Topic: Reducing mp3 File Size While Retaining Tags (Read 3488 times) previous topic - next topic
I have my entire CD collection on my hard drive, with most encoded using LAME v3.90.3 "--alt-preset standard" (when this was still the preferred version). I'd like to reduce the size of a number of these files to place them on an older mp3 player. I know to optimize sound quality I should encode from the source .wav files, but I'm willing to trade the difference in sound for the time saved.
Is there a way, either on the command line or through a front-end GUI, that I can retain all my mp3 tags when I create an mp3 file from an mp3 file? With the following command I lose all my tags:
lame -V5 --vbr-new --mp3input "f:\mp3\Beatles\Revolver\01 - The Beatles - Taxman.mp3" "f:\mp3portable\Beatles\Revolver\01 - The Beatles - Taxman.mp3"
Foobar2000.
Foobar2000.
[a href="index.php?act=findpost&pid=354155"][{POST_SNAPBACK}][/a]
Can you give more details? I use fb2k to listen to mp3 files on my PC and to copy mp3 files in order to rename them starting with a playlist track number so my DVD player plays songs in the order I want.  I also use the plugins replaygain to standardize volume and diskwriter to create .wav files from mp3 files.
How can I use fb2k to encode an mp3 file from an existing mp3 file? Will I be able to place files in multiple directories in one pass (when converting files in \Beatles\Help and \Beatles\Revolver will I be able to place the new files in respectively different directories)?
[a href="index.php?act=findpost&pid=354281"][{POST_SNAPBACK}][/a]
With the same thing you use to create .wav files from mp3 files - with Diskwriter.
[a href="index.php?act=findpost&pid=354313"][{POST_SNAPBACK}][/a]
I only see two output options for the diskwriter component and both are .wav files. I've combed through the fb2k components forum and cannot figure out how to get any type of dialog box that includes mp3 settings. I assume I will need to place my lame_enc.dll somewhere (components directory?), but I can't find anything regarding that either.
You'll need the Command-Line Encoder plugin for foobar2000 (foo_clienc.dll), and lame.exe (NOT lame_enc.dll).
The current foobar beta comes with the diskwriter preconfigured with lame; all you need is to get the current recommended lame version (3.97b2), place it anywhere (it will ask for the path) and you can set the quality with a slider.
http://foobar2000.org/beta/index.html
