Topic: Converting 'Normalize' (db) output to use with --scale (lame) (Read 3054 times) previous topic - next topic
Could anyone tell me how to convert the oputput from 'normalize' (Decibels) to use with the --scale option in 'lame'
For example I have this 'normalize' output
[Bobby@NoIP]$ normalize -n 15\ - example audio.WAV
Computing levels...
level        peak        gain
-16,7914dBFS -1,0410dBFS  4,7914dB  15 - example audio.WAV
And I want to get a number out of this to use with the --scale option in the 'lame' encoder.
Any hints ?
WaveGain
I prefer foobar2000 Diskwriter with "Use Replay Gain".
These are essentially same procedure.
Yes, use WaveGain instead of normalize.
See this topic and this post in it.
You can use a simple shell script:
album mode:
GAIN=$(wavegain -a -p -x *.wav);
for all in *.wav
do
    lame --scale $GAIN "$all";
done
radio mode:
for all in *.wav
do
    lame --scale $(wavegain -p -x "$all") "$all";
done
or simply for a single file:
lame --scale $(wavegain -p -x file.wav) file.wav
Edit: radio gain is done for each file.
Thanks everyone who replied.  I'm encoding mostly speech CDs so I'l be using the "Albun mode" of WaveGain, neat tool but took a while to find
