Topic: Wanted v0.9 plugin ports (Read 749502 times) previous topic - next topic
Is there a plugin that could serve the same purpose as foo_history and which might be ported?  (no port planned?)
The I-net radio plugin would be nice to see in 0.9. Also a "search database / playlist box" in the ui_columns whould be great
foo_msn (AMIP is not ok because it still shows track in messenger when you pause it)
foo_winamp_spam
This thread is useful as you are posting the versions as they come out. Good work!
hi
Thanks a lot for info guys
what about foo_uie_trackinfo.dll? Doesn't seem to be ported yet!
Source can be found here
Thnx in advance
iN TRANCE WE TRUST
foo_dsp_ssrc.dll (Resampling plugin that uses the SSRC library, was part of the special installer of foobar2000 0.83 IIRC)
foo_dsp_bs2b.dll (configurable crossfeed-emulation plugin for headphone-listening)
foo_convolve.dll (general dsp convolution plugin, originally by Garf, IIRC)
Tim
I can stay for hours listening to all the sounds... (Samuel Beckett, Rough for Theatre I)
Reply #30
I like having foo_dynamics for listening to music at work on my speakers at low volume.
Could you please add a description in addition to the filenames on the list. I have no clue what 90% of the plugins on the list do.
foo_wma (Enables .wma playback.. if it isn't ported already..)
Reply #33
I also very much liked the old database search utility, but I can't remember what it was called.  Perhaps the new media library plugins can be far better.
Also, the old freedb tools were useful... can't wait for those.
[a href="index.php?act=findpost&pid=373585"][{POST_SNAPBACK}][/a]
freedb2 & dbsearch are already available into foosion plugins (bottom of the ported plugins list)
[a href="index.php?act=findpost&pid=373614"][{POST_SNAPBACK}][/a]
I understand and I must say I don't have any information either about most of these plugins.
This would represent some huge work and I'm not ready to do that now, but I might try and add descriptions for the ported plugins later...
Reply #34
foo_dsp_ssrc.dll
I think foobar can now resample using foo_dsp_ppsh.dll
Reply #35
foo_dsp_ssrc.dll
[a href="index.php?act=findpost&pid=373622"][{POST_SNAPBACK}][/a]
L'embarras du choix?
No, really, I sometimes use foobar2000 for pseudo-mastering purposes, and having ssrc, which is a really high-quality resampler, at hand in your dsp chain is really really handy.
But I agree that, for normal listening, pphs is a good choice as it uses less system resources.
Tim
Reply #36
Seriously, could you guys make this thread sticky? At least for a while, until people are used to 0.9 and its plugins.
This is a very useful topic.  Thanks a lot.
Liberate tutemae ex inferis
Reply #37
Tim
but then again, au pire des cas, you can always use ssrc outside of foobar...
Reply #38
Seriously, could you guys make this thread sticky? At least for a while, until people are used to 0.9 and its plugins.[a href="index.php?act=findpost&pid=373629"][{POST_SNAPBACK}][/a]
Done.
Please keep the discussion about individual components to a minimum, i.e. use separate threads for in-depth discussion to keep this thread manageable and easy to use.
Reply #39
foo_spc (using "Like SNES" settings at 32KHz, rather than High-quality emulation at a different frequency)
Edit:  I'm stupid.  I wasn't aware that foo_gep covered all my base already lol.
Reply #40
foo_minibar
Source code that compiled under 0.7 SDK: here.
rotjong
Reply #41
Let's not forget:
foo_uie_simple_spectrum.dll
Reply #42
foo_dsp_dolbyhp - Dolby Headphone
foo_uie_volume - Volume control
Reply #43
necessary for me:
foo_controlserver
foo_text (or  foo_text_ftp)
foo_write_http
not so necessary:
foo_out_dsound_ex2
Reply #44
There's a volume slider in v0.9 - just click the dB level indicator in the lower right corner.
Reply #45
foo_playlistfind (searches the playlist, and can be added as a toolbar/panel)
Only one I'm really waiting for...
Reply #46
foo_mim_notify
It sends notifications with now playing information to Miranda IM.
Edit:
I would like to withdraw this request if it's possible. I just found foo_prettypopup and I much prefer it to foo_mim_notify.
Reply #47
call me stupid but where is the 0.9 freedb2 component
ive been looking on foosions site but cant find a link
all his components are for the RC, not the final version
maybe im blind
Reply #48
maybe im blind
[a href="index.php?act=findpost&pid=373690"][{POST_SNAPBACK}][/a]
what works in the rc works in the final too..
Reply #49
wow thats awesome thanks heaps
now it all makes sense to me
