Topic: Realtek AC97 and ASIO drivers (Read 3803 times) previous topic - next topic
Hi all!
Is there a way to use ASIO/ASIO4ALL drivers with Foobar and my Realtek AC97 audio on board?
If I cannot use ASIO driver what's the best alternate output choice?
(Let's see if I can have a serious answer this time)
I'd strongly advice against re-opening already closed threads unless you're a mod.
Horello:
Basically, all outputs are created equal. The best output choice is always the one that works for you (as in does not trigger issues like random crashes in your soundcard drivers)
You should read the FAQ and search the forum before asking, well, frequently asked questions.
See also http://foobar2000.org/FAQ.html#FAQ_o2
(friendly hint: you better go do some research and stop asking now)
