Topic: LAME problem samples - discussion (Read 46734 times) previous topic - next topic
Reply #50
Can you do me a final favor and try 3.90.3 --alt-preset 270? I'd like to use that for future productive purposes.
with pleasure
3.90.3 --alt-preset 270 passed my pre-echo test  (can't abx). Please note that this is just pre-echo test and it might as well fail on other artifacts.
//still like fastenc better 'cause it is 3x faster
J.M.
Reply #51
Search on scooter.flac gives nothing. Where is sample?
Reply #52
Thanks a lot.
You have helped me a lot with your test on your pre-echo sample.
Sure this doesn't tell about other artifacts. But for the worst problem samples (to me) the problems are negligble to me at a bitrate of 256 kbps and above. As for them I prefered gpsycho a little bit but there has never been an essential difference to me. I just had to make up mind, and decided to use gpsycho.
But your test shows me if I take it all together that the better solution is to use --alt-preset 270.
Out of curiosity I will try fastencc 1.02 and EasyMP3 (if I can get at it) on the bad problem samples I mentioned (though I don't think I will deviate from using Lame). Thank you for the detailed information.
lame3995o -Q1.7 --lowpass 17
Reply #53
here. (last post)
>halb27: glad it helped
EasyMP3 is here. I think the shareware version has some limitations though.
Reply #54
Thanks for the link.
Just tested my standard-bad samples (harp40_1, herding_calls, trumpet) with the Fraunhofer codecs at cbr256. At this bitrate Lame yields a not-at-all-annoying quality (though is not transparent) to me. fastencc102 -br 256000 -hq does so as well. I also tried EasyMp3 but as you said there are restrictions (especially bad for abxing: an intro is added). From just careful listening it sounds the same to me as fastenncc102 (no surprise).
As you are sensitive towards pre-echo maybe fastenc is the better choice for you (AFAIK fastenc is famed for its good pre-echo behavior). I personally stick with lame (but 3.90.3 --alt-preset 270 --lowpass 18.6 from now on).
Thanks again for your help.
Reply #55
ABOUT THIS SAMPLE.
ABX log = http://audiotests.free.fr/tests/2006.05/_a3_a4.txt
I compared alpha 3 ("revision 3" from 2006.02.05) with alpha 4 - which sound worse (alpha 3 is also far from transparency).
setting used: -b128
EDIT: -V5 --vbr new has no issue like this. alpha 4 jump to 183 kbps whereas alpha 3_3 is only 155 kbps (quality is on first look identical).
Reply #56
setting used: -b128
yeah, that's also my experience - only CBR is affected by this artifact. But I still dont get why it happens only sometimes (and quite rarely). (e.g. my looped scooter sample - the exactly same waveform is looped several times but it artifacts only sometimes)
J.M.
edit> quick test; adding -q 5 seems to fix the artifact
edit again> -q 4 is also fine.
When encoded with default quality, there is also a very nasty dropout on the first kick, extending down to 2kHz (!)
