bitperfect rips... under Linux
Reply #4 – 2006-03-05 14:31:11
You could work it out from using EAC's Compare WAV facility. Thanks! Using EAC under wine I got a value of 36 repeat samples for my DVR-110D. I repeated the rip using this offset and now I get identical files to EAC:cdparanoia -Bvz --sample-offset 36 -d /dev/cdrom 3 track_03.wav cdparanoia III release 9.8 (March 23, 2001) (C) 2001 Monty <monty@xiph.org> and Xiphophorus Report bugs to paranoia@xiph.org http://www.xiph.org/paranoia/ Checking /dev/cdrom for cdrom... Testing /dev/cdrom for cooked ioctl() interface CDROM sensed: ATAPI compatible PIONEER DVD-RW DVR-110D Verifying drive can read CDDA... Expected command set reads OK. Table of contents (audio tracks only): track length begin copy pre ch =========================================================== 1. 57380 [12:45.05] 33 [00:00.33] no no 2 2. 47175 [10:29.00] 57413 [12:45.38] no no 2 3. 32450 [07:12.50] 104588 [23:14.38] no no 2 4. 54905 [12:12.05] 137038 [30:27.13] no no 2 TOTAL 191910 [42:38.60] (audio only) Ripping from sector 104588 (track 3 [0:00.00]) to sector 137037 (track 3 [7:12.49]) outputting to track03.track_03.wav (== PROGRESS == [ | 137037 00 ] == :^D * ==) Done. $ diff track03.track_03.wav ../Desktop/My\ albums/Track03.wav $ (where Track03.wav was from EAC). If there were differences, diff would have said so. BTW: according to this list the correct offset of my Pioneer 110D is "+48". Yet I seemingly got "+36". Was my EAC output also wrong? (EAC on that windows box was never calibrated, but it did give consistent results between two different CD drives).
