I ripped a scratched CD using EAC, and got errors.
2006-02-24 18:34:06
Hi. I have a CD that has tiny areas that are practically transparent. I mean that when you hold it against a light you can actually see light passing through. This of course makes certain parts of it (one track) impossible to play a CD player. I tried to rip the CD using EAC with Secure mode. When it got to the scratched part, it became really slow ( < 0.1%) and started giving Read/Sync errors (I will paste the log file at the end of the message). I waited for about an hour and not much progress... I saw on an other thread here that in these cases it's good to try "Burst mode" and "Test and Copy...". So I did. It finished the job and produced a file that (to me) sounds perfect, but of course there were errors (Timing problems). What do these errors mean? I'm using really poor speakers, so maybe the quality is actually bad and I can't notice it. Is it possible that I have a perfect file (as far as I care), and that the errors are things that only the computer can notice? And how is it possible to get a WAV file that sounds ok, when there are parts in the CD that are PHYSICALLY missing? I'm going to try and start another rip in Secure mode before I go to sleep and let it work through the night. So here is the log: Used drive : LITE-ON DVDRW SOHW-1673S Adapter: 0 ID: 0 Read mode : Burst Combined read/write offset correction : 0 Overread into Lead-In and Lead-Out : No Used output format : D:\Program Files\Monkey's Audio\wapet.exe (User Defined Encoder) 192 kBit/s Additional command line options : %d -t "Artist=%a" -t "Title=%t" -t "Album=%g" -t "Year=%y" -t "Track=%n" -t "Genre=%m" mac.exe %s %d -c2000 Other options : Fill up missing offset samples with silence : Yes Delete leading and trailing silent blocks : No Native Win32 interface for Win NT & 2000 Track 8 Filename D:\Mp3z\Unknown Artist - Track08.wav Timing problem 0:02:09 - 0:02:13 Timing problem 0:02:15 - 0:02:21 Timing problem 0:05:01 Timing problem 0:05:43 Timing problem 0:05:56 Timing problem 0:06:01 - 0:06:44 Timing problem 0:08:10 - 0:08:15 Timing problem 0:08:31 - 0:08:33 Timing problem 0:08:41 Timing problem 0:10:37 Timing problem 0:10:56 Timing problem 0:11:00 - 0:11:01 Timing problem 0:11:17 - 0:11:19 Timing problem 0:11:23 - 0:12:02 Timing problem 0:12:11 Timing problem 0:12:13 - 0:12:14 Timing problem 0:12:17 - 0:12:19 Timing problem 0:12:24 Timing problem 0:12:28 - 0:12:30 Timing problem 0:12:41 - 0:12:44 Timing problem 0:12:47 - 0:12:49 Peak level 100.0 % Test CRC FEE94D24 Copy CRC 357A8222 Copy finished No errors occured End of status report Cheers!!!
