
Failed to read from C:\Users\[removed]\AppData\Roaming\foobar2000\foo_title\.
Startup time : 0:05.241959
Shutting down...
In components folder the icon for dll has a lock - maybe that has a meaning:
Edit:
I can't find foo_title in the componentslist in preferences as if it wasn't loaded. Nevertheless the foo_title branch appears in foobar2000s preferences.
Maybe it is useful for you to read the content of startup windwo in english:
[removed]
Reply #332
foo_title is foo_managedwrapper in the component list. You have it loaded.
I made a new install on a new netbook with Seven. I had the same error message once at the first start. Never since.
Very strange.
Reply #333
Thanks, i didn't look carefully enough.
@quiark
"foo_title" looks ugly in main menu and preferences. Don't you think this sweet component deserves a real name like: "Title notifier" or whatever else?
Reply #334
I have a question. My foo_title settings cannot display artwork which is embedded in the mp3 file. My folder structure looks like:
c:\muzik
......├kor
......├album
............├[2006] Yellowcard - Lights And Sounds
[kor] folder includes single mp3 files which has their own embedded artwork but do not work;
and there is an independent cover.jpg for every sub-folder under [album] that works properly.
Additionally, my fb2k is a portable installation, and no %appdata% settings for fb2k.
For foo_title setting in 'misc->Album Art', cover;folder;%front%;%filename%;%album%
so, what's going on? is there any solution?
Reply #335
Unfortunately, foo_title does not support embedded artwork.
Reply #336
So...that's it... it must be the most unfortunate thing for foo_title. I have been surfing and asking this question for months...
really thx for your response..
Reply #337
foobar2000s artworkreader does! Do you plan to support it in one of next versions?
Reply #338
Not right now, maybe when I have some free time again.
Reply #340
Could the Germanic umlaut "ö" in your user path be the reason for that problem?
Ein Teil des Pfades C:\Users\[removed]\AppData\Roaming\foobar2000\foo_title... konnte nicht gefunden werden
(A part of the path couldn't be found)
Reply #341
You are absolutely right! I had this issue in normal installation and in portable installation which was placed on desktop. I copied quickly the portable installation to C:\ and then it worked.
Reply #343
This addon is really good. I think it needs an option to only be displayed while foobar is playing the song and not when the song is paused. I often leave Foobar open and paused while I do something else like watching a show or a movie and the bar with the song's info is there bothering (as I use it always on top)
Reply #344
if this plugin ever reads embedded artwork its win!
Reply #345
A DirectX hook would be amazing if this is still developed.
The very act of observing, influences what happens.
Reply #346
ive noticed that when using album art, even if there is no art file in the folder but the folder has a thumbnail it will use that picture. i dont know the mechanisms that are causing this but it has posed some problems for me. also would there be a way to also used embedded artwork rather than just picture files in the folder? i use columns ui and it displays embedded artwork so it is possible to do in foobar
Reply #347
figured out a fix. just have to remove "folder" from the possible album art filenames in the settings. and then i renamed all the album arts i had named folder to front
Reply #348
I'm getting error dump on shutdown on my play about system running 1.1.6 Beta 4 , tried manual install of components no joy.. Win 7 , Any ideas?
Reply #349
So... is there any alternative to this plugin other than foo_prettypopup?
This plugin has some weird activation quirks that I don't really like (the only command that can be linked to shortcuts just enables/disables the popups, rather than showing the popups for a few brief seconds... there are a few other quirks, but this doesn't seem to be developed for anymore).
Pretty Popup, for some reason, stops working after awhile with my setup. Which is ashame, because it does everything I want it to.
