Topic: fb0.9b9 Bug: songlength wrong after changing file (Read 3352 times) previous topic - next topic
Hi
2 Bugs:
1. I downloaded a file and wanted to hear it, before the download finsished, so i copied the incomplete file and listened to it, while the original countinued dowloading. After some time I deleted the copy and made a new one to have more of the song. (the orig was still incomplete).
But foobar shows the length of the old copy for the new copy but don't stops playing when the statusinfo(don't know the right english word for that. The thing which shows you the position of the song) reaches the end.
I have a percent status info additional to that which shows position 300% of the song.
So foobar don't update it's filelength info even if the file changed...
2.  When i search a song in my medialibary, i only can play the song through doubleclick, if the song exists in the activ playlist, if not, nothing happens...
--Ano
2. Not a bug, foobar2000 0.9 can only play files that are on a playlist.
1. I'm not sure why that would happen, since foobar2000 detects filechanges by filesize and last modified timestamp. Can you give more details like what format that file is in (MP3, Vorbis, AAC, ...)?
It was a mp3 File.. don't know what more to say.. Tell me if you need to know something special..
[Edit:] I found some interessting things:
If i open the properties windows for the file (titled File Info - Songname), it shows the length of the old file.
But at the bottum in the statusbar it shows the correct length..
2.  Why not changing the behavior from "doing nothing on play if file is not in playlist" to "search playlist where this song is or create a new one for the song" in the libsearch? It would be more comfortable...
--Ano
Are %_time_total% and %_length% the same?
Essentially yes, but %_time_total% only works for the currently playing item.
I know, thanks, I was actually asking Anonym001 if he was getting different values when playing that track. The help page says "%_time_total% / %_time_total_seconds% get data from playback core while %_length% / %_length_seconds% get data from database, in some rare cases either of them may be more reliable." so it could be good to know if that's one of those cases he's on about.
I got information from zZzZzZz that only the timestamp was checked for detecting file info changes, but the filesize was ignored. This will be fixed in the next beta. It is still weird that both copies had the same timestamp.
%length% has the real file length
%_time_total_seconds% has the old file length
--Ano
