Topic: LyricsDB discussion (Read 424423 times) previous topic - next topic
LyricsDB discussion
Reply #200
Is a tab version on the way?
LyricsDB discussion
Reply #201
Thanks for a great plugin... !
But, how can i get access to edit mode on tracks i submitted. I have submitted some that i would like to correct a bit.
LyricsDB discussion
Reply #202
You need to be an advanced user to edit lyrics. But i don't know if you will ever get promoted to a higher level...
EDIT: if the promotion system works in the way, that the admin needs to check all the lyrics you posted, i doubt you get ever promoted, because i'm sure dug has more important work than checking lyrics.
If it's based on the number of complains for your lyrics, you may get promoted, but i'm not sure with that
LyricsDB discussion
Reply #203
I thougth you just have to be registred to edit lyricsm am i wrong?
And so-called promoting system just don't have any system  Some guy posted all lyrics from last rhcp album, so was promoted same second I noticed.  I just have no idea does anyone use web-face for something or just I from time to time do.
And yes, there's always something to do...
You are aware of web-interface, right?
dezisehtnys eb lliw noitulover eht
LyricsDB discussion
Reply #204
Thanks a lot, Solved, Now the edit link is there  (And i'm now an advanced user, was ordinary)
LyricsDB discussion
Reply #206
bug report:
foobar crashed when i was trying to retrieve the lyrics for the album "Ayreon - Human Equation". The window with lyrics two versions showed up, then it crashed, however the track continued to play.
I tryied to get the lyrics for the first (Day One: Vigil) and second (Day Two: Isolation)  track separetely, with the same results...
EDIT: it seems, that the lyrics version window ALWAYS causes foobar to crash, no matter what the album is
(foobar2000 v0.9.2 beta 4, LyricsDB v0.0.7 beta 3, Win2K SP4)
Same here.
foobar2000 v0.9.2 beta 5, LyricsDB v0.0.7 beta 3, WinXP SP2
LyricsDB discussion
Reply #207
bug report:
Yes, seems so. I think I'll disable this feature on the server again, will enable it just as soon as fix the issue…
LyricsDB discussion
Reply #208
crossed 6'000 artists and 100'000 lyrics marks, couldn't beleive it ...
LyricsDB discussion
Reply #209
Great news!
LyricsDB discussion
Reply #210
I've found some lyrics that I want to edit too. But I am just an ordinary user. Any chance I can request an upgrade to advanced?
My login name is lexlyrics.
Edit: Thanks a lot dug.
foobar2000 + EAC + Burrrn = Happiness
LyricsDB discussion
Reply #211
Anyone else having problem using the web-interface? It worked fine up until today for me, but now it's seems to be gone??
Works fine again now=)
LyricsDB discussion
Reply #213
You could make a simplified version (radio button in configuration), which doesn't save lyrics - it just shows them. For me (and maybe some other people) that would be great because I just ocasionally check for lyrics.
It would be easy as clicking on a song, and selecting Show Lyrics ..
Do you guys know if such component exists?
LyricsDB discussion
Reply #214
Just click get lyrics and when the lyrics are showed cancel and nothing will be saved.
In the 3rd party components section there's a sticky topic called 'Most wanted v0.9 components' or something like that. You can find there some lyrics plugins that can do the job.
edit: this one. The wiki is useful too.
LyricsDB discussion
Reply #215
I don't get it, I copied it to my components folder, but how do I use it inside foobar2000? I can find it in preferences but I can't insert it with columns_ui or anything. Only the options I can find. Could someone please help me?
LyricsDB discussion
Reply #216
You can access it through the context menu.
It seems that you think that this plugin displays lyrics, but it is made to downloads them.
LyricsDB discussion
Reply #217
Yes, it was, yes. I am already tired to explain this... I glad to see a person, who understands what the plugin is for ;)
LyricsDB discussion
Reply #218
Then what plugin to I use to show them? I tried the different I could find around HA, but I couldn't figure out, how to make them work together
LyricsDB discussion
Reply #219
You Need Lyric Show Panel -- Latest Version --> 0.3.0.0 Lyrics Show plugins for foobar2000
Developed by bluenet
Compiled on: Jun  2 2006
LyricsDB discussion
Reply #220
is it possible to have it search automatically for the current playing song?
LyricsDB discussion
Reply #221
Only if you assign a hotkey.
LyricsDB discussion
Reply #222
Alright I got it now, it's supposed to be green and scrolling right? But anyway it won't show songs I know is on the site for lyricsdb, so how do I get them to work together?
- Twaize
LyricsDB discussion
Reply #223
You need to save the lyrics into to the ID3 tag with LyricsDB first, and then Lyrics Show will show them.
Personally i prefer trackinfo for displaying lyrics, as i don't like the scrolling.
LyricsDB discussion
Reply #224
If I have to download all the lyrics manually and insert them into the ID3 tag, then what is the point of LyricsDB?
