Topic: Any way to remove FLAGS DCP from EAC cuesheet? (Read 5534 times) previous topic - next topic
Is there any way to make EAC not put the FLAGS DCP in a cuesheet? I know I can manually remove them, but I'm lazy and don't want to.
Here: http://homepage.ntlworld.com/jfe1205/flags.zip is a little program that will do that for you!!  No help, error messages, etc, just a bare proggie.
Type: flags inputfilename, enter.
Clear the Disable copy protection flag on adding audio files... checkbox under EAC Options > Write.
I use cuemod.exe with catwalk to do that task. It works reliably and is very flexible and you can make it remove any line from a cuesheet or from multiple cuesheets.
http://tangerine.uw.hu/prog
This doesn't work. That just disables the copy protection flag if you go to burn a CD using EAC. I appreciate the tools that have been suggested, but I was just wondering if there was a way to disable it within EAC.
You're right, the two are not connected. You cannot prevent EAC from putting FLAGS DCP into the cue sheet, if the CD has that flag set, then.
