Topic: what is mpeg 1 layer 1 ? (Read 4248 times) previous topic - next topic
hello, I demuxed an avi file with a strange audio soundtrack.
I thought it was mp3 but winamp refused to play it and
showed it was mpeg 1 layer 1.
Is there a winamp plugin for such files ?
thanks
Winamp should be able to decode MP1 files if I am not mistaken. It has built-in support for Layer I, II and III. That file information is often wrong. I saw Winamp pretty often reporting some Layer III files as Layer II with emphasis bit set, etc.
thanks
Mpeg 1 Layer 1 is AFAIK only used in the now obsolete DCC (Digital Compact Cassette) by Philips.
"Layer-1: Its ISO target bitrate is 192 kbps per audio channel. Layer-1 is a simplified version of Layer-2. It is most useful for bitrates around the "high" bitrates around or above 192 kbps. A version of Layer-1 is used as "PASC" with the DCC recorder."
http://www.faqs.org/faqs/mpeg-faq/part1/
"(MP1) A simple 32-subband audio compressor using a floating point representation for subband samples. Resolution and scale factor are stored for groups of 12 subsamples. MP1 is only used for Philips DCC Digital Compact cassette with data rates of 384 kbps. "
http://www.computer-dictionary-online.org/...dio%20layer%201
/Kef
yes, winamp was wrong... in fact I found out by renaming the file extension to  .wav that it was ADPCM, not mpeg 1 layer 1 !
thanks for the info on mp1, that's interesting. I once had a portable dcc recorder, this was crap. I'm glad it's a dead format.
Use Mr. QuestionMan perhaps to correctly find out what your file is actually.
thanks
What did you demux it with?
Vorbis-q0-lowpass99
lame3.93.1-q5-V9-k-nspsytune
