Topic: How to FLAC archive files recorded by Nero 7 Ultra? (Read 6324 times) previous topic - next topic
Please help. I am trying to FLAC archive files recorded from LPs by Nero 7. I need to find either free conversion software that will accept MS PCM Wav files or a Nero plugin that will let me record to a format that can be converted to FLAC. Any advice would be greatly appreciated.
http://flac.sourceforge.net/
pretty much any software that encodes to FLAC should accept pcm wav (which is a very standard format)
FLACdrop and FLAC frontend are both simple and easy to use
Cosmo, Thanks for the quick reply. I did solve my problem with a FLAC plugin for Nero. When I tried to use FLAC Frontend the program reported that MS Wav was not a recognized format.
I have a different problem. When I try to encode files to nero aac using a plugin for flac-nero freezes at the end of the encode. It does not freeze if I convert the flac files to wav first. Are there compatibility issues with flac plugin and nero 7?
you will make mp3's for compatibility reasons.
